Originally posted by: SuperTool
OK, what's with all this second guessing. The terrorists start killing hostages and the Russians go in. Negotiations are fine until the terrorist start killing hostages en masse.
Only 2 hostages died from gunfire, according to official new sources. That is not "en masse." Whatever you were told there must not be true.
No one is approving of terrorists or hostages-takers, but this was obviously a more-or-less failed rescue scenario, with unacceptable hostages casualties (~15%). The fact that those deaths were caused by the Russian government, and not the hostage-takers as would be the usual case, makes the situation that much worse.
With Putin on Russian TV giving formal apologies, you can guarantee that heads are rolling in the Russian government right now.
The terrorists said they would start executing hostages at 6 in the morning. They killed 2 at 5:30, and the Russians heard automatic weapons fire. The hostages that made it out said they had full expectation of being killed. Now, what would you have the Russians do?
1. Sit back and say, "yep let them shoot. they'll run out of ammo eventually"
2. Not use gas, rush in and risk massive explosions. Now even if the building didn't collapse, there were dozens of chechen women sitting there wired up to blow. Surrounded by hostages. We are talking about blowing up dozens of bombs in a crowded theatre. Now given the size of their explosives, each would probably take down a dozen or more around them. If the building collapsed, everyone including the rescuers would die, probably around 1000 people.
3. Use gas. Which would kill some hostages with lower tolerances, but would neutralize the terrorists. They had to use enough gas to incapacitate all terrorists if they wanted to avoid explosions. There are so many variables, that it's impossible to calculate how much gas is needed to avoid killing the hostages and at the same time take out all the terrorists.
The Russians did what they had to do with the information that they had. Now if you can come up with a better solution given what they knew then, I would like to know it. And why are 15% casualties unacceptable? And why would it be better if the hostages were killed by terrorists who wouldn't give them any chance to survive as opposed to being killed by Russians in a rescue attempt, where at least they had a chance?
