Page 135 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Status
Not open for further replies.
BFG10K
22,709
3,005
This thread was started in mid 2021 and is being retired/locked. As the OP is no longer active, or updating and maintaining it.
Mod DAPUNISHER
8GB
10GB / 12GB
  1. It's the player's fault.
  2. It's the reviewer's fault.
  4. It's AMD's fault.
  5. It's the game's fault.
  6. It's the driver's fault.
  9. Wrong area was tested.
  10. Wrong games were tested.
  11. 4K is irrelevant.
  16. It's an anomaly.
  17. It's a console port.
19,203
Sad thing it ran so smoothly before the update
I think the gold standard for gaming engines is still ID Software's after all these years. They strike an excellent balance between speed and pushing the graphics quality envelope. Even if their engine is hard on contemporary cards, one or two gens later, the same engine delivers 100+ fps at max settings. Seems they have some secret recipe that Carmack discovered long ago that allows the engine to scale up automatically with more CPU/GPU horsepower and which to this day is being used by them as a trade secret.
Ranulf
2,895
2,556
Eh, I'm not surprised. Let's just say I'm not impressed by the KCD devs for numerous reasons. The last thing they really need to be working on for that game is any upscaling tech or ray tracing. The reported bugs and features left out that were in the first game should be a priority. The engine is fine and runs on older hardware now very well and the game looks good.
marees
2,036
2,670
The overall overview shows that there are still games that run perfectly with 8 GB, but they are a dying breed. Anyone who wants to use ray tracing will definitely overtax an 8 GB graphics card – not because of the processing power required, but because of the memory requirements. The frame rate differences are gigantic and even produce interesting results in the "RTX 4060 Ti 16GB beats RTX 5070"
Anyone who has been using an 8 GB graphics card for years knows its peculiarities and doesn't need to replace it based on the results. However, the often-read statement that 8 GB is sufficient in Full HD has been refuted forever by this test. Anyone who doesn't manually reduce the details will experience either stuttering or texture mush, which the game automatically serves up in an attempt to save the frame rate. It should not go unmentioned that, despite our demanding test scenarios, we still show a best-case scenario. Typical gaming PCs have various programs running in the background that take up additional graphics memory and thus exacerbate the problems described. In addition, the number of games that are critical with 8 GB is significantly larger than the 35 benchmarks shown here, which represent a cross-section.
Ranulf
2,895
2,556
A good point that is often missed or just not outright stated explicitly. Windows usually wants 1GB of vram for itself in a desktop scenario. A 4GB card is really 3GB for games. A 12GB card is really 11GB etc..
Golgatha
12,424
1,110
Honest question here. For lower end video cards, will the amount of VRAM not matter, or at least not matter as much, in the future? Looking at the recently released spec for PCIe 7.0, the bandwidth for a x16 slot will be 512GB/s and Direct Storage is a thing. The 4070 12GB only has 504GB/s of memory bandwidth. Thinking further though, I guess you'd be limited by the speed of your SSD, but it might be a nice use case for a SLC 8GB or 16GB module connected directly to the video card; much like the RAM upgrades of olden days.
Thunder 57
4,204
6,991
Honest question here. For lower end video cards, will the amount of VRAM not matter in the future? Looking at the recently released spec for PCIe 7.0, the bandwidth for a x16 slot will be 512GB/s and Direct Storage is a thing. The 4070 12GB only has 504GB/s of memory bandwidth. Thinking further though, I guess you'd be limited by the speed of your SSD, but it might be a nice use case for a SLC 8GB or 16GB module connected directly to the video card; much like the RAM upgrades of olden days.
PCIe 6 (let alone 7) won't make its way to client for years.
Reactions: Mopetar
Golgatha
12,424
1,110
Right, it took about 3 years to get the first PCIe 5.0 video cards, and (IMO) first viable PCIe 5.0 SSDs; aka a SSD that doesn't need a heatpipe and/or active cooling to run without throttling. So, the more specific question is say 6-10 years from now, will Direct Storage largely alleviate the need for more VRAM on video cards?
Edit: Thinking about this more and even though I despise proprietary solutions, a 16x video card could be split between an 8x interface for the GPU and an 8x interface for a SSD or proprietary memory upgrade module. Maybe even a non-proprietary solution of dual 4x NVME drives in some sort of dual channel configuration?
19,203
Not sure how much VRAM writing is done in gaming workloads. If it's a lot, we would need expensive SSDs with higher TBW ratings.
Golgatha
12,424
1,110
Most Direct Storage is read operations, but for this I would envision a small but really fast purely SLC cache module; this would give you fast read and write + higher TBW. I'm thinking 1 or 2 Intel Optane type modules for VRAM supplementation directly on the video card as probably the best solution here.
Anecdotal comment - I still use a 16GB Intel Optane drive in an external enclosure to make Windows 10 or 11 installation media. It's a much faster and reliable solution than a regular USB drive, and there's plenty of space left over currently for a drivers and programs installation folder on the same drive. Just install the OS and then immediately access the drive to install drivers and a few programs. Doing it this way and using Rufus to automatically get past all the privacy and login making questions makes the whole process take like 30 minutes. I definitely don't miss the days of booting from a floppy drive and then installing from optical media. ;)
19,203
Which external enclosure please? I had two and both crapped out with the 64GB Optane drive I snagged for $50 used (maybe it pulls too much current or gets too hot).
Also, turn the Optane drive into a Ventoy drive. Then just drop ISO and voila! I can't believe it's so simple!
Reactions: Ranulf
Golgatha
12,424
1,110
Been using these for years. Bought 2 different colors so I know which drive is which (I have a 2TB for backups in the other enclosure).
Golgatha
12,424
1,110
Actually I bought the same for NVME drive data removal, etc. Has worked every time I needed it to.
Yes, I've installed and uninstalled NVME drives dozens of times from these enclosures. The installation screw is metal and the mounting nut is brass. A lot of these external enclosures have rubber or plastic installation hardware and they're good for less than a handful of swaps. I would say I've swapped drives out of these dozens of times and they still work great.
Very fast for swapping during a laptop image for example. You image the laptop drive to the drive in the external enclosure and then the enclosure becomes a nice storage spot for the drive coming out of the laptop. Once the laptop is verified working correctly, that's the time you use diskpart to prep the drive in the enclosure for something else. My most recent usage was consolidating 2x2TB NVME to a single 4TB drive (#2 setup in my signature), so the same process on my desktop as compared to a laptop....annnnd to tie all this together, the reason I consolidated drives is because NVME #3 shares bandwidth with the bottom PCIe 16x slot where the 3050 6GB now resides, AND 6GB OF VRAM IS NOT ENOUGH (UNLESS YOU'RE USING IT FOR DEDICATED PHYSX, THEN IT'S ENOUGH)!!!
MrPickins
792
If you're going so far as all that, why not just add another ram socket on the card or motherboard for additional vram? It would be worlds faster for both reads and writes, both in bandwidth and latency.
Edit: I was thinking user-upgradable. If you're thinking soldered on, I could see that. Just a large SLC level of cache for the GPU.
Reactions: Golgatha
Status
