Page 761 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Det0x
1,490
5,117
Anyone know of a good program to measure core to core latency ?
I tried MicroBenchX.C2CLatency and and it spat out this
When i tried to save the data window closed, and i'm not running that again (~20min runtime)
If im reading it right, its ~20ns inter CCD and up in the 150-180ns range for cross ccd (?)
yuri69
699
1,252
Actually it is worse.
AMD basically stopped shipping iterations of Bulldozer for DIY desktop. But they really did polish that turd almost every year through 2015! Zen 5 won't be getting that yearly treatment.
Yea, this is depressing.
AMD pushed a Piledriver-based APU in... 7 months after Bulldozer. Meanwhile Zen 6 is coming in 2026/2027.
Reactions: exquisitechar
Hitman928
6,755
12,501
I really doubt that. I mean I’m not an expert, but it it’s been shown in other reviews it takes on the order of ~ 1 ms to hit boost frequency
~ 100 ns is on the order of RAM access latency, I can’t imagine it coming out of any kind of sleep anywhere near that fast. The voltage regulation, everything else will respond on timescales much longer than that. Just based on my intuition and respect for orders of magnitude I don’t think there can be a software (Windows driver) reason to explain the extra 120 ns. Microcode, maybe.
Are you sure it takes that long and is not just the limit of the monitoring method?
Hitman928
6,755
12,501
sl0519
58
151
66
Is there a detailed description anywhere of what we are seeing in this graph and how it was produced?
I hope the regression versus Zen 4 < 125 W is an artifact of the particular desktop setup. (Because Turin vs. Genoa eventually needs to have a very different outcome than this one...)
[It's not a rehash of the older 9950X *ES* measurements, is it?]
Cinebench R23 PPT scaling.
Regression in very low wattages are also present in Geekerwan’s Strix Point review if I recall correctly.
*edit: it was Spec2017 that showed regression from Hawk, R23 was still performing better in every ppt.
Josh128
Banned
Oct 14, 2022
1,542
2,295
Ummm...hate to break it to you but Zen 5 will 100% be getting that "turd polishing" treatment. It is AMDs "new foundation" for x86 CPUs. Zen 6 will take Zen 5 core arch, put on a smaller process, a few various enhancements (possibly with a 16 core CCX per CCD), along with presumably brand new uncore / IOD setup. Then Zen 7 will iterate on what Zen 6 has done. All will use the Zen 5 core.
Reactions: Gideon
StefanR5R
6,851
11,029
The Core Parking seems to me more like a band aid to the problem
Apparently a poor bandaid just like it has to happen when ISV, OS maker, OEM and CPU maker are not quite getting together for a more targeted implementation. Like assigning CPU affinities to the game process at its startup, maybe.
after decoder mystery got solved
Well, we learned quite a bit more (how it behaves on GNR, whether or not SMT disabled in the BIOS influences its behavior, what the impact in actual workloads is, plus the commentary that moving the various resources between 1T mode to 2T mode is not entirely trivial and has got latencies). There are still more pieces to the puzzle left to discover (or not). Such as why this is counter to what M. Clark said when being interviewed.
Reactions: carancho
gdansk
4,796
8,096
Ummm...hate to break it to you but Zen 5 will 100% be getting that "turd polishing" treatment. It is AMDs "new foundation" for x86 CPUs. Zen 6 will take Zen 5 core arch, put on a smaller process, possibly with a 16 core CCX per CCD, along with presumably brand new uncore / IOD setup. Then Zen 7 will iterate on what Zen 6 has done. All will use the Zen 5 core.
Emphasis on yearly treatment.
It's 22 months between iteration for Zen.
sl0519
58
151
66
Only if this redesigned core somehow can run @5.4-5.5Ghz with 3D cache.
If they somehow manage to hit clock parity with X variant, I genuinely think there’s no point for the existence of lower end X variants. People who are into productivity tasks naturally gravitate toward R9s anyway.
Hitman928
6,755
12,501
I guess you are not using this fancy driver so we can exclude this as a cause, therefore it's a band aid and they botched something it seems...
I think the behavior is inherent to the CPU when there is low activity, the driver is for the OS to schedule only on the active CCD according to whatever requirements it has for doing so.
Hitman928
6,755
12,501
That fancy driver as you put it is not a fix, its a work-around trying to mitigate the problem
Yeah, that's kind of how I see it. I think this behavior was intentional to lower the power consumption of the overall package when only needing a few cores. The driver is there to try and stop the OS from using both CCDs when only 1 is needed, to avoid having to wake up the other cores and suffer a power and performance penalty. Though, it seems to be mostly concerned with gaming loads, or whatever it sees as a gaming load.
MS_AT
943
1,868
That's at least my take if i understand it correctly
Yes I agree. I simply meant that some people thought driver is the reason for high latency and since you are not using it, we know it's not.
That would make sense if this was burst behaviour but I guess you can keep all cores active [disable power saving options in the bios should prevent lower power states? maybe something in the windows power planes] and the picture wouldn't be changed fundamentally. Might be that test itself is enough to keep the cores awake.
Josh128
Banned
Oct 14, 2022
1,542
2,295
Almost certainly the "core parking" thing they are implementing during gaming is required because of the increased cross CCD latency, not the cause of it. With it over doubling from Zen 4, any game threads that crept onto CCD 1 could bring a massive drop in performance, so they were basically forced to do it or risk Bulldozer'esque gaming regressions.
Also, regarding X3D, the chance that they launch with a greater than 5.3G boost is almost zero. In fact, I'd be more willing to bet that it might top out at 5.2G out of the box and they "will allow the user" to try to OC to obtain more at their own peril. Think about it, Zen 5 barely holds its 1T boost in something like R23 without a delicate X3D chip stacked on top of it, why in the world would we expect significantly higher boosts than Zen 4 X3D?
MS_AT
943
1,868
Almost certainly the "core parking" thing they are implementing during gaming is required because of the increased cross CCD latency, not the cause of it. With it over doubling from Zen 4, any game threads that crept onto CCD 1 could bring a massive drop in performance.
Also, regarding X3D, the chance that they launch with a greater than 5.3G boost is almost zero. In fact, I'd be more willing to bet that it might be 5.2G out of the box and they "will allow the user" to try to obtain more at their own peril. Think about it, Zen 5 barely holds its 1T boost in something like R23 without a delicate X3D chip stacked on top of it, why in the world would we expect significantly higher boosts than Zen 4 X3D?
Any source on Granite Ridge being able to barely maintain boost clock in R23? And could you give a context to barely?
