Page 851 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Det0x
1,484
5,086
With 5.2 Ghz Max Boost, rather than 5.4-5.5 GHz some people expected, 7800x3d owners can sleep well, without temptations to upgrade.
Guess AMD went conservative on the clocks for this SKU, and looking at the already leaked numbers for Arrow Lake, they will face zero pressure from Intel this generation.
But Z5X3D should have much more overclocking headroom than Z4X3D, for those of us that like to tweak 👍
5.2ghz stock fmax + 200mhz offset + ECLK the rest
Det0x
1,484
5,086
Me and someone Ik have been stuck around the same score of 33K, guess it’s because we're on Nvidia?
Not really
I updated my numbers for 9950X (ES) + 3090 @ same settings
Pretty much bottlenecked by the 3090 at this level, need to get my hands on a 5090 :smilingimp:
Had one run at 53.3k, but the clocks were pushed to high -> freeze at the outro-screen of all things 😅
Timmah!
1,572
935
Another great review by Geekerwan.
Is this 45k score at 5,13 GHz and 300W of power for 9950x default state of business with PBO on,or does it require further tinkering to get there (meddling with CO and other bios settings, in other words not guaranteed)?
Is 300w possible to cool with AiO like my Arctic 420 - i mean to keep it at those 95C so the clocks wont throttle down from that 5,1 value and score does not plummet?
Gideon
2,043
5,096
Would make sense. I installed W11 24H2 and managed to hit 34K, but couldn't get any more out of it, even with RTX 4090. I'll try at some point with my venerable RX 6800, once I get it back
Reactions: lightmanek
CouncilorIrissa
780
2,819
Do I get this right, he made a show of overclocking Zen5 so it could match subambient cooled M4 in SPEC instead of simply enabling SIMD in the compiler options, where it would match it at stock (at least the FP part) ?;) [This assumes he used his standard compiler setup for SPEC].
Not only that, the GCC version used to compile SPEC in his testing, GCC 10.1, predates not even Zen 4, but Zen 3.
lol
MS_AT
918
1,836
lol
Isn't he using Clang 14.0.6 but without specifying any arch so he gets x64 baseline for everyone? It's better than specifying march=native if he doesn't plan on updating the compiler.
I think the twitter user Raichu was using GCC 10.1, David Huang is using GCC 12.3 but he is trying to make sure his march options make sense and Chips&Chesse are using GCC 14.2 with --march,mtune=native which is the best option for any chip as long as it is recognized by the compiler but it will force them to update the compiler for each released chip that GCC 14.2 does not support [or manually enable missing features].
Josh128
1,505
2,256
Idk here ? xD "Not, a chance in hell" then 12h later xD when tuned 9800x3d is 25%+ faster vs max tuned wcckek's best amd-owner's can do. But that meme was funny thou xD
Looks like at least half of my "not a chance in hell" prediction came to fruition, the performance half. Now its completely up to AMD. "To milk or not to milk".
CouncilorIrissa
780
2,819
10:58
CouncilorIrissa
780
2,819
Oh, I haven't noticed. My bad. That is why I was saying in another thread the compiler configuration should be shared in visible place together with the results;)
Thanks for pointing this out.
He's been all over the place with his choice of compiler. He used Clang 14.0.6 for his LNL review as you pointed out. But his Raptor Lake reviews used GCC 12 IIRC.
Philste
308
486
I mean everyone that expected way more than 10% was obviously wrong. ZEN5 is 3% faster than ZEN4 with same RAM and clocks have a 0.5-0.7 scaling. So it's 3% from Arch and 7% from Clocks at best. With 5.2GHz boost we're looking at 3% from Arch and 3% from Clocks, so ~6%.
Josh128
1,505
2,256
AMDs marketing has a proven track record for setting a range of expectations and having the product come in at the absolute lowest possible point on that range. They literally leaked 5.2GHz all core Cinebench R23 a couple weeks ago. Based on that, most logically thinking people were assuming 5.3 to 5.4 max boost for 9800X3D. AMD set these expectations with that leak. Coming in at only 5.2 is disappointing solely because of their own crappy marketing. All they had to do in the run up was tease a "modest max clock boost", or dont mention clocks at all, but thats not how they roll, lol.
CP5670
5,686
787
8% seems too little to bother with. Maybe the 16 core part will be more interesting, but for games I don't see much reason to upgrade a 7800X3D.
Reactions: Tlh97 and Elfear
Hail The Brain Slug
3,889
3,329
You're judging a leak which may not even be accurate or real information against.... another leak that may or may not even be accurate or real information.
I'd think it would be prudent to stop judging an unannounced, unreleased product until we have real, actual hard specs and performance figures.
tsamolotoff
259
510
Who said that was AMD? It was clearly an overclocked CPU which was most probably (to put it mildly, I'd even say definitely) a dual CCD part with one chiplet disabled (otherwise it wouldn't require hiding the CPU name etc) which has higher (or just different) fmax as compared to non-ES SKUs including 7800x3d. As Dom said, his pre-release ES "9950x" has different fmax and v/f curve as compared to the final products
Josh128
1,505
2,256
The 5.2GHz all core leak was most definitely done with AMDs permission. There are NDAs for things like this, and its extremely evident that it was a calculated / planned leak.
tsamolotoff
259
510
You can also make 7800x3d and 7950x3d to run close to fmax on x3d chiplet, so what's different now and why we should be worried etc? This 5.2 leak was just to curb expectations if people see the 5.6 ghz benchmarks and assume that it'd be 100% possible to do for everyone.
arcky
14
50
46
Nothing about this “official leak” (whatever the hell that means) looks reputable to me. The graphic style (font, layout, image) doesn’t match any other AMD material, the verbiage itself reads very casual/unprofessional and frankly grammatically incorrect. At worst, this is entirely fabricated, at best it might be sourced from some official channel, but in neither of those scenarios does this appear calculated/planned.
arcky
14
50
46
5.25 1t
5.3 1t
Make of that what you will.
Using average of those two vs aggregate score linked below, +21% ST, +22% MT over 7800x3d
