7800 GT or.....X1800 XL ?
Munky
9,372
Originally posted by: Crescent13
7800GT EVGA. I have it. Voltmodded it and OC'ed it to 505/1180 for a score of 8200 in 3dmark05 :D
P.S. 7800GT also has Transparency Supersampling AA.
Meh. My friend with a 7800gt got it to 500mhz without voltmods.
And ever heard of AAA?
Alaa
839
8
Originally posted by: munky
Originally posted by: Alaa
7800GT is better in most cases even with AA, so EVGA 7800GT is recommended
BUUUUZZZ!!! Wrong! Did you bother looking at the benches I linked?
ur WRONG! go to AT's review, 7800GT is winning almost every bench with 4xAA and when it loses its only 2-5 fps for the X1800XLAT's review
Munky
9,372
Your article: October 7th, 2005
My article: January 24, 2006
Nuff said.
*edit: fixed dates
Elfear
7,169
829
My article: January 30, 2006
Nuff said.
Lol. Come on people, don't you read more recent reviews.
TheRyuu
5,479
14
First off, just say screw it and get the 7800GT. :p
Second, I'd get the 7800GT (or two of them :p), for some reasons I can't think of right now.
Look here 7800GT beats the X1800XL in almost every benchmark (only loses one and I think thats Half-Life 2? but thats typical)
EDIT: Evga is the cardmaker to get 516 or the 518 with the free mobo if you need one.
RussianSensation
19,458
765
Alaa
839
8
Nuff said.
*edit: fixed dates
just like ATi has updated the card since that time!! NO its the same card and it lost so stop being a fanboy cuz i wanted to get that card and i wasnt convinced by its performance..
Munky
9,372
Nuff said.
*edit: fixed dates
Did you ever think about newer driver increasing performance? That review did more thorough testing and analysis that most other sites would even imagine doing, so dont start the fanboy argument, cause the door swings both ways...
SickBeast
14,377
19
Nuff said.
*edit: fixed dates
Actually the newer cores supposedly overclock much better, plus its drivers have matured.
Elfear
7,169
829
Lol. Give me a break. Of course it's the same card (although like Sickbeast mentioned possibly better cores) but drivers do mature. If you look at SLI benchmarks when that technology first came out and SLI benchmarks now you'll see a big difference. What happened?? Did the cards get switched around for better-performing ones?? Nope. Drivers got better.
Cookie Monster
5,161
32
86
Since you ordered the GT.. i dont see the point cancelling it in favor of the XL. The XL may have some advantages but its not enough to cancel your order.
OP also noted that he will not be OCing.
Alaa
839
8
i just dont know when newest drivers came out so am just talking based on the review i really want to try X1800XL but even if its performance have been improved i think that it should be priced like the 7800GT.
MUNKY what door are u talking about? ur house?ok if u want to fix it then..am not the one to ask!
JPB
4,064
89
Well, now ive narrowed down to what Gt if that is the one. The CO......What's the difference from the CO and the OC versions'? From what I see....the CO runs with the GTX. The X1800 is $319 and the 7800 GT co is $314......hmmmm...makes it harder now since same price... ...
Edit: I plan to use AA/AF alot.....
Edit # 2...I need a PSU upgrade....what is minimum for these cards....?
djnsmith7
2,612
I have the BFG 7800 GT OC card & play BF2 & FEAR with it...Both games are phenomenal with this card...I run my card @ stock settings w/ stock cooling...You can't go wrong with this card...I upgraded from an X800XL & the differences are obvious...
supastar1568
910
Originally posted by: Matt2
Originally posted by: x80064
Originally posted by: Slitherythesnake
I'd go with the 7800 GT since it can OC to 7800 GTX performance levels fairly easily whereas the X1800XL needs some voltage tweaks to get it up to X1800XT performance levels. As Cookie Monster pointed out, AOE3 runs much better on the 7800 GT and overall it is a bit faster than the X1800XL. Still, both are good choices.
Edit- Go with the evga 7800 GT CO edition.
I don't plan on overclocking which ever card I get....so that don't matter to me. I just like the stock performance which from either card should be great. One thing though, if the GT has the slight performance over the XL ? How come the XL scores more in 3D Mark ? I don't use those programs though. Just seen them on website's. The XL right now for Connect 3D is $319 at the Egg. The GT is $20 cheaper..
If stock is what you're shooting for, look for the EVGA 7800GT CO SE (part # 516). It's $20 less than the regular CO because supposedly its clocke dlower, but my CO SE came stock 470/1100, CO speeds. The CO is hands down a better deal than the X1800XL if you dont plan to overclock.
X1800XL scores higher than the 7800GT in 3DM05, but in 3DM06, ATI cards get raped by Nvidia cards. a single GT scores almost as high as a X1800XT, likewise, GT SLI scores almost the same as X1800XT Crossfire.
yea, what he said. Except mine is on roids and came stock at 475/1110
Pete
4,953
I'd go for the GT: slightly faster overall (much moreso in AoE3) and cheaper. I'm not sure what the problem is with the GT CO costing as much as the XL. If the plain GT runs with the XL, but the GT CO runs with the GTX while still costing only as much as an XL, then the GT CO seems like a no-brainer.
"[A]t least at 1600 resolution?" Not with a GT or XL in new games like FEAR or CoD2, according to most or all benchmarks. Well, not unless you like FPS gaming at 30fps, or you're willing to sacrifice some in-game IQ settings (like shadows, etc.). 1280 is probably a more realistic res for AA+AF with a GT or XL.
Is SLI in your future, or are you sticking with single cards? I'd recommend at least a quality 430W PSU with a PCI-E 6-pin connector at a minimum.
JPB
4,064
89
Here is the XL.... http://www.newegg.com/Product/Product.asp?Item=N82E16814142053
Here is the GT co http://www.newegg.com/Product/Product.asp?Item=N82E16814130249
Well, Right now I can play COD 2 at 1280 with my X800 Pro with some AA/AF ( not alot..but some )...with no slow down what so ever. Certainly it should be better on either of these 2 cards
SLI or CrossFire...( not sure yet..will depend on which card I go with ) could be in the near future. But for now...Just need a good quality PSU for a single card. Can upgrade again for dual card's later. Maybe like in June or so. Right now im using a 218 watt that came with a HP from WalMart because my Thermaltake 480 just up and quit. Can you reccomend one with good amps on the +12 rail ? Was lookin to stay under $100 on PSU...
Edit: Which card is louder.....run's cooler....?
NoStateofMind
9,711
Out of those I would go OCZ. But also check out fortron source and Xclio. They don't have the "Big name" but IIRC they make PSU's for those "big name" companies. Enjoy! :)
JPB
4,064
89
Anyone know of any real good benchmarks of the 7800 GT co ?
Decided on the OCZ psu
Edit: Before I hit the cancel button, and order the GT co.....is there any features...( not relating to core and memory ) that the X1800 XL has the the GT doesnt' ?
Blastman
1,758
The X1800?s can do HDR (openEXR) and AA (the 7800?s can?t). The X1800?s also have a higher quality (non-angle dependent) AF that can be switched on that is better than anything NV has.
The 7800?s have bad texture shimmering in many games -- poor image quality. You can get rid if this ?somewhat? by running in HQ (note - the cards are benched only Q mode) but you will be taking a 10-15% hit in performance. So I would put the 7800GT slower than an X800 XL if you are going to be running it in HQ mode.
Munky
9,372
The 7800?s have bad texture shimmering in many games -- poor image quality. You can get rid if this ?somewhat? by running in HQ (note - the cards are benched only Q mode) but you will be taking a 10-15% hit in performance. So I would put the 7800GT slower than an X1800 XL if you are going to be running it in HQ mode.
That article I linked to also used HQ mode on Nv cards to reduce shimmering. That would explain why the x800xl came out a bit faster on average than the 6800gt, contrary to the popular myth from last year. Also gives a perspective on the 7800gt performance. Anyway, the op already decided on the 7800gt, and you cant go wrong with either at those prices.
