Page 572 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
SarahKerrigan
735
2,036
It is just really strange, as it seems like a single thread cannot utilise all core resources, did AMD design what is effectively Bulldozer 2: Electric Boogaloo?
This may blow your mind, but a bunch of structures have been statically partitioned for a while.
(Also, it's entirely possible that in 1t mode, the two frontends work like they do with Atom - early fetch/decode of branch targets.)
SarahKerrigan
735
2,036
To give them ST credit, they're at M3 family levels of performance in geekbench ST (~3000). So basically second best already (second only to M4).
Yeah, the Bulldozer comparisons are stupid because Bulldozer was drastically behind Intel on single-thread perf. That's not the case here - not even close.
If they actually managed a huge jump in MT from replicated frontends, and also a small ST bump in the same gen, without blowing out area, that's interesting.
poke01
4,888
6,233
Yes but they did with a 1GHz boost compared to M3 and we'll have to see power numbers and I don't think they will be close to M3.
In GB5 at 5GHz Zen 5 strix scores around ~2300, M3 does ~2300 at 4.06GHz and M4 does ~2700 at 4.5GHz. AMD still has ways to go.
If we don't take clock and power into account then the 14900K should be the king but its a crappy product.
Reactions: carancho
Hitman928
6,755
12,501
9.71% in SIR 2017.
"In this test, a single Zen 5 thread still performs like a 4-decode x86 core. But when we enable two SMT threads for testing, we can see that the throughput doubles, and the instruction throughput reaches 8 in the L1-L2 and even L3 ranges, and in the DRAM range it returns to the same normal level as Zen 4."
@SarahKerrigan you were onto something, I guess :p
If they increased the die area this much and the main benefit is SMT, that is very disappointing. The AVX/SSE instruction results are also quite perplexing to me where only 512-bit stores are improved but everything else is the same or worse, with int add being twice as slow. I can't imagine that was intentional, lol. I'm not a CPU architect so I can't comment too much, but from an end user perspective, it seems like some misguided choices were made for this architecture. Pending final release silicon results, this is a pretty big disappointment.
Hitman928
6,755
12,501
I wouldn't say they blew the area out, but it is a significantly larger core. Thankfully they were able to somehow significantly decrease their L3 cache size to offset it, but the core itself is still significantly bigger than Zen 4.
soresu
4,253
3,757
they spoiled us with previous Zen iterations
To be fair they also led us on a merry hype train with the RDNA3 dual issue thing reporting twice the FLOPS/CU/clk despite that only being relevant to specific use cases.
Hitman928
6,755
12,501
Huang's tests also don't show the 2x bandwidth in L1 cache, though L2 does show ~60% improvement with a weird spike up to 90% as L2 starts to get saturated.
Abwx
12,034
4,995
In GB6 text processing he measure about 10% while AMD state that it s 19%.
In GB5 and AES XTS he measure about 12-13% while AMD state that it s 35%, so dunno what is the validity of his tests or if frequencies where accurate.
inf64
3,884
4,692
His tests are actually fine, considering that Zen 5 in Strix is castrated in a few ways. I wouldn't be surprised that Granite Ridge gets around 5% more IPC in 1T versus Strix which should put it close to ~16% figure AMD showed. Interesting that SMT might bring bigger uplift.
branch_suggestion
905
1,967
I still don't see how any IPC increase is Bulldozer 2.
I'm not saying it is bad, but a different take on a similar goal of nT spam.
Oh I know, but 1t mode seemingly has more static partitions than Z4 had.
Perf traces are numerous and complex and having as much dynamic capability in a core is desirable over having missed IPC opportunities. Serial computing is hard, I like my parallel dumb ALU machines.
What did you think SMT was for?
SMT is great, but you want to try to avoid having net core performance reliant on SMT use.
Core should have high resource utilisation in 1t mode. Z5 looks very much like a server first core, far more than the previous Zen cores even.
Hitman928
6,755
12,501
Yeah, that is peculiar as well, though there is still the ambiguity of what AMD actually tested since the end notes said it was a MT test. I’m inclined to believe it was just a typo in the end notes but this whole thing has been such a mess, anything is possible.
Hitman928
6,755
12,501
Maybe that explains the difference, but do we actually have evidence about STX being castrated besides these results?
