Page 716 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
gdansk
4,789
8,083
My predictions were far more accurate than Kepler/Adroc's 40% crew.
Actually according to your line in the "Granite Ridge speculation" spreadsheet those troublemakers are still somehow about as close you.
NameIPCFMaxComment
Jayzen5%5.1The hype train has derailed
Kepler_L2 overstated Zen 5 Granite Ridge performance by 1.21x
And AMD's 1.16x estimate exceeds your Zen 5 Granite Ridge estimate by 1.23x.
It's possible you may be the only negative person who is as far off as Kepler_L2 et al.
Markfw
May 16, 2002
27,404
16,255
NameIPCFMaxComment
8 days till we get the real numbers
CouncilorIrissa
788
2,855
NameIPCFMaxComment
See, being negative and cynical automatically means you're smarter than everybody else.
/s
Jayzen
35
89
51
NameIPCFMaxComment
It's 5-10% in most benchmarks, besides AMD's cherry-picked tests. And 5.1 is far closer to what these chips will actually run at in real-world conditions than people's delirious 6 GHz fantasies.
Reactions: exquisitechar
static shock
133
61
61
We are in the era of diminishing gains.
In 2018 when ARM unveiled the Cortex A76 with a colossal >50% IPC gain, they prophesied that going forward there will be only smaller gains. It has proved true. We haven't seen such a large IPC gain from them since.
Had. Zen1 and Golden Cove.
Jan Olšan
626
1,262
Golden cove come in less than a year than Cypress Cove.
You are aware that Cypress Cove was simply the architecture from Ice Lake (Sunny Cove) from august, 2019, I hope?
That makes it two years and something, but Sunny Cove was probably spending some time waiting on 10nm node so the real gap could even be longer in theory.
First the 'M4 was created in 7 months' posting, now this... you guys are totally doing this on purpose, aren't you? :triumph:
GTracing
478
1,114
That what I thought, but IEC said embargo on reviews was 14th
He said 2 chiplet embargo lifts on the 14th. I think he meant the 9900X and 9950X, which are technically 3 chipelts, but only 2 compute chiplets. It wouldn't make any sense for a product embargo to lift several days after the product is on the shelves.
Who is IEC?
A user on this forum, go back a page.
tsamolotoff
261
512
Yes, there is some variability in SPEC. Obviously the main source is the compiler and the optimization options which can change the score dramatically. Other factors that create variability are OS state (often official scores are run on recently booted systems), memory allocation libraries, huge TLB tweaks in the OS, etc.
How compiler and optimization options are related to 'run-to-run variance'? A few weeks ago I've posted several runs of GB that were done one after another with wildly different ST scores (200 pts difference between the highest and lowest). This alone shows that GB test runtime is too short for the CPU to boost properly to the max (and it's not a CPU problem, turboreactive boosting is detrimental to performance in most real-world(tm) scenarios)
MS_AT
941
1,866
C&C measured that Zen4 core can go from idle to max boost in 11 ms. I am not familiar with geekbench that much, but I assume any workload will last at least a 1s so the time to reach boost clock can be ignored as 99% of the test duration should run with max possible boost.
You could try to set fixed clock value [disable boost or do a static all core overclock at fixed freq] what will lower the variance but I guess won't eliminate it because part of it might come from the fact that unless you tell Windows not do so, it will migrate the workloads between the cores. This hurts more if the working data set of the benchmark fits relatively well in the core private caches and I guess geekbench can have few of those ;) Oh and cores are not created equal so each of them have slightly different V/F curve so not all of the might be able to reach the max boost so if the migration pattern is random from run to run you have additional variance source unless you fix the clocks yourself.
It could also help to boost thread/process priority of geekbench if it doesn't do it by itself, to ensure less things will preempt the running benchmark.
Nothingness
3,374
2,475
I was answering your question about SPEC.
These 200 pts are for ST? That would represent ~10%, right? That's too high, I agree. My message gave another source of variation: the OS scheduler and power governor. When doing benchmarking of short programs (such as GB6, but not limited to it), I set it to performance on my Linux machine, because short programs will indeed be affected by frequency raising latency.
tsamolotoff
261
512
On an X3D cpu, good joke (also, if you read a few posts back, that's precisely what I've suggested for ppl trying to compare different CPUs and achitectures instead of playing haruspex with the .gb6 clocks). In any case, I'm not talking about how a user can 'fix' the benchmark, I'm saying that the way Primate Labs does it now can lead to huge run to run variance in ST scores.
tsamolotoff
261
512
As I said, almost everything that you've described is not related to run-to-run variance. What I've meant, is there a discernible variance in SPEC results if you just run the suite (same binary, without recompiling, rebooting, changing anything basically) several times back to back?
Nothingness
3,374
2,475
If you don't understand how scheduler and power settings affect back to back runs, you should read about it.
tsamolotoff
261
512
Oh, I clearly understand it and I even have custom profile for such situations, it is just if power settings and scheduler affect your ST performance benchmark this much, then clearly this benchmark is very flawed, there is no recourse to that. Also, very surprised that I still don't have a clear answer to a purportedly simple question ('fiddle with power settings / scheduling' is clearly not an answer to the question 'what run-to-run variance is there with SPEC(int/fp) suite)
