Page 884 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
inquiss
649
914
have to say, the eye popping Gaming performance seems to have shadowed the impressive general application perf IMO
I haven't had a chance to pour over data from the 7800X3D in huge detail, , but just from hindsight and what I have seen the standout for me is how Zen 5 has responded to cache outside of gaming workloads. The effective 'ipc' increase seems notably more significant.. around 8% in CnC's Spec INT Testing, and in Computerbase's Tests for CB24 , we can see it's around 6% faster than the TDP unlocked 9700X in Multi core as they both sit at roughly 5.2Ghz under All core load in this case (conveniently - check their OG 9700X review)
In ST CB it sits around 4% higher iso clock estimated (The 9700X is 5.5% higher clocked, but only 2% higher performance) , Ditto WebXPrt
The end result is in MT in particular, some quite phenomenal overall performance really for an 8 core CPU @ 5.2Ghz .. It's like Zen 5 comes alive.
It would be great to see what it does with the wick wound down a bit too.
Yeah, definitely. Shows how limited zen 5 is by the memory subsystem. Strix halo will be a bit more unchained in that regard and I'm expecting strong productivity performance without the need for 3D vcache.
Josh128
Banned
Oct 14, 2022
1,542
2,297
if leaks 9950X3D is true, and will be faster in games than 9800X3D, that also gonna be best universal CPU for gaming and work
MSI 9950X3D show it will be worse in games than 9800X3D. Scheduling issues will undoubtedly cause anomalies that will bring its average vs 9800X3D down a bit.
KompuKare
1,236
1,611
What really needs to stop is the 10 versions of the same test.
Imagine a productivity suite that was just 10 different 3d renderers, most of which nobody uses. That is what CPU gaming benchmarks are pretty much, it just covers the AAA titles with very little covering the rest of the gaming market. GN atleast test Stellaris and some of the german sites test ANNO so there are a few places that at least throw in those sorts of titles but if you wanted a proper suite you would do something like the below
1 e-sports shooter. (CS2, Cod, Valorant)
1 e-sports MOBA. (LoL or Dota)
1 RTS (starcraft 2)
1 ARPG (path of exile, Diablo 4)
1 turn time test (civ 6, civ 7 next year)
1 sim rate test (HoI4, Cities skylines, Factorio, Satisfactory)
1 survival game (PubG, Rust)
1 Flight sim (MSFS, Xplane)
1 racing sim (ACC, iRacing)
1 Bethesda game (Modded Skyrim given that is more popular than Starfield or Starfield given that is the newest iteration of the engine)
1 CDPR game (CP2077 given that is their latest and is popular)
1 Larian game (BG3)
2 AAA games that are currently popular
That covers a 15 game suite and would give you a pretty broad look at a lot of different titles, some of which are AAA and some of which go beyond just looking at that.
Then imagine if there were 5 different outlets that each tested a different game in each category or where they do test the same game they each tested a unique scene. That would give you far more scope to make a purchasing decision.
Excellent post!
The whole tabloid journalism of perfomance being a simple linear thing really needs to go. Obviously someone who runs and plays everything will have it harder, but most of us only do certain things so the:
"What is the best CPU?"
Should almost always be met with:
"What do you do/play?"
(And what is your budget!)
As with most things in life, there is seldom a simplistic "best", and even against 7800X3D there are still some outliners where RPL is faster (ignoring power).
Gideon
2,044
5,103
It has gobs of memory bandwidth as well as a SLC.
I'm not sure how much the latter is actually used by the CPU portion, but i guess it can reduce latency for cases where different CCDs modify the same system memory. Should be faster than snooping each-other's caches, let alon go to main memory.
Reactions: inquiss
19,219
And ignoring the possibility of the CPU being just wasted piece of silicon after it's been zapped enough times by the ST boosts :D
Though one could start disabling the affected cores one by one to prolong its life and allow it to enjoy life a little longer...
Reactions: lightmanek
Gideon
2,044
5,103
I have to say I really like the methodology of this Polish reviewer (use google translate if needed) on testing tuned settings and CPU bottlenecked scenarios:
All measurements in programs were performed four times, while in computer games eight times (two separate rounds covering four passes, preceded by a platform reset). The result that differed the most from the rest was rejected, and then an arithmetic mean was taken from the rest. In the game performance graphs, the individual bars mean: the longest is the average number of frames generated per second (AVG FPS), the middle is the average value for the lowest frames per second (MIN FPS), the shortest are frames per second (1% LOW) that are below the average MIN FPS for 99% of the time. The above description may seem enigmatic to readers unfamiliar with the terminology, so 1% LOW should be read as a symptom of performance drops, stutters, drops, etc., if it significantly deviates from the MIN FPS indications.
DDR5 memories worked at 7000 MHz and latencies of 32-48-48-96, always working in asynchronous mode or Gear2 (1:2), which is mandatory for Intel LGA 1700 platforms and optional for the AMD AM5 platform. In the case of the AMD AM5 platform, the DDR5 7000 MHz CL 32-48-48-96 (1:2) settings are equivalent to the DDR5 6000 MHz CL 30-36-36-76 (1:1), as confirmed by THIS article ( LINK ) and the sample charts below. Therefore, I decided to use identical DDR5 RAM modules for both platforms. The problematic 1:1:1 configuration is no longer required to achieve optimal performance on the AMD AM5 platform, because the correlation between the Infinity Fabric bus, the memory controller and the RAM clock has changed compared to its predecessor. Therefore, the asynchronous mode in the AMD AM5 implementation is much more useful than before. The Infinity Fabric bus on the AMD AM5 platform worked at an automatic frequency (2000-2100 MHz),
Why are some games ray tracing enabled, when it is widely known that it additionally burdens the graphics card? This is partly true, but the above statement is imprecise, because ray tracing also affects the CPU utilization. The relationship between CPU/GPU depends on the implementation of ray tracing in specific titles, because in some cases the GPU utilization can even drop, while the CPU load increases. For example - Spider Man Remastered, Hogwarts Legacy or Dying Light 2 practically do not change the relationship between components, although enabling ray tracing reduces the overall performance, which allows you to check the configurations in the most demanding scenario.
In computer game tests, I use my own measurement locations, which I capture during long hours of sessions, but all of them are completely normal scenarios occurring during gameplay. I consistently avoid built-in benchmarks, because most of them do not reflect real conditions and distort the results, often being an element of manipulation by hardware manufacturers and drivers. Therefore, the best choice are test locations in popular locations or sequences played during the campaign, which cannot be skipped and/or affect the overall experience of the game. To increase the reliability of the measurements, I present my measurement locations below:
Makes sense to me. All CPU intensive options are "on" and all areas tested are listed below (usually only busy city scenes with lots of NPCs, etc to offer the worst case CPU bound scenarios).
We already know that X3D chips perform extremely well in games with relatively low CPU usage say at 720p in otherwise GPU bound areas (as it becomes almost entirely memory subsystem limited). These benches highlight the cases where 7800X3D struggled more.
The good news? 9800X3D passes these with flying colors too and 285K is even worse than ever
In2Photos
2,626
2,794
I was watching another review of the 9800X3D and the reviewer noted a difference in the core voltage under CB R24 which accounts for the difference in power consumption compared to the 7800X3D. The higher clocks need more voltage (which we know). Despite the much higher core voltage the temps are still lower. Here's what he saw in testing:
  • Love
Markfw
May 16, 2002
27,416
16,275
Amazon is now back to $479 even, and they are in stock ! newegg is sold out still.
Edit: But I just noticed " FREE delivery January 22 - 24 to amazon prime members"
In2Photos
2,626
2,794
Not sure if what he says is from rumor or talks with AMD (it which case he probably isn't supposed to be saying it) but Paul says 9900X3D and 9950X3D are to have vcache on both CCDs. Starts at correct time stamp, even with an image of cache on both.
OneEng2
1,016
1,213
What is most interesting to me (a non gamer) about the 9800X3D reviews is that it looks like the core architecture still has some room to grow. A few tweaks here and there to alleviate some bandwidth bottlenecks and it isn't hard at all to imagine a Zen 6 with 20-30% IPC uplift.
This thing really breaths well ..... and is very power efficient when it does so.
I am still thinking that the 285K CB 2024 (and Zen 5 with different memory speeds) is showing that bandwidth is more important in this CB than in 2023 and that 285K can move more than Zen 5 .... while Zen 5 clobbers 285K in latency to pretty much any memory.
Are these accurate conclusions?
inf64
3,884
4,692
Insane if true. 9950X is going to be an absolute unit of a CPU, especially with new RTX 5090 coming soon. Sad times for intel though, they are being relegated to bulldozer levels of performance.
Gideon
2,044
5,103
1:2 memory with 7000 mt/s -> straight to the trash bin :p Eastern Euro reviewers are like uber-pro Intel and pro-nVidia, as usual
They mesured CL30 6000 MT/S as well. But yeah win10 is strange and their overclocking part was trash IMO (compared what scatterbencher could achieve)
Still useful as they tested heavy areas of actual games. Even if these are usually Intel favored, intel still lost heavily.
Glo.
5,930
4,991
Only possible IF Zen 6 has more memory bandwidth available.
Latency is not the limiting factor, but bandwidth starts to be.
And that will possible ONLY with new socket.
Gideon
2,044
5,103
I really hope they do it. IMO it's the only way that makes sense.
We know these chips can clock to at least 4.5 GHz. Even more, if the stories about 9800X3D "9600 level" binning are true (and they seem to be, based on the current info from a smallish sample size).
We know from the Phoronix review, that even in production workloads, the 9800X3D outperforms the 9700X, despite the latter having a theoretical 300Mhz ST clock advantage.
2x stacked dies would remove most scheduling headaces (no stupid game bar fix needed). and 9900X3D would actually be a viable SKU.
I know of multiple developers that need max amount of cores for compiling but also like to game (some are even game developers). 9850X3D would be a perfect solution for them.
Timorous
1,989
3,918
The 8000 APUs support much faster ram on AM5 so I don't think it is a socket issue, just the IO die is a bit behind.
Good thing is Zen 6 is supposed to have a new IO die (possibly new packaging as well) which can improve the CCD to IO die connection as well as IO die to memory bandwidth.
Ranulf
2,921
2,602
Framechasers cringelord heard you :D. It is hilarious since it's coming from a guy who is selling gaming tweaking/OC guides for the most expensive CPUs. Also he complains about something he can only detect ("AMDip") lol
The irony is he or rather the meme isn't totally wrong, it depends on the game. The fact that mr max fps Cod pro custom OC guy doesn't know there are games that really really do well with the 3d cache is hilarious all while he is an expert that charges for all his tweaks that many could do fairly easily on their own.
It is even funnier given all the dramas with CoD and the new Blops6 with matchmaking issues, server stability and performance etc.. I can't take most of these competitive shooters seriously anymore give the manipulation clearly going on in these games, especially activision blizzard. I've seen it a lot in Overwatch "2" for over a year now.
Josh128
Banned
Oct 14, 2022
1,542
2,297
I really think hes just speculating / pulling that out of his arse. Personally I think there is .001% chance that they do that...UNLESS theyve figured out a way to UNIFY both CCDs across a single huge L3 and choose to do it this gen. I think the chances are even less of that though.
Gideon
2,044
5,103
Why not? They would "waste" less X3D chiplets per CPU, but they'd literally leave performance on the table. Keep the scheduling issues (that are a dealebreaker for some). And keep the 7900X3D as a zombie unsellable CPU ...
There would be nothing special in having two X3D CCDs. They've done it in servers and it would behave as any other 12/16 core AM5 part.
Unifying could make (a little) sense if the 3D part were L4, but as it is all one big shared L3, the latency from CCD1 -> X3D -> CCD2 and back would be horrible for a L3.
Not to mention unifying 2 CCDs would only help desktop chips. Going through all that trouble only minimally helping the (surely upcoming) server parts, makes even less sense.
Josh128
Banned
Oct 14, 2022
1,542
2,297
Unless they unify the L3 across them, there would be zero gaming benefit, at the detriment of being a lot more expensive.
L3 latency would increase, but it should be far from "horrible". If the chiplets are layed out correctly, it would be not much worse than the latency of the L3 on the 16 core CCX on Zen 5c. If the chiplets are layed out as below with a single L3 SRAM die below them, there you have it. At worst, the latency would double from far core to far core/L3, but still about the same as if you had a single monolithic chip with one long L3 layout between the cores, which they do have. If you disagree, please refer to the figures below and explain why.
Im no CPU engineer, but I dont see how this is something that would not be quite possible, and quite beneficial, to make a killer CPU. It may not happen on AM5 due to pin layouts, etc, but I think it WILL happen eventually.
Theoretical 9950X3D:
Existing Zen 5c CCD
In2Photos
2,626
2,794
Being he was the only one I saw mention that I tend to agree he's speculating.
The only reason I can think NOT to add vcache to both CCDs is that it could hurt sales of non-X3D parts (not speaking to possible technical reasons). The 9800X3D kind of makes the 9700X pointless except the 9700X costs less. But if the 9800X3D out performs the 9700X in nearly all areas I think most would just go for the X3D version. But yields are less for X3D versions right? It takes more time to make the chips? This would reduce the amount of chips they could produce if they only sold X3D versions. If AMD could make the X3D chips compete with their non-X3D versions in non-gaming scenarios and dominate in gaming scenarios there's really no need for non-X3D versions, unless there's a big enough price gap.
