You're looking at this all wrong.
Maybe I am. But I've only written about my point of view. Obviously you (and others) don't agree and that's fine. I really like the new miata from an aesthetic point of view. I love that they kept the weight down. And I think that they are 90% there. I also expect that the 155/148 number isn't really the final output number and we'll see something better. Quite frankly I don't think that the US spec car will weigh 2200lbs either. Until they publish official weight specs for the 2.0L US spec car we won't know.
First, yes, a 2.0L NA engine can make plenty more than 155hp. Now consider what else has to change to support the extra power: heavier pistons, heavier rods, a heavier crank, a heavier cooling system, a heavier fuel system to maintain range, heavier exhaust system to support the extra flow, heavier transmission to support the higher torque, heavier drive shafts to get that torque to the wheels, heavier hubs, heavier wheels. Now that the whole driveline, engine, fueling, and cooling systems are heavier guess what else needs to be beefed up? The brakes, the crash structures, the suspension springs/dampers/sway bars, etc. It's called weight compounding (or de-compounding if a vehicle is losing weight) and one cannot make a change to a vehicle without considering it.
While the above has some truth to it, you assume that every component of the unreleased car would have to be strengthened to maintain acceptable durability for the end user. There are obviously considerations that need to be made for any increase in power; however, what I've proposed is a relatively modest bump.
It's unlikely that the rotating assembly would need much of any tweaking to produce 175-185hp. Even if it did, the weight gain would be minimal to the car as a whole. Generally the manufacturer builds quite a bit more leeway into their design. That being said, the skyactiv engines are definitely built for efficiency first.
There is no reason to expect any gain in the weight of the fuel system (both tank and delivery) or exhaust system. A slightly higher output engine isn't going to drastically change the range of the car to the point where a bigger fuel tank is warranted. Larger CC injectors and a bigger fuel pump (highly unlikely that they would even be needed) shouldn't have an appreciable difference in weight.
Cooling system might gain a few lbs (read: 5 or so) if they increased the radiator size (which would also increase the coolant volume) slightly. May or may not be needed based on what the existing car has.
It's also unlikely that the driveline would need any significant increase in weight to handle the extra power. I wouldn't expect that there would be much extra torque (if any) on the low end which would be the biggest reason to warrant it (remember we aren't talking about adding a factory turbo here). This isn't a V8 swap, or even a turbo application, it's a case for a slightly higher output N/A motor. Some tweaks needed... yeah sure... but not tons of added weight here.
Brakes... yup... larger brakes would be warranted. Lets say 1lb per corner. This is a small car regardless of power, and on meeh level street tires it probably doesn't need a ton more than slightly larger rotors.
Can't see any reason the crash structure would need to change given that the weight change is next to nothing.
Suspension tweaks would be warranted for the extra power, but contribute virtually no additional weight. Springs of different weights weigh close enough to the same thing. A slightly thicker sway bars might add a pound each front/rear.
One cannot just ignore money - the higher cost will eliminate a large part of this car's market. It will cost a lot more than a 10% bump to the base price to realize a 20% power increase at the same durability and weight.
I'm not ignoring money, but I don't think that a small (even optional) increase in price is going to kill sales (primary because this is a sports car and not something that typically own for their only car).
They already did this once in 2004. The whole assembly (turbo+intercooler+piping+all the additional tweaks that you mentioned) added up to just under 90lbs of additional weight (when comparing the mazda speed verson of the 2004 MX-5 to the equivalent base car). That's saying a lot, because a turbo and intercooler setup alone is a significant portion of that. The cost? under a grand compared to a similarly equipped MX-5 (numbers from the car and driver review). So that is roughly 25% more power for roughly 3.2% moar monies. It also had a >40% take rate.
If they gave us 185 hp (20% more power with basic suspension and brake mods) for 10% moar monies in 2016, every major US magazine, reviewer, and miata owner would be sucking Mazda off so hard it wouldn't even be funny. Can you imagine if they did it for less? FWIW, no one would give a shit if it was 2250lbs instead of 2200lbs.
One cannot just say 'oh, all it needs is a tune' because that is not true - the added stresses on the vehicles sub-systems will remove the durable care-free nature of the Miata, which many people appreciate. Not to mention to inevitable increase in warranty claims.
See above. Also if designed right from the beginning, all engines could utilize a very similar drive line.
It's fine to not like it, plenty of people do, and it's certainly not perfect. The Miata doesn't have a chip on it's shoulder though, only its critics do. With it's (literal and figurative) track record I can't understand how people can say "it needs X" or "it needs Y." What they are REALLY saying is: "I want X and I want Y, why doesn't Mazda tailor their cars to be exactly what I want!?" It's whiny, annoying, and ignorant. If you don't like it, don't buy one. The Miata will continue to be the longest-standing, most prolific roadster ever made in addition to being the most-raced car made by the most-raced brand.
I do like the miata. I'd like to see it be better. No one "needs" a miata. Owning a miata is a "want." If you "need" a car for transportation, get a yaris or something similar. Even more reliable / economical than the miata and like what... 10 grand less?
I (obviously) really like the Miata. This is for one very important reason: it's one of the few cars in the last few decades to be designed by a vision and not by a committee. It does what it does better than any other car ever made. Despite the many criticisms leveled against the Miata its designers have never strayed from their vision: an accessible, affordable, super-light and simple driver's car that's fun at any speed.
Agreed.
