Yet you didn't even post what laptop you have. I call shenanigans.
Even if your computer can do it, no other screen can do 4:1.
I'm betting it's a Yoga 2
Just IMO. I'd rather pay more for quality. Especially where with my work, the IPS or IZGO quality matters. Unfrotunately, IZGO/IPS 4k isn't at a price point that i'm okay with. Yet. But i'm sure that will change with time. Bottom line is you get what you pay for with the 600$ 4k panels. I think i'll wait for something I can appreciate more, when those IPS/IZGO hit sub 1000$ price levels, count me in. IZGO is also similar to TN in terms of response times, IZGO is technically capable of lightboost just like TN is. But it is incredibly expensive, so they're now being marketed more along the lines of professional use. However, once IZGO lowers in price...watch out. They're going to be insanely good IMO, especially for gaming. 🙂
Precision m3800
No, iGZO is not as good an TN for response times. I had my U2713HM for a year before I switched to the 950D and I can tell you the IPS panel looked much better. The Samsung, wasn't bad bud it was no comparison. The 950D though was much much faster. my K/D in BF4 rocketed up. Aiming was much better. So whenever my 590D gets here and if it's anywhere as fast as as my 950D iGZO will have to come a lot closer before I consider it as gaming is primary.
From the one thorough review the 590D is excellent for a TN monitor. It's even holds it's own against PLS/IPS panels in that review. It's only downfall being contrast ratio. All else being very good
ofcourse if there was an iGZO panel with a 1ms response time and very little input lag for less than U$1000 than great, but alas there will always be compromises. So you can't pre-judge someline like the 590D or the Asus monitor with the same panel with comments like "you get what you pay for".
I was arguiging with a friend over 4k resolution. I claimed that you can use a 4k monitor , as a 1080p monitor too, and it would be as good as a native 1080p monitor . Because all 4k monitor have to do is ,to map 4 pixels to 1 pixels colour data. No resizing is necessary.
He claimed that lcd monitors only work at native resolutions ,and if we try a 4k monitor at 1080p, it would be all blurry.
Which one is true?
It doesn't look as good
Would you agree it can depend on what 4K display you are using, and what 1080p display you are using?
Or is it categorically that all 4K displays will not look as good as an equal-sized 1080p display, when they both are showing 1080p content?
So, I can confirm the 590D do not look very good running at 1080p. Looks worse than my 950D even if it is an inch smaller. Seems like it doesn't scale right.
I imagine the idea behind getting a 4k monitor, but wanting to know of 1080p looks good is the 4K is for the desktop and easier to run games, with 1080p being a fall back on really demanding games.It's only been a few weeks. I would hope that someone isn't buying a 4k monitor for the sole purposes of 2k gaming. Might as well also build a server with a Xeon chip just to play Space Quest 2.
Does it give any options, like something that might affect how it scales and/or interpolates, when you scroll through the on-screen menu? Like, does it have a game mode, vs. an internet/photo mode?
That isn't amazing at all. CRT's don't have a fixed grid of pixels. They just changed their frequency and the monitors showed resolution as it is. CRT's do not have native resolutions, and gamers of the time often choose resolutions like you'd adjust any other setting. Picking the best one for the GPU power you had.results is only as good as the scaler.
amazing how old school crt scaled perfectly.
SC1 with standard 640x480 resolution scaled look exactly the same on a 1920x1440 21" ViewSonic PF815.
