Page 826 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
biostud
20,199
7,316
This thread is so dead, not even some X3D rumors posted hours ago have made it here yet.
TLDR: 9800X3D R23 ST 2145, MT 23315
.......... 9950X3D: ............2245,...... 42375
Indicates ST boost clock speed of ~5.3GHz for 9800X3D, ~5.6GHz for 9950X3D. Very impressive for the 9950 if that score was achieved with an X3D die.
Or more likely they are still heterogeneous....
19,218
Something about ASUS Nitropath:
Lemme engage my AI assistant to understand what he's saying (sorry, short attention span prevents me from digesting info heavy videos!)...
[Music]
hi and welcome back to a new video last
week I was visiting Asus HQ in Taiwan
and I was discussing the Nitro paath
memory feature with them this was
already released and announced during
previous Gamescom in August I was
hosting a live stream at least for my
German YouTube channel I was discussing
it briefly there and at that point I
wasn't sure if that's just the typical
marketing blah blah or if it's actually
doing something Asus was advertising
that it allows to increase your memory
speed by about 400 megat transfers and
yeah so discussing this with the
engineers it was much more technically
interesting than I initially thought and
we will look at this in today's video
are you looking for a strong and
reliable hosting partner then hna is the
right place for you as leading hosting
provider with their own high-tech data
center hsna offers gdpr compliant
hosting at incredibly low prices heads
operates several hundred, servers at
multiple locations in Europe and the USA
and most recently also in Singapore hsna
products impress above all with their
outstanding price performance ratio the
secret behind this simple and functional
Solutions a focus on core features and a
constant optimization click on the link
in the description and discover more
about hetner this slide was used by Asus
to advertise this yearing Gamescom on
the left side you can see a conventional
memory slot everything you have
currently at home is using exactly this
technology and on the right side you can
see the nitr PA memory slot with those
like bent contact pins that then make
contact with the memory slot in the
middle last week we were using an let me
phrase it upcoming motherboard that only
has two dim slots and it's focused on
memory overclocking so I'm not getting
into trouble and this motherboard the
upcoming one for Intel didn't have the
nitr PA feature which they didn't make
sense to me because I thought this Nitro
paath feature like new memory dim slots
would enhance memory overclocking so why
would an upcoming memory focused
overclocking board not have it like this
one the x870 e hero for dim board for
AMD and AMD is typically not running
such a high memory speed has it but then
the Intel board didn't have it that was
quite odd then I asked the R&D team what
the reason for this is and then they set
up two comparison platforms so they
brought two x870 a gaming Wi-Fi
motherboards which are like mid-range
and four dim motherboards they had one
with con conventional memory slots and
one with the Nitro path memory slots the
first setup was with an AMD 8700g
because those apus can currently run
higher memory speeds than for example
ryzen 9000 and the on the conventional
motherboard it was maxing out at 88,200
me megat transfers so at that speed you
could still boot but in Windows in m
test you would get errors and then they
swapped the same CPU same memory dims
onto the Nitro paath motherboard and
8600 megat trans transfers would run
mest stable so that was again the moment
when I asked myself okay that's cool but
why is it again not on the upcoming two
dim motherboard that is focused on
memory overclocking and that's because I
had a wrong perception of what this
feature actually does when it comes to
the memory layout most of the
motherboards these days are working
exactly the same so the desktop CPUs
usually have two memory channels that is
channel a and channel B that's also why
you can find this label on here like Di
A1 A2 B1 and B2 and two of the channels
are always Daisy chained because it only
has two channels then the first two
slots are going to one channel and then
the B slots are going to the second
Channel and that's why when you occupy
A2 and B2 you always see this running in
dual Channel mode and now if you occupy
this with two memory dims like right
here you still have the two empty slots
and these are still electrically
connected to the CPU and there're still
signals arriving so there's like no
electrical switch in between that if you
don't pluck anything that they're like
that that's not the case when this nitr
PA feature was announced I just thought
okay it's like a different mechanical
mechanism of how the contact pins are
making contact with the dim itself and
because this is also like having a
little bit higher mounting pressure than
a conventional dim slot that this is the
real benefit but that's actually not the
case it was just about the empty slots
not about the occupied slots which is
what I had like completely wrong if you
want to measure the signal quality of
such a memory slot for example you can
do that with an ey chart if you look at
the binary signal it's in original form
like a rectangle shape but if it's very
high speed like here between let's say
3,000 and 500 MHz it becomes much more
like Senus sinus Senus sinus shaped and
that's because of a lot of interference
and things in between and with an eye
chart you can identify if the signal is
still clean enough or if it's already
overlapping and you will get some errors
this is one of the charts where you can
see it with the blue and green lines we
can also see state zero and state one
like zero at0 volt and then one at 0.4
volt and due to this very high clock you
can see that this is no longer the
typical rectangle theoretical form but
like a sinus shape because of the high
speed and in between there is this hole
and that's what they call the ey marked
in red and depending of the size of this
I that is determined in Picos seconds
that is the time and the height in Mill
volt so the voltage you can determine
how good the signal quality is so the
bigger the eye the better because you
won't have overlapping signals this
example we're looking at right now was
also provided by Asus and this is
running with 6,400 megat transfers which
equals 3,200 MHz we can see on the left
side config one which is testing the A2
memory slot and config 2 on the bottom
is testing the B2 memory slot on the
right the old connector is the
conventional memory slot and the new
connector on the right is the Nitro
paath memory slot but here in this
scenario with 64 megat transfers which
is 3,200 MHz there is little to no
difference so at this state at this
speed it's not really relevant that's
why we're now switching over to 5,000
MHz equaling 10,000 megat transfers and
here it looks quite a bit different the
traditional memory slot doesn't have
this eye anymore in the center so you
will have some memory interference some
overlapping signals which will lead to
errors or even that you're not even
possible or not even able to boot this
kind of speed then again on the right
side with a nitr paath slot you can see
a significant difference the I became a
lot smaller compared to the previous
example with 6,400 megat transfers but
it's still visible and that's I'm not
sure if this state is like usable with
the 10,000 megat transfers but you can
at least see see a clear physical
difference between the two slots now
going back to the beginning because I
originally thought that those different
memory slots will help because they have
like different shape and make better
electrical contact with the modules for
example but that is not the case it's
about the empty memory slots each of the
memory slots contains 288 pins it was
the same for ddr4 it's still the same
for ddr5 just with the fact that now
we're just approaching very high speeds
let's say with 10,000 megat transfers
approaching with ddr5 that is just very
very high frequency and will need very
good signaling quality and each of these
pins that are standing out from the
memory slots they also act like an
antenna especially the non-occupied
slots so every non-occupied slot is
interfering with the occupied slots
right next to it so the higher you go in
frequency the more relevant this problem
becomes that those empty slots and the
empty pins act like as an antenna and
have bad signal impact on the memory dim
right next to it now Asus did a lot of
testing about this and they had some
very cool images which they also gave to
me what they did was making pcbs with
memory slots sitting on top also with
memory dims inserted then they put
everything into epoxy hardened it then
they cut through it sanded polished
everything so you can get a very nice
crosssection to see how this looks in
reality the left image now shows was the
crosssection of conventional memory slot
where there is no memory module
installed yet the dark area is the
plastic of the socket and in the center
you can see the contact pin that also
has this rounded shape that then
eventually makes contact with the memory
dim itself that's what you can see on
the Right image so that is also again a
conventional slot but just with the
memory module installed that you can see
in the center has a quite thick PCB and
you can also see that it's a multi-layer
PCB and has this copper contact on left
and right which forms contact with the
pins of the memory module which are
forced out a little bit to left and
right because the module was inserted
now switching over to the nitr paath
memory slot left side again without
memory module and on the right side with
the module inserted now that's quite
interesting because this is a little bit
different to what they showed in the
original marketing slides could be that
this was some kind of technically like
more relevant and probably important
feature that they wanted to hide a
little bit so thanks for providing those
cross-sections anyway you can see that
it was bent down it is a lot shorter
than the conventional slot by about 40%
and only this like Bend section is then
making contact with the memory dim
itself so to recap this it's mainly a
feature that helps on the empty dim slot
and not on the occupied one and that's
also why you probably won't find this on
like an MSI UniFi X or like an Asus Apex
motherboard because it doesn't really
help if it's just a two dim motherboard
that's why I was just completely wrong
we recently covered something similar in
a video where I was talking about that
the guaranteed memory speed for example
advertised by Intel doesn't depend on
your actually memory configuration but
rather the motherboard configuration
they were listing for example I think
14th gen was 5600 megat transfers and
that is only for a two dim motherboard
like an apex but whenever you use
something like a hero or extreme which
has four four slots then like officially
it was something like 3600 or like 4,200
like bizarre low and I was wondering if
that's correct but it's indeed correct
because it's mainly the motherboard that
is causing trouble to how high you can
clock your memory rather than the actual
memory configuration that's why yeah if
you are targeting or if you're looking
for very high memory speed then like a
two dim motherboard will always be the
way to go the cool thing is also that
this won't stay an Asus exclusive
feature if I understood it correctly
they developed it together with the slot
manufacturer I think it was Lotus and
now it will be exclusive for Asus for
like a year and afterwards it's going to
be an open standard and everybody can
make use of that so I'm pretty sure we
will also find it on like MSI gigabyte
or like an ASRock motherboard and that
should definitely help memory clocking
in the future but yeah I just wanted to
cover this because I I
underestimated how yeah problematic just
the empty memory slot could be I hope
you enjoyed this video see you next time
bye-bye
[Music]
In this video, the host discusses their visit to ASUS HQ in Taiwan, specifically focusing on the company's "Nitro Path" memory feature, which was previously announced and released during Gamescom in August. Initially, the host expressed skepticism about whether this feature did anything beyond marketing hype. ASUS claimed that Nitro Path could increase memory speed by approximately 400 megatransfers.
The host found the discussions with ASUS engineers to be technically intriguing and aims to explain the technology in more detail in the video. They promote HETNER as a reliable hosting partner providing GDPR-compliant hosting and good price performance.
The video discusses two types of memory slots: conventional and Nitro Path. Conventional memory slots, commonly used, are shown alongside the Nitro Path design, which features bent contact pins. The host mentions using an upcoming desktop motherboard with two DIMM slots focused on memory overclocking, which did not include the Nitro Path feature—this was confusing because the host assumed it would enhance memory overclocking capabilities.
To understand the differences, the ASUS R&D team set up comparative platforms using two mid-range motherboards: one with conventional memory slots and the other with Nitro Path slots, both using an AMD 8700G APU. They recorded that the conventional board maxed out at 8,200 megatransfers, leading to errors, while the Nitro Path setup was stable at 8,600 megatransfers.
The host realizes that their initial assumption about Nitro Path was incorrect, believing it only affected occupied slots rather than empty slots. Most motherboards utilize two memory channels, which leads to dual-channel configurations when two slots are filled. The host initially thought Nitro Path improved the contact mechanism and signal quality but later learned it primarily helps manage the signal quality of empty slots that can interfere with occupied slots.
Signal quality is assessed using an "eye chart," which visually represents the signal integrity. A clean rectangular shape represents a good signal, while a sinusoidal shape indicates interference. The host emphasizes the significance of the "eye" size for signal quality, noting that larger eyes indicate better conditions without overlapping signals.
Examples were provided to illustrate the differences in signal quality between conventional and Nitro Path slots at various speeds. The host highlights that with higher speeds (like 10,000 megatransfers), the conventional slots demonstrate poor signal integrity, causing issues that may prevent proper operation, while Nitro Path slots maintain a better signal, even if it diminishes at these higher speeds.
Further, the host discusses the construction of the memory slots. They explain that conventional slots have a uniform structure, whereas Nitro Path slots show a different approach, allowing the shorter bent section to make contact with the memory module.
Ultimately, the host concludes that the Nitro Path feature might not be essential in two-DIMM motherboards designed for higher memory speeds; hence this feature might not be seen on certain models. However, they learned that the technology used in Nitro Path was developed in collaboration with a slot manufacturer and will eventually become an open standard, leading to broader adoption across different motherboard brands in the future.
In summary, the main takeaway is that the Nitro Path memory feature addresses signal quality issues stemming from unoccupied memory slots—a factor often overlooked but crucial for high-performance memory configurations. The host expresses an appreciation for the complexity and implications of this technology, inviting viewers to consider it more deeply.
19,218
So another gimmick that one should wait 1-2 years minimum before buying into?
I would call it progress rather than a gimmick since it improves signal integrity. Yes, initially it will only be available on ASUS 4 dimm slot mobos but hopefully in 2025 we can have it on other vendors' mobos too.
Seba
1,599
259
Non-AI summary (by me):
The pins from unoccupied memory slots (slots which are still receiving signals from the CPU) act like antennas, emitting an electromagnetic field. That electromagnetic field causes interference with the signals to the occupied memory slots.
ASUS changed the shape of the pins, claiming that the modified shape reduces the EM field generated from the pins from unoccupied memory slots.
This change allows for higher memory frequency (while the PC still remains stable).
Joe NYC
4,234
5,838
Good video, it’s the first die shot but unconfirmed
Interesting video, which adds some facts from the die shots from just pure speculation in this thread.
My speculation, not seeing the TSV area from the first die shots was that perhaps AMD spread the TSVs over the some other areas of the CCD die, and that perhaps AMD was going to cover the whole bottom die with V-Cache.
High Yield video is speculating that perhaps the opposite could be taking place, that AMD will cut down the size of V-Cache die and make it 2 layers.
If his hypothesis is correct, this could be the reason why clock speeds regression of V-Cache chips is expected to be lower or eliminated - because cooling area over cores will be minimally obstructed.
It would seem like a complicated way to achieve just that, it seems that there could have been other ways to achieve the same.
Going as far as implementing 2 layers for no gain is overall size of the cache seems like a lot of work for small benefit. The only way I could see this as worthwhile would be if it was a solution that can have more layers beyond 2 (such as 4 or 8)
Doug S
3,845
6,797
Or they could treat it like everyone else treats unterminated transmission lines, and create some sort of dummy terminator DIMM to put in those slots. Bet that would do an even better job than reshaping the pins, and they could sell those to every overclocker out there with not just Asus boards but every make of board!
If I had the connections in the industry and wanted to go back to having to work hard for a while, I'd develop, patent, and productize this myself lol
lightmanek
524
1,292
wait when L3 height is higher than the rest of ccd how is it properly cooled 😱 how many stacks can they do??
AMD's solution (TSMC's really) is up to 12Hi stack (old AMD EPYC server BIOS was showing options of up to 4 stacks on Zen 3 die).
My alternative theory is that instead of going with multiple stacks to make L3 die small enough, they productise it using TSMC 3nm process (which claims 1.2x scaling for SRAM vs N5).
Just a shot in the dark, but broken clock can be right from time to time.
RnR_au
2,913
6,505
From my understanding adding these layers is a slow process. Its capacity limited. So I don't think going to 2 or even more layers is being considered. And thats before thermal considerations. More layers means thicker silicon pads over the compute area which means harder to cool.
Reactions: Tlh97 and Vattila
Kryohi
69
140
Isn't zen 4 vcache made on N7/N6? Even going N4 would increase density if that's the case. Though it kinda kills one of the purposes of vcache.
Joe NYC
4,234
5,838
There is another packaging process called Wafer on Wafer, where the full wafer of the V-Cache die would get joined tother in one step, which would be ~3,500 of the half size V-Cache chips.
The advantage of one by one assembly is that it can be limited to Known Good Die. In case of 2 layers of SRAM chips, the yields are so high and cost is so low that you would not bother to test each individual die (for Known Good Die). The test would be just for assembled 2 layers.
To attach these 2 layers to the CCD could still be done on Known Good Die bases, one by one...
Joe NYC
4,234
5,838
Going to more advanced nodes (from N7) would increase the cost per bit, while not really adding anything in terms of performance for SRAM.
Also, for practical purposes, TSMC N7 capacity is unlimited, while N5 and N3 is becoming limited.
lightmanek
524
1,292
I agree, but on the other hand, main driving force behind V-Cache is server Epyc line of products, so I don't think cost of maufacturing is critical.
Wonder what is more expensive in the long run - stacking 2 or 4 layers, where each stack brings potential defect or manufacturing smaller die on more expensive process.
Joe NYC
4,234
5,838
TSMC is not at capacity for any node.
That has been the case since 2022, but I think now, in H2 2024, N5 and N3 are getting tight. This is just from various tidbits. We will get a more official update in a couple of weeks from TSMC in their investor call.
N7 capacity utilization dropped most significantly since late 2022, and that node has a lot of room left to recover.
