3DPM: Can we fix it? Yes we can!
511
5,495
4,897
AMD maybe (assuming it's free) but I think Intel doesn't give away its tools for free?
Intel's tool are mostly free and well supported where do you get the impression Intel dev tools would be paid in fact they are the best tool's for anything related to x86 AMDs don't even come close.
19,218
I haven't checked recently but 25 years ago, their compiler cost $400.
Schmide
5,788
1,093
Realize. This is different in the way it's outputting the data to an array. I didn't see the code before. Sorry about that. (note: Not my coding style just told it what to do)
Code:
// 3dpm3.cpp : Defines the entry point for the application.
#define _USE_MATH_DEFINES
#include <stdio.h>
#include <time.h>
#include <thread>
#include <chrono>
#include <iostream>
#include <math.h>
#include <algorithm>
#include <string>
#include <bit>
#include <random>
#include <vector>
#include <immintrin.h>
using namespace std;
// Fills 'buffer' with 'count' random normalized 4D vectors (x, y, z, w=1).
void fill_with_random_vectors(double* buffer, size_t count, bool singleThread) {
    unsigned int numThreads = singleThread ? 1 : std::thread::hardware_concurrency();
    if (numThreads == 0) numThreads = 4;
    std::vector<std::thread> threads(singleThread ? 0 : numThreads);
    auto worker = [buffer, count, numThreads](unsigned int threadId) {
        std::random_device rd;
        std::mt19937 gen(rd() + threadId);
        std::uniform_real_distribution<double> dist(-1.0, 1.0);
        size_t chunkSize = count / numThreads;
        size_t start = threadId * chunkSize;
        size_t end = (threadId == numThreads - 1) ? count : start + chunkSize;
        for (size_t i = start; i < end; ++i) {
            double x = dist(gen);
            double y = dist(gen);
            double z = dist(gen);
            double mag = std::sqrt(x * x + y * y + z * z);
            if (mag > 1e-8) {
                double invMag = 1.0 / mag;
                buffer[i * 4 + 0] = x * invMag;
                buffer[i * 4 + 1] = y * invMag;
                buffer[i * 4 + 2] = z * invMag;
                buffer[i * 4 + 3] = 1.0;
            } else {
                buffer[i * 4 + 0] = 1.0;
                buffer[i * 4 + 1] = 0.0;
                buffer[i * 4 + 2] = 0.0;
    if (singleThread) {
        worker(0);
    } else {
        for (unsigned int t = 0; t < numThreads; ++t) {
            threads[t] = std::thread(worker, t);
        for (auto& th : threads) {
            th.join();
// AVX-accelerated version: normalization uses AVX intrinsics and reciprocal
void fill_with_random_vectors_avx(double* buffer, size_t count, bool singleThread) {
        size_t i = start;
        for (; i + 3 < end; i += 4) {
            double x[4], y[4], z[4];
            for (int k = 0; k < 4; ++k) {
                x[k] = dist(gen);
                y[k] = dist(gen);
                z[k] = dist(gen);
            __m256d vx = _mm256_loadu_pd(x);
            __m256d vy = _mm256_loadu_pd(y);
            __m256d vz = _mm256_loadu_pd(z);
            __m256d xx = _mm256_mul_pd(vx, vx);
            __m256d yy = _mm256_mul_pd(vy, vy);
            __m256d zz = _mm256_mul_pd(vz, vz);
            __m256d sum = _mm256_add_pd(xx, _mm256_add_pd(yy, zz));
            __m256d mag = _mm256_sqrt_pd(sum);
            __m256d eps = _mm256_set1_pd(1e-8);
            __m256d mask = _mm256_cmp_pd(mag, eps, _CMP_GT_OQ);
            __m256d invMag = _mm256_div_pd(_mm256_set1_pd(1.0), mag);
            __m256d rx = _mm256_mul_pd(vx, invMag);
            __m256d ry = _mm256_mul_pd(vy, invMag);
            __m256d rz = _mm256_mul_pd(vz, invMag);
            double fallback[4] = { 1.0, 1.0, 1.0, 1.0 };
            double zero[4] = { 0.0, 0.0, 0.0, 0.0 };
            __m256d fx = _mm256_loadu_pd(fallback);
            __m256d fy = _mm256_loadu_pd(zero);
            __m256d fz = _mm256_loadu_pd(zero);
            rx = _mm256_blendv_pd(fx, rx, mask);
            ry = _mm256_blendv_pd(fy, ry, mask);
            rz = _mm256_blendv_pd(fz, rz, mask);
            double outx[4], outy[4], outz[4];
            _mm256_storeu_pd(outx, rx);
            _mm256_storeu_pd(outy, ry);
            _mm256_storeu_pd(outz, rz);
                buffer[(i + k) * 4 + 0] = outx[k];
                buffer[(i + k) * 4 + 1] = outy[k];
                buffer[(i + k) * 4 + 2] = outz[k];
                buffer[(i + k) * 4 + 3] = 1.0;
        for (; i < end; ++i) {
            if (mag > 1e-8) {
            } else {
    if (singleThread) {
        worker(0);
    } else {
            th.join();
// AVX-512-accelerated version: normalization uses AVX-512 intrinsics and reciprocal
void fill_with_random_vectors_avx512(double* buffer, size_t count, bool singleThread) {
        size_t i = start;
        for (; i + 7 < end; i += 8) {
            double x[8], y[8], z[8];
            for (int k = 0; k < 8; ++k) {
                x[k] = dist(gen);
                y[k] = dist(gen);
                z[k] = dist(gen);
            __m512d vx = _mm512_loadu_pd(x);
            __m512d vy = _mm512_loadu_pd(y);
            __m512d vz = _mm512_loadu_pd(z);
            __m512d xx = _mm512_mul_pd(vx, vx);
            __m512d yy = _mm512_mul_pd(vy, vy);
            __m512d zz = _mm512_mul_pd(vz, vz);
            __m512d sum = _mm512_add_pd(xx, _mm512_add_pd(yy, zz));
            __m512d mag = _mm512_sqrt_pd(sum);
            __m512d eps = _mm512_set1_pd(1e-8);
            __mmask8 mask = _mm512_cmp_pd_mask(mag, eps, _CMP_GT_OQ);
            __m512d invMag = _mm512_div_pd(_mm512_set1_pd(1.0), mag);
            __m512d rx = _mm512_mul_pd(vx, invMag);
            __m512d ry = _mm512_mul_pd(vy, invMag);
            __m512d rz = _mm512_mul_pd(vz, invMag);
            __m512d fx = _mm512_set1_pd(1.0);
            __m512d fy = _mm512_set1_pd(0.0);
            __m512d fz = _mm512_set1_pd(0.0);
            rx = _mm512_mask_blend_pd(mask, fx, rx);
            ry = _mm512_mask_blend_pd(mask, fy, ry);
            rz = _mm512_mask_blend_pd(mask, fz, rz);
            double outx[8], outy[8], outz[8];
            _mm512_storeu_pd(outx, rx);
            _mm512_storeu_pd(outy, ry);
            _mm512_storeu_pd(outz, rz);
            if (mag > 1e-8) {
            } else {
    if (singleThread) {
        worker(0);
    } else {
            th.join();
// No normalization, just random values
void fill_with_random_vectors_no_normalization(double* buffer, size_t count, bool singleThread) {
            buffer[i * 4 + 0] = dist(gen);
            buffer[i * 4 + 1] = dist(gen);
            buffer[i * 4 + 2] = dist(gen);
    if (singleThread) {
        worker(0);
    } else {
            th.join();
// Fixed vector (0, 1, 2, 1)
void fill_with_fixed_vectors(double* buffer, size_t count, bool singleThread) {
            buffer[i * 4 + 0] = 0.0;
            buffer[i * 4 + 1] = 1.0;
            buffer[i * 4 + 2] = 2.0;
    if (singleThread) {
        worker(0);
    } else {
            th.join();
int main()
    const size_t vectorCount = 1 << 27; // 134,217,728, a power of 2
    double* vectors = new double[vectorCount * 4]; // 4 components per vector
    // Test all routines in both single-threaded and multi-threaded modes
    for (int singleThread = 0; singleThread <= 1; ++singleThread) {
        std::cout << (singleThread ? "[Single-threaded]" : "[Multi-threaded]") << std::endl;
        auto start = std::chrono::high_resolution_clock::now();
        fill_with_random_vectors(vectors, vectorCount, singleThread);
        auto end = std::chrono::high_resolution_clock::now();
        std::chrono::duration<double, std::milli> elapsed = end - start;
        std::cout << "[Standard] Generated " << vectorCount << " random normalized vectors in "
            << elapsed.count() << " ms." << std::endl;
        for (size_t i = 0; i < std::min(vectorCount, size_t(5)); ++i) {
            std::cout << "Vector " << i << ": ("
                << vectors[i * 4 + 0] << ", "
                << vectors[i * 4 + 1] << ", "
                << vectors[i * 4 + 2] << ", "
                << vectors[i * 4 + 3] << ")" << std::endl;
        fill_with_random_vectors_avx(vectors, vectorCount, singleThread);
        std::cout << "[AVX] Generated " << vectorCount << " random normalized vectors in "
        fill_with_random_vectors_avx512(vectors, vectorCount, singleThread);
        std::cout << "[AVX-512] Generated " << vectorCount << " random normalized vectors in "
        fill_with_random_vectors_no_normalization(vectors, vectorCount, singleThread);
        std::cout << "[No Normalization] Generated " << vectorCount << " random vectors in "
        fill_with_fixed_vectors(vectors, vectorCount, singleThread);
        std::cout << "[Fixed] Generated " << vectorCount << " fixed vectors in "
    delete[] vectors;
    return 0;
  • Love
19,218
It's a big nothing. Are we sharing? I don't want to be the only one.
Share something from my side? I haven't written anything. I can't anyway. That's why my bench tool says special thanks to you :)
I can share the rudi code with you privately if you prefer.
Schmide
5,788
1,093
Little side note. I've been very impressed with Github Copilot. I checked out a few AIs asking them the same general questions about bit reversal routines. (non paid versions) Github Copilot basically completed my tests and was a joy to bounce ideas back and forth with. After that I paid for a year and let it see my codebase. It tried really hard and although a bit overeager to push avx512 on code that I don't think it understood the implications it seemed to get it when I pushed back. (not real person)
I did the same for ChatGPT and it did horrible. My phrasing of the original question may have led it in the wrong direction after correcting its path it overestimated its abilities and pushed wrong and troublesome answers. After pushing it to work on a famous bit reversal algorithm from Dr Dobbs. It produced a similar algorithm. I asked it the optimize it and it showed an optimization with output. It looked like something that I hadn't thought would work and I couldn't exactly understand how it worked. Well I tested it and it didn't work. It hallucinated and didn't check its work. I called it out and it apologized. I did a couple more tests as it kept pushing for avx optimizations. I asked it to do one and it failed again producing a version that not only returned to the original wrong path, but didn't even complete that path correctly.
Claude did ok but it's window I guess for free versions was too small and it kept putting out python.
Didn't really check out any more. (joke) Grok kept inverting my z values for some reason.
Schmide
5,788
1,093
^ Funny thing is I didn't even really notice the python, just seemed like a coding style.
