- Mar 3, 2017
- 1,779
- 6,798
- 136
Actually since OS schedulers tend to go from highest frequency to lowest in priority, and CCD1 cores all have lower frequency than CCD0, a "CCX-unaware" scheduler should still work just fine.Even the plain old 9950X is dependent on preferred CCD scheduling for peak performance.
The reviewer guide gave steps to avoid bad scheduling because Windows 11 was too clever for that.Actually since OS schedulers tend to go from highest frequency to lowest in priority, and CCD1 cores all have lower frequency than CCD0, a "CCX-unaware" scheduler should still work just fine.
AMD currently perform the same segmentation with Ryzen 8000G vs. Ryzen PRO 8000G: Phoenix's and Phoenix 2's IMC supports ECC, but the non-PRO SKUs have it disabled AFAIK. Likewise, Ryzen 4000G vs. Ryzen PRO 4000G alias Renoir.[…] they can't charge too much for EPYC 4000 since it's just rebadged "consumer" stuff, Intel solved this problem in the past by removing support for ECC, but since Zen 4/5 support it (if you get BIOS and mb) it's hard for AMD to do that.
I agree but add that "best" doesn't imply "good".EPYC 4004 doesn't have any dual cache CCD parts but its successor stands the best chance […]
Well, EPYC 4004 appeared two years after Ryzen 7000, and 1½ years after Ryzen 7000X3D. I am guessing AMD aren't quite in a hurry to release EPYC 4005 either.[…] (after sales channels are saturated with 9800X3D).
Incompetence - they could have made extra couple of hundred bucks for the same 9000 series product, more if they had both chiplets with 3D cache, free money.I am guessing AMD aren't quite in a hurry to release EPYC 4005 either.
LmaoIncompetence
These things are niche to begin with, and V$ parts moreso. Get real.they could have made extra couple of hundred bucks for the same 9000 series product, more if they had both chiplets with 3D cache, free money.
L3 are "shared" to ensure cache coherency of the whole chip via Infinity Fabric on IOD - this has got high latency, which is why it is ideal to have big L3 cache on each chiplet, this way there is much bigger chance workloads run on each chiplet will fit THEIR stuff into their local L3. Otherwise why would AMD create Genoa-X with extra cache on all chiplets, for mugs? It was priced only like 10% extra by the way, clearly tech is cheap enough.I really don't know why anyone wants dual v-cache dies if the processor isn't able to share cache between different CCDs.
They're coherent but not shared.L3 are shared to ensure cache coherency of the whole chip via Infinity Fabric on IOD
Yes, I've (later) put "shared" into double quotes.They're coherent but not shared.
margin.so what's the bloody problem offering it
anything but.price is cheap
It will not.this extra cache will offset limits of 2 memory channels
From memory Genoa-X 96 cores was like just over a grand over extra for 12x extra 3D cache chiplets, that's very cheap per chiplet - 100 bucks?anything but.
List prices are NOT real prices. Forget about them.From memory Genoa-X 96 cores was like just over a grand over extra for 12x extra 3D cache chiplets, that's very cheap per chiplet - 100 bucks?
I am talking about retail pricing that I could see, poor peasants like myself don't get hyperscaler discountsList prices are NOT real prices. Forget about them.
We're not talking hyperscaler discounts.I am talking about retail pricing that I could see, poor peasants like myself don't get hyperscaler discounts
Really? When did that happen?Turin-X scrapped
You buy a system, not a CPU.
Somewhere this year when MS opted for MI300C for HPC refresh instead.When did that happen?
So is this a packaging bottleneck?Somewhere this year when MS opted for MI300C for HPC refresh instead.
Any plans for an MI325C with z5 chiplets?Somewhere this year when MS opted for MI300C for HPC refresh instead.
I guess high capacity HBM is more useful.So is this a packaging bottleneck?
I buy CPUs, Genoa-X retail price was just a grand over normal 96 core, that was 10-12%, on a system basis when you throw in RAM/nvmes etc that's even smaller increase, but in any case I was talking about AMD's money here - if they were getting only 100 bucks extra for each of the 12 3D chiplets then it's not expensive for them to do it at all.You buy a system, not a CPU.
No, just a product choice.So is this a packaging bottleneck?
No.Any plans for an MI325C with z5 chiplets?
Well the point is that you buy server stuff from your favorite OEM/ODM were CPU price varies. A lot.I buy CPUs, Genoa-X retail price was just a grand over normal 96 core, that was 10-12%, on a system basis when you throw in RAM/nvmes etc that's even smaller increase, but in any case I was talking about AMD's money here - if they were getting only 100 bucks extra for each of the 12 3D chiplets then it's not expensive for them to do it at all.
As far as I can see it's the same kind of price among them - too high...Well the point is that you buy server stuff from your favorite OEM/ODM were CPU price varies. A lot.
FWIW, retail prices in Germany of Milan-X and Genoa-X have always been considerably more expensive than non-X parts, whenever I looked them up.Genoa-X [...] was priced only like 10% extra by the way,
