Page 133 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Status
Not open for further replies.
BFG10K
22,709
3,005
This thread was started in mid 2021 and is being retired/locked. As the OP is no longer active, or updating and maintaining it.
Mod DAPUNISHER
8GB
10GB / 12GB
  1. It's the player's fault.
  2. It's the reviewer's fault.
  4. It's AMD's fault.
  5. It's the game's fault.
  6. It's the driver's fault.
  9. Wrong area was tested.
  10. Wrong games were tested.
  11. 4K is irrelevant.
  16. It's an anomaly.
  17. It's a console port.
poke01
4,606
5,916
Been looking at a few benchmarks of KCD II, why do AMD cards perform so poorly in that game?
Its not NV sponsered at all.
Did AMD release a driver update for this game?
Some AMD users have the same question
Edit: looks like both NV and Intel released a driver update for this game on the 30th Jan.
poke01
4,606
5,916
I believe a good part of the problem is the raytracing bloat that devs have been adopting as per Nvidia's "request" and marketing co-sponsorship, as the BVH tree occupies quite a bit of VRAM by itself.
you forget where games are made for consoles first and RT is mandatory on consoles too for games like Indy.
The funniest thing is that Nvidia is now promoting neural-network generated textures to save VRAM space
again AMD is also doing the same thing if you bother to read their GPUOpen papers
Nvidia-only solution (neural textures)
Intel and AMD have their own solutions for this...
Hans Gruber
2,534
1,363
12GB should be dead in 2025 and 8GB needs to packed and sent to Jensens behind.
Based on the spot price of Vram. I agree. Just remember, manufacturers are paying significantly less for vram than the spot price market. 16GB should have been the minimum and Vram should have been 64GB on cards like the 5090.
poke01
4,606
5,916
The game is Crytek engine and apparently AMD cards have had issues with it for awhile.
All the more reason for AMD to focus on the driver for this game.
It’s kinda sad to see, cause I thought we finally had an engine that worked well on all GPUs. Hopefully, AMD works to improve their support as this game is selling well.
Reactions: marees
marees
2,038
2,671
Maybe the RDNA 4 drivers will fix this (including older RDNA 3 cards too )
marees
2,038
2,671
I dislike the amount of truth in the statement about poor optimization though. It is probably the strongest defense the "losing side" offers. I am playing Rise of the Tomb Raider, and the game looks and plays amazing for how little vram is uses. Something certainly went wrong somewhere. Hell, look at how well Kingdom Come Deliverance 2 runs on 8GB cards.
I believe that game uses (Voxel) Cone Tracing rather than (Pixel) Ray Tracing
Not sure if that contributes to lower VRAM usage. Maybe they use other such tricks to optimize VRAM
DAPUNISHER
32,267
33,018
4060 vs 7600XT
He does not emphasize you can keep the textures maxed on the 16GB card, or spend any time comparing the difference that can make in those titles. Since he kept optimizing for a 60fps target, why not spend more time on frame generation? At 60fps in all of those single player titles you can apply it. Oh that's right, the 4060 can't use it without upscaling from an absurdly low internal resolution.
19,203
Reposting a lovely example of using the wrong "settings":
If only the moronic reviewer had used the 4060 the way it was meant to be used. How else can anyone explain a card with less RAM bandwidth and lower GPU frequency from two generations ago, beating the 4060 to a pulp? It can't be anything else other than the wrong settings used, can it? (imagine an orangutan scratching its head)
marees
2,038
2,671
the measured behaviour is sufficient for us to simply not recommend this game to anyone with a graphics card with 8GB of VRAM or less. Having to decide between high textures that cause stutters while looking sub-par and medium textures that look even worse, neither is a choice we can particularly recommend.
To sum up, lower-end graphics cards with lower VRAM allocations should avoid Monster Hunter Wilds until these issues are rectified. Higher-end hardware can brute-force the game's shortcomings to some degree, but it's still hard to recommend such a flawed technical outing - or even derive optimised settings.
DAPUNISHER
32,267
33,018
^ Steam survey is fake news. One month Chinese jumped 25% as a language, and that same month the RTX 3060 jumped to 10% of all users. They "corrected" it but far from the first time those "errors" have happened.
DAPUNISHER
32,267
33,018
LMAO has to be the gaming cafe distortion again. Chinese jumped almost 21%.
Status
