1900XTX not performing...
Originally posted by: josh6079
Thread title should be changed from "1900XTX not performing..." to "akshayt not performing..."
Besides, why would he say it's the X1900XTX's fault if it works completely fine in another rig?
:laugh:
Here's my two-bits worth: I think the PSU is overheating, causing it to throttle down.
I had this problem with my X1900 and Antec TruePower 550W. After I increased the case fan speed, the flickering went away.
It happened again after I installed a new HDD. One of the cables kept the fan from turning.
please wait for me, i will come back after trying many things.
I will tell the results to you.
1)Till then please tell me how to disable FW, it is not in my BIOS?
2)Should I try warcat drivers?
3)What page file should I keep?
Instead of trying to do fifty things at once and get nowhere...why don't go through your PC and test each part one by one until you find the problem.
If after testing it's still mucks up then go through each setting one by one and so on.
Ten times easier to do then making multiple changes at once and chasing your tail around in circles
I will be trying some imp things like a 6600GT on my comp, I will get back.
One thing I have noticed is that ocing makes more FPS, also helps in some areas, but also gives a smoothness hit in some areas, any way about it?
Do not overclock you computer until you find the results of what you said you were going to test🙂
One of them:
Using onboard audio
I think the problem with your setup is that you start tweaking before you get things stable. THAT IS THE ISSUE! Leave everything at stock Go into the bios and select optimal defaults. Test from that. If it's not smooth and it still stutters, don't overclock as your problem is related to something else. Example, "I overclocked and it was better but much worse" or something to that affect🙂. Either you expect to much and/or you machine is not configured properly.
Also do not use 3rd party drivers until you have things stable.
The biggest problem I see is not the hardware it's the person using it. I get the vibe that you want the "console experience" as in plug it in and it works. If you wanted that you may have been better off going with a Dell or a console as many people recommended already. Honestly everyone needs to start somewhere but you need to stick with stock until you know what your doing.
In my opinon I think you are expecting a little to much in combo with your machine not configured properly. Your video card is on the high side but the rest of your machine is on the mid end (1GB memory and a 3200 is not what I consider high end). Example, some games you say are running ok (still not acceptable) with no AA but other games you are running it with 6AA and have the same opinion. How is the game at 2*AA? Which leaves me under the impression if the game ran good at 1280-1024 with 4aa you would still have a problem that it doesn't run at 1600-1200. So in summary even though you have a high end card don't expect it to run with everything at 6X aa. Example I have a X1800XT 512MB card and I run company of heroes with 1280*1024 with the game AA on. That is the breaking point for me, as in any higher it runs like crap. It performed:
"Good"
AVG 36
MAX 137
Min 12.6
This is with a single core Opteron 2.7GHZ (vs your 1.8GHZ) and with 2GB (vs your 1GB).
To start out most of the games you listed have in game performance test like the one above. Example Company of Heroes, Fear, and HL2. Let us know the resolution you test it at (start with 1280-1024 no aa and progress upwards), make sure you sound options are set to low, test, and display the results. The reason of this is also due to opinion. Runs like "crap" is very subjective. So run COH and let us know the results.
Also after running each game run task manager, press ctrl+alt+del, and select performance. Note under Physical Memory (k) /Total. This your amount of memory installed. Under Commit Charge (k) look under peak, this is the amount of memory that was used at the peak. If Peak>Total then you are loosing performance due to paging and will either need to upgrade memory or reduce settings.
Good luck and people are here to help but you need to keep up your end and make sure you take the suggestions seriously. If you don't have time to test, then why should it be at the top of the forum?
When I upgraded to a 6600GT (from a Ti4200) I had a lot of problems with stuttering, and other various issues. For some reason, the 6600GT just didn't get along with my Asus A7N-266E. I tried everything, but nothing worked. I finally swapped out my nice Asus motherboard with my son's cheap-ass Biostar, and everything was fine.
So it could be a motherboard issue.
Is it possible that your mobo was fualty? Did your other cards run fine on that motherboard?
I HAVE 2GB RAM. MY CPU is running at 2.4GHz(or atleast was) so neither the CPU nor the RAM is a bottleneck.
FPS I mostly get are pretty good.
Problems are like:
UT04 running fine at 12x10 6x AA but not running fine with 6x AAA, something similar with underground 2.
I will try the 6600GT and onboard audio, I don't have the right screw driver for which I am waiting. I will be back.
kmmatney:
When I upgraded to a 6600GT (from a Ti4200) I had a lot of problems with stuttering, and other various issues. For some reason, the 6600GT just didn't get along with my Asus A7N-266E. I tried everything, but nothing worked. I finally swapped out my nice Asus motherboard with my son's cheap-ass Biostar, and everything was fine...So it could be a motherboard issue.
akshayt:
Wow...just wow.
Problems are like:
you are in no position to offer advice...you can't even get you're own PC working.
Quit while you're ahead and buy a console...you clearly suck at using PC's.
I can't identify the cmos, please tell me.
How can somebody who says this even attempt to oc their computer??? Not to mention write a blog on oc'ing...😕
ahhh yes I remember that thread and blog...I wouldn't let my worst enemy use that blog for overclocking.
I reccomend that this thread be retitled to "the OFFICIAL put sh!t on Akshayt thread"...because it pretty clear it's the only thing it's good for as he isn't using anybody's advice and still persists on b!tching that his PC doesn't work.
although I do find his latest excuse most amusing..."my screwdriver doesn't work", more like it should read "my brain doesn't work".
I will try those things later, however I come back with a useful find.
Most Wanted
Those stuttering/jerking tress don't stutter in Vista, there are occasional stutters in motion and slow downs due to low FPS in Vista, but that should hopefully be corrected as Vista advances, do you think that it was a software issue or hardware issue?
Most Wanted
duuuuuhhhh....... let's see, you changed the software and the hardware stayed the same...:disgust:
Akshayt, can you please try another forum on another website. There are plenty of other sites out there who are in need of frustrating users with imaginary problems.
my problems aren't imaginery, I have given a video to prove that the game stutters. I will still be trying the 6600GT and all on XP.
BTW the game was installed in XP, however worked through source files in Vista.
You will never solve your problem if you continue as you are. You need to try ONE THING AT A TIME. You have received hundreds of suggestions since your ownership of the X1900 and I truly believe you have not even tried 1/20th of the suggestions. Suddenly, you have Vista installed? You're jumping around like a kangaroo with ADHD.
I will try the stuff, let me get the screw driver. I will hopefully be trying a different card(6600GT), removing the sound card, a different CPU and motherboard.
Please wait.
I found these things, therefore posted it here, if MW runs without those problems(but with some new ones) on Vista but not on XP, I wanted to know whether that could be a software/driver or hardware issue.
Please be patient, from whom I haven taken AMC will come with the required hardware or equipment to test, I can't force him, but he should come soon.
i am beginning to believe that *you* are just putting us on ...
:thumbsdown:
in every way 😛
[dennilfloss of old days would have created someone like you just to waste the forums time and frustrate helpful people trying to seriously answer something that is better ignored] 😉
did you find a "proper screwdriver" yet?
:roll:
either you are (1) completely hopeless or (2) fake ...
EITHER way, i will not bother reading another of your posts ... nor will i post in any of your threads.
call me suspicious ... but some things are a total waste of time .... and i think you are laughing at us
:disgust:
damn it, you are freaking annoying.
Follow the steps EXACTLY and report the results:
Take EVERYTHING out of your box except
1. one cpu
2. one motherboard
3. one harddrive
4. one piece(1 gig) of ram
5. one 1900xtx videocard
6. one power supply
7. one keyboard,
8. one mouse
then
1. clear your bios
2. format your harddrive
3. install windows xp
4. install one ATI driver
5. install one game
then run the game , tell us if it is stuttering.
DONT DO /INSTALL / F**K With anything else. don't install any other driver, etc et, don't do any windows update, don't do anything, just FOLLOW THE STEPS AND REPORT BACK!
Can you do that?
Have you checked to make sure your drives (both hard disks and optical drives) are running DMA mode, not PIO mode?
That's the last option I can think of. And yes, Windows doesn't always get this setting right, and sometimes runs drives in PIO mode. This could conceivably cause the choppiness you're talking about. I'd also defrag all hard disks.
Also, I'd update your sound card drivers, or try running with onboard sound instead of the SBLive!. Occasionally poor audio drivers can cause choppiness in games. Your 3DMark05 scores are where they should be for the card you have; I really don't think your card is even the problem here.
1. one cpu
2. one motherboard
3. one harddrive
6. one power supply
7. one keyboard,
8. one mouse
then
1. clear your bios
5. install one game
Can you do that?
OOOOOOOO wait, I've got this one.....
akshayt---> "OK, I've done what you said almost, but I can't get XP to install, do I need to put my CD drive in too?"
