Page 565 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
techjunkie123
168
368
Do we have any leaks on how strix will compare to Phoenix in terms of battery life under light - medium loads?
I'm really curious what the power/performance curves for Zen 5 will be like. Hopefully they're better than Phoenix and the uncore power is also better!
Reactions: lightmanek
Fjodor2001
4,631
746
If Zen5 X3D will be released already in September, are any of you intending to buy the vanilla variant in July anyway and if so why?
Mopetar
8,531
7,795
I think that's going to depend more on how those parts stack up against the 7800X3D for many people.
AMD has already stated that they don't expect their new CPUs to handily beat the Zen 4 v-cache parts, so I think unless there are some important titles where the new parts are clear winners, that few people will be tempted to upgrade.
Anyone on an older platform will just go for the best chip, even if it's an older Zen 4 CPU since it's the same platform either way. Maybe some people will consider Zen 5 if it's cheaper for similar performance, but the only people who I think will definitely upgrade are those running a lot of AVX-512 code as that's the most obvious advantage that Zen 5 brings to the table.
gdansk
4,789
8,083
Counting the mm2 but double vector bandwidth and a full rate AVX-512?
Doesn't really add up, dis. Seems like a pretty easy cut if they wanted to save area at all costs.
They added some places and took away in other. But that's not unusual.
CouncilorIrissa
788
2,855
Probably a consequence of running the same design on client and server (full rate AVX-512). Good for Turin, but not that relevant for GNR and STX.
DisEnchantment
1,779
6,798
For the Mobile versions, looks like a possibility that they cut L3 cache and some PRF as well, possibly to cut power and cost.
SarahKerrigan
735
2,036
Cutting the PRF (or any other core-private resource for that matter) would be a first for any Zen IIRC?
And would be extremely out of character for how AMD has generally worked.
I expect Zen 5 to largely just be Zen 5, not "here's Zen 5 but with fewer physical registers here, a smaller scheduler there, an extra cyc of latency on the FMA..."
CouncilorIrissa
788
2,855
Yes, usually they design a core and that's what you get across the entire product stack. I think they only customised the FPU for PS5, but that's semi-custom business.
Reactions: Mopetar
SarahKerrigan
735
2,036
Yep. Thing is, parameterization of stuff like that often costs more in dev/validation than you save in an incrementally smaller core variant. AMD has been wise to mostly avoid it thus far.
I think anyone believing that Strix Zen 5 will somehow be a materially worse microarchitecture than desktop Zen 5 is going to be disappointed.
jpiniero
17,200
7,576
Zen 5 was planned before the latest AI meme.
True. But there was enough time to gimp the L3, right?
It makes sense. TSMC isn't getting any cheaper so penny pinching on mm2 is only going to get worse. Strix Point laptops are already expensive enough as it is.
Goop_reformed
316
341
What if the actual uplift is only +10%, that should satisfy both views
