Page 514 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
FlameTail
4,384
2,762
Ladies and gentlemen, I detail to you the approximate Cinebench 2024 MT performance of Strix Point.
They say the Cinebench 2024 MT performance is 30% better than the X Elite.
But first, we need to to know which X Elite SKU it is. According to the footnotes (which somebody has previously posted in this thread), the X Elite SKU used here is the X1E-80-100. That thing has 4.0 GHz Dual Core Boost and 3.4 GHz all-core. It does about 950 points in Cinebench 2024 MT.
This would put the Ryzen AI HX 170's MT performance at 1250 points (130% × 950).
That's a solid +40% improvement over Ryzen 7840HS.
But still not matching M3 Max's MT as @Ghostsonplanets estimated.
yuri69
699
1,252
Apparently I woke up on the darkest timeline side of the bed today since I've learned that MLID was apparently correct.
Tech bros, I'm not feeling so well right now.
MLID published slides that AMD themselves presented. Hypetrain conductors spammed some 3rd party (at best) estimations or even hallucinations. RDNA3 anyone?
poke01
4,887
6,233
its not the same as M3 Max. Different class. Need to compare with M3 pro 5 or 6 P core version
inf64
3,884
4,692
On the right side it says +47% vs Core Ultra 185H. According to CPU monkey that SKU scores 1070 pts in nT CB 2024, so 47% more is 1572pts (unless I fumbled something :D)
FlameTail
4,384
2,762
I never said so. It was Ghost who was saying it was touching the nT of M3 Max.
Hmm🤔
Glo.
5,930
4,991
Sure, but Strix point has 50% more CPU cores than Phoenix.
poke01
4,887
6,233
It’s accurate, it somewhat aligns with R23 result earlier. But at this point it’s using 80watts to reach that score.
AtenRa
14,003
3,362
I dont know if anyone noticed that in the keynote AMD said that EPYC 5 ZEN 5 is build at 3nm for the Chiplets kai 6nm for the I/O , I was under the impression that ZEN 5 Ryzen 9000 is build at 4nm for the Chiplets.
If that is the case, it would be the first time in the ZEN history that Ryzen and EPYC are using different dies.
techjunkie123
168
368
I dont know if anyone noticed that in the keynote AMD said that EPYC 5 ZEN 5 is build at 3nm for the Chiplets kai 6nm for the I/O , I was under the impression that ZEN 5 Ryzen is build at 4nm for the Chiplets.
Dense (Zen 5c) chiplets are on 3 nm while classic (Zen 5) chiplets are on 4 nm. Classic chiplets are used for desktop SKUs.
Keller_TT
161
198
CPU monkey scores are usually in the best case range for all SKUs. So, that's there.
Also, could it be that they're using different TDP configurations for these measurements? The test vs Oryon being a lower comparable TDP and going for the 54W or perhaps higher value vs the Core 9 Ultra? Did they mention anything in the footnotes?
Hans Gruber
2,543
1,372
Originally it was said that Zen 5 would be on N3 (3nn). Then it was N4 (5nm). Now I have read about rumors that Zen 5 will be on N4P, which would be significantly better than N4. I wrote in another post that TSMC wanted their customers to switch to N4P while waiting for 3nm silicon. They offered incentives for them to switch to N4P.
Does anybody know what silicon Zen 5 will be shipping with in July?
Joe NYC
4,244
5,860
I took a crack at scaling based on the image. The die size is pretty similar.
Thanks, I appreciate it. You came very close to his numbers.
As far as official die size of Zen 4, it is alternatively listed as 70 mm2 and 71 mm2, so you are with 1 mm2, which is quite amazing.
So, in view of no change in die size, how does 16% IPC look? Pretty good IMO.
To clarify, the combination of small die size and improved power efficiency are fantastic news for notebook and server markets.
But less than fantastic for desktop / gaming market.
Reactions: lightmanek
poke01
4,887
6,233
the core increased in area which will have an impact in notebook. Going by only the CCD die size can get misleading.
Saylick
4,133
9,650
Lol, getting within 1mm2 is probably purely luck on my part since it depended on which pixel I measured from.
Fwiw, TSMC N4P comes with a 6% reduction in area for logic in comparison to TSMC N5, but 16% higher IPC with a 26% larger core and presumably 34% more transistors (1.25*1.06 = 1.34) is right on the money with respect to the square law of scaling (square roof of 1.34 = 1.15). Not Zen 3 levels of improvement (19% higher IPC, 200 MHz higher max clocks, for 8% larger CCD) but at least Zen 5 isn't under par. I'm hoping that the 16% IPC uplift is true for general performance and not significantly skewed due to AVX512.
