Page 608 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
SarahKerrigan
735
2,036
Tin foil hat time - I don’t think the 32% number was ever real. I think it was an honest mistake from extrapolating results from what appeared to be legit benchmark scores.
We’ve seen multiple instances where benchmark software incorrectly reports Zen 5 clocks much lower than it’s actually running. We’ve made this same mistake in this thread with Strix GB6 scores. I think this same thing happened with SIR2017 last year and it accidentally spawned a year long hype cycle.
SPEC doesn't attempt to detect clock speeds itself (though it has a bunch of other very handy hardware-detection mechanism) so nah.
AFAIK the whole thing came from some people seeing something that said 96c Turin does 50% higher perf than 96c Genoa, without specified clocks, and started extrapolating it in the most hypey way imaginable.
Markfw
May 16, 2002
27,404
16,253
9654 retail only does 2.5 ghz when all cores are loaded, where the 9554 does 3.5 ghz with all cores loaded, so it should be easy to get fairly decent higher clocks out of Turin.
Edit: I just calculated. 2.5*1.4 = 3.5, so if Turin's base for 96 core is 3.5, there is your 40%, not including avx-512 or internal improvement.
SarahKerrigan
735
2,036
Which is great and all, but irrelevant to what I was saying, which is that somehow "+50% socket throughput" transformed into "absolute confidence in +32% iso clock ST int" (and deliberate suppression of materials against that narrative.)
Markfw
May 16, 2002
27,404
16,253
Well, I think it could be related.....In fact ST int of plus 32% would mean a lot more MT, so lets see.
Edit: I will probably have a Turin, but it may be a while,. I can't afford retail at release. I wait until ebay fills with ES and open box, and gets affordable. But I can test anything you guys want for Genoa when Turin comes out.
Doug S
3,840
6,791
Inferring anything with zero information about what is being tested is crazy. If it was limited by bandwidth and the platform got 50% more bandwidth you'd see that gain without the CPU core changing. If it was limited by SIMD and it got 50% more SIMD throughput, you'd see that gain but it would say nothing about what happens with ordinary real world code.
There are so many potential bottlenecks in a 96 core system I couldn't even list them all. Trying to infer IPC or ST gains from that is like trying to infer world population growth based on Super Bowl viewership.
SarahKerrigan
735
2,036
Indeed! Which is a reason I hope folks view the next hype train with some critical thought.
Markfw
May 16, 2002
27,404
16,253
Since I have both a 64 core and a 96 core Genoa, and see up front the differences, I see temperature/heat per sq inch a big reason for the differences in speed. With a new design and new arch, Turin may have distinct advantages. They are all using SP5 heatsinks and all are 12 channel memory.
adroc_thurston
8,580
11,317
But there was, a lot.
it's SIR2017.
Not really?
This isn't 2005, we're pretty good at multicore designs.
gdansk
4,780
8,072
Many people warned not extrapolate from Turin to desktop.
But I'm still amazed how many pages this thread goes through in a meltdown for what is only a 250-300MHz miss from the AMD average.
Reactions: lightmanek
SarahKerrigan
735
2,036
Yea, rate n.
Oh I never said it was 1t (I think?).
But AMD 1t gains are usually higher than their nT bumps (especially on major tocks), so there's that.
https://forums.anandtech.com/thread...ranite-ridge-ryzen-9000.2607350/post-41182261 ("always lower than the 1t bump")
https://forums.anandtech.com/thread...ranite-ridge-ryzen-9000.2607350/post-41081322 (not immediately related, but aged like milk!)
https://forums.anandtech.com/thread...akes-discussion-threads.2606448/post-41076737 (combined with your post immediately below, where you said that you considered "fat" to mean 40%)
Just what 5 mins of searching came up with.
Joe NYC
4,228
5,829
It seems that Zen 5 +16% IPC while maintaining roughly the same clocks is going to look pretty good next to Arrow Lake, if this ES2 is representative of final release:
BTW, I wonder if my theory of Arrow Lake 2x latency hit (due to chiplet architecture) is the reason for the lower expected performance gain vs. Lunar Lake gain in mobile.
Reactions: Tlh97 and del42sa
RnR_au
2,910
6,502
From memory 25% more power was specified. And the 50% increase was for the nT SpecInt.
Hail The Brain Slug
3,890
3,331
looking at the image he has SMT off ? Core effective clocks should have T0 and T1 if SMT is on.
As if I needed more reason to believe this guy is just screwing with us by doing weird configs that make no sense and no one would do in real life then not providing all the relevant information about it.
Seriously, who disables SMT, uses PBO+CO but tunes PPT down to 60W while using a custom waterloop? And then arbitrarily chooses a random older blender benchmark version?
itsmydamnation
3,139
4,009
yeah fair call,
even with a 1.25x multi to the score its "poor" uplift compared to your score.
Hail The Brain Slug
3,890
3,331
yeah fair call,
If the HWInfo in that screenshot is accurate he's only getting ~25W core power. I reapplied my tuned 6400/2133 config that involves increasing several voltages to bump my misc and soc power but I was still getting 27-29W core power. My increased core power would explain some of the difference.
But that calls into question why his uncore power was so high? My voltages are all tuned up higher than what is visible in that screenshot.
I'll rerun it later when I have a chance with SMT off but in such a power starved scenario I don't know if it will make a big difference. The cores will use less power, allowing them to clock higher by some amount to offset the SMT yield loss.
Det0x
1,488
5,114
Ever heard of Snapshot CPU Polling in hwinfo for Zen cpus ? :)
This option works on AMD Zen-based CPUs only.
When enabled, a snapshot of the entire CPU package and state of all its cores is read at once. This is different from the traditional approach when each core/thread determines its individual state (clock, voltage, etc.), which might cause it to interfere with the actual state. Hence, this polling mode does most accurately reflect the actual CPU state by eliminating the "Observer Effect" to a minimum.
Note, that in this mode some (i.e. per-thread) values might not be available.
Some more information about it on reddit:
itsmydamnation
3,139
4,009
you mean like this from the Zen 3 APU i am currently typing on:
lixlax
208
196
Does anyone still believe that Zen 5 has more than 4 ALUs? The leaks so far suggest that even the 16% IPC gain seem to be a little bit too optimistic.
Is there a launch date given or is it still just "july" for Granite Ridge?
CouncilorIrissa
788
2,855
We've got GCC patches confirming 6 ALU pipes.
