Page 134 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Status
Not open for further replies.
BFG10K
22,709
3,005
This thread was started in mid 2021 and is being retired/locked. As the OP is no longer active, or updating and maintaining it.
Mod DAPUNISHER
8GB
10GB / 12GB
  1. It's the player's fault.
  2. It's the reviewer's fault.
  4. It's AMD's fault.
  5. It's the game's fault.
  6. It's the driver's fault.
  9. Wrong area was tested.
  10. Wrong games were tested.
  11. 4K is irrelevant.
  16. It's an anomaly.
  17. It's a console port.
poke01
4,608
5,917
GTA V: Enhanced looks great. But look at the VRAM used at max settings at 1440p. Its 8.80GB used.
Whatever 8GB cards NV or AMD release this year, those cards cannot play this game at maxed out settings.
Ranulf
2,896
2,558
Meh, from what I've read on Steam, the endhanced gta5 is a mess even if you're lucky and they let you convert your account/character to the new version. I'm not going near it for at least another few weeks till they work out any bugs if ever, since its Rockstar. I also don't want to have two versions of the game installed which seems the prudent thing at the moment.
Given that my old 4790k and 2060S can run gta5 original at 60fps locked without breaking a sweat, that screenshot doesn't do much for me. Glossy paint on the suv looks the same and nicer puddles is a big whoop dee doo.
DAPUNISHER
32,273
33,045
GTA 5 Enhanced is running silky smooth an issue free on my 7800X3D+7900XTX. It looks a lot better than the OG, and FSR native AA and DLAA support are nice additions. It is a significantly smaller install at under 100GB. The old one was a bloated mess. I am doing a playthrough now.
Ranulf
2,896
2,558
The old one used to be 80GB in 2015, give it a couple of years and it will hit 100GB easy.
DAPUNISHER
32,273
33,045
And? That's a problem for future us. ;) For now it's about 30GB less than the OG was when I nuked it. In addition I get way faster load times, ray tracing, better AA, and a better looking game overall.
GodisanAtheist
8,438
9,845
Looks like it's a poster child for "The way it's meant to be remastered" :)
-NGL there are a lot of older games out there that really just need their lighting model updated to look like they'd been released in the last couple years.
If it can be done without outrageous overhead and shutting out a ton of the market, I say let them do it.
biostud
20,011
7,101
A bit off-topic but is nVidia still the go-to, if you want to stream your gaming sessions?
We're in entry level land so 4060(ti) 8GB or 7700XT 12GB, hopefully I can wait until the 5060(ti) 8GB launches or if AMD is ok RX 9060.
DAPUNISHER
32,273
33,045
Toasty shills tested these 2
AV1 will make the differences in quality even less notable. The extra VRAM and performance make the 7700XT a better value here in the U.S.
biostud
20,011
7,101
Thx, I've searched and searched and couldn't find anything newer than 6600 and 3060.
For pure gaming I would also go with the 7700XT because of the better value, but I was not sure about the streaming.
19,203
People claiming they lose perfomance after patch, especially RTX 4xxx
Probably Nvidia engineers "helpfully" told them some "trick" to improve RTX 5000 series performance which when used, causes their driver to tank RTX 4000 performance artificially.
poke01
4,608
5,917
Or it’s way more likely that the devs stop stuffed up. Not everything is a conspiracy.
It looks like they optimised for RDNA4 and Blackwell. But gave no care to RDNA3 and Ada. PC gaming is annoying
Edit: that is a big drop, so these devs test anything anymore???
Status
