Page 573 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
branch_suggestion
901
1,962
The problem is that such considerations make the assumption that coding and compiler output is optimal, which we all know it very often is anything but.
We know AMD has been investing in compilers heavily for some time, to me being fully blunt this testing is yet another gimped ES (double FP latency and no NOP fusion that should be useful to keep) and Strix is already half SIMD and L3 gimped.
Final Si and software is what matters, and regardless of how Z5 is balanced, the fact is that it really is a big departure from the past.
The GPD data is promising for a higher IPC uplift than observed here, and it also points to very strong nT perf via similar or higher SMT yield.
I'm committed to the 3.65Ghz Strix GB6 run being legit, that has <10% less IPC than Firestorm which is where I'm hoping things end up.
I really don't care if I'm wrong anymore, AMD has already made fools of everyone.
Reactions: carancho
lightmanek
524
1,292
Yeah, the Bulldozer comparisons are stupid because Bulldozer was drastically behind Intel on single-thread perf. That's not the case here - not even close.
If they actually managed a huge jump in MT from replicated frontends, and also a small ST bump in the same gen, without blowing out area, that's interesting.
This will cement a statement - "8 cores is enough for gaming"
It's also interesting to observe how IPC is getting better the older GeekBench is used ...
Can't wait for power tests and more details about desktop Zen5!
Reactions: Joe NYC and Tlh97
CouncilorIrissa
788
2,855
AMD would be screaming from the rooftops if they had 90% of Firestorm's IPC and clocks of 5+ GHz. They aren't.
branch_suggestion
901
1,962
Are they on sale yet?
Have they released pricing yet?
Have they done a proper breakdown of IPC gains and the uArch as a whole yet?
The answer is no, and why would they show all of their cards already when they were patiently waiting for X Elite to go public for a proper comparison?
If they were scared they would show everything and try to end it straight away, but as we've seen that was always going to be a flaming heap.
Intel who are releasing 3 months after AMD are also obfuscating their true gains for now.
Still room to speculate.
branch_suggestion
901
1,962
Don’t forget the low pricing
If the pricing leaks are true that could be for reasons irrespective of relative performance.
Like just pricing more aggressively to take market share at the cost of some margins, which is offset by high margin server products.
and bringing in X3D much earlier.
It comes when it comes, nobody knows the original intended release and whether the ultimate release is early or not.
CES 2025 is the assumption, not the fact.
CouncilorIrissa
788
2,855
No, but we hear rumours of aggressive pricing. Meaning the thing is mid. Other than the iGPU maybe.
They showed something and benchmark selection was dodgy to say the least.
Why wouldn't they? They could've finished the SDXE off before it was released. Qualcomm teased heir 3.2k Geekbench run on a mythical devkit chip a while ago. AMD showing up with 3400-3500 would've instantaneously rendered the competition DOA.
I want that 3.65 GHz run to be true just as much as you do, but there's very little info suggesting that it's the case.
soresu
4,251
3,756
AFAIK Intel and AMD don't compare themselves to Apple in PR.
I think Qualcomm are only doing so because they have literally been boasting that they had Axx µArch engineers working on Phoenix/Oryon.
MacOS still remains too separate from Windows or any serious level of compatibility to its software base on the level of Linux Proton/Wine, in no small part due to Apple's insistence on going their own way with Metal gfx API rather than the open standard of Vulkan, meaning that they cannot take advantage of the work done in DXVK and Zink.
branch_suggestion
901
1,962
The assumption is September, ~2 months after vanilla Zen 5 and before ARL-S.
Now it is, it and the former assumption are both backed up by thin air.
Either date could've been the plan, or the plan changed from one to the other.
Pure speculation.
Wait, how do I get L1 levels of ifetch bandwidth out of L3 area.
This is nonsense.
Engineering samples are always within margin of error of final performance, or so people like to believe.
I will say it again, the data with the most red flags are the weaker Z5 benches, the stronger benches line up far more with known behaviours.
branch_suggestion
901
1,962
The result is nonsense, it sustains L1 levels of ifetch b/w out of L3 region which is physically impossible since L3 bandwidth was literally untouched.
That calls into question the entire benchmark suite.
Oh, and the SPEC run was using GCC 12.3, 14.1 is the first version to officially support Zen 5.
Zen 5 as I've said seems to be heavily compiler reliant for final performance due to the substantial changes vs Z4 requiring different optimisations to take advantage of.
Assuming the Computex results AMD showed off were actually intended for the canceled April thingie, and GCC 14.1 was released in May...
Something doesn't add up, sorry.
tamz_msc
3,865
3,730
I don't see what the problem is with the graphs.
It supports Huang's conclusion that without SMT, Zen 5 behaves as two 4-wide decodes, but with SMT, it can behave as 8-wide decode, with probably some caveats.
It also perfectly explains AMD's cherrypicking of Geekbench sub tests, because the workload characteristics fit perfectly with what has been demonstrated by Huang.
Reactions: Henry swagger
H433x0n
1,224
1,606
Well there’s only a month left. Odds are this is going to be among the most thorough look at Zen 5 outside of probably Anandtech and ChipsAndCheese.
Per David Huang these results have been repeated on Weibo by other people too. We even had that Lenovo product manager say it was +10% int performance a few months ago but we all discounted it. We also have AMD’s slides that state 10-15% IPC which lines up perfectly with this result too.
tamz_msc
3,865
3,730
You're not getting L1 bandwidth out of L3 region under any circumstances.
That's the point.
What is referred to as Bandwidth in the graph is just the rate of instruction fetch per cycle.
A consequence of the source not being a native speaker of English.
The Hardcard
354
448
It has per-thread decoder clusters (better way tho), so it can't be Bulldozer 2 or Piledriver 2, it's clearly Steamroller 2. Or Excavator 2 in Strix (cut down cache, compacted SIMD unit).
when the Ryzen details were announced with all the upgraded front end resources explaining the 40% IPC increase, I wondered at the time how much better the Bulldozer family would perform if it got the same upgrades.
Reactions: del42sa
IronLynx
22
36
61
Besides the difference between L1/L3 BW, there are some odd things with David H's test.
AMD claimed GB5 AES-XTS should be +35%, but David measured less than half the gain.
Is there so much difference between mobile and desktop Zen5???
