Page 505 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
TwistedAndy
159
150
Maybe it’s time to put this argument to rest? In the last 4 years Apple had more ST gains than any x86 designer, and their rate of improvement actually accelerated with M4. Yes, some of those were achieved by increasing the power consumption (just like anyone else does). There is no evidence whatsoever that they are stalled or hurting for loss of talent. I don’t think that “they failed to increase Clang subtest IPC since 2021” is a good argument. Their IPC there is already ridiculously high. They might be at a practical limit.
Apple M4 has an 8 - 12% IPC increase compared to M1. Most of the performance gains come from higher clock speeds and more advanced nodes.
As for the power consumption, the M4 P-core consumes more than twice the power as the M1:
poke01
4,898
6,238
The 16% IPC increase is a pretty good result. My biggest concern is that it took almost two years to achieve that.
If we take Apple, for comparison, M4 has 8 - 12% better IPC than M1 (in SPEC17 and GeekBench 6 without SME). Yes, during the last 4 years, Apple has had a smaller IPC increase than AMD in 2 years. Most of the performance increase comes from higher clock speeds.
my goodness. The level of defence for AMD. ARM did 16% YoY. 16% in 2 years and a "new" core is not good. Its average.
Apple is stuck atm, we know that.
linkgoron
2,599
1,238
It's bad because AMD delivered moar 1t than that each core.
Pretty simple!
I think it's because some "leakers" and "insiders" have been selling that this is going to be totally revolutionary, and clearly it's not. It's not terrible, but it's not ground-breaking.
adroc_thurston
8,673
11,375
No, it's mid.
The rule of thumb is 25% 1t or more, or piss off.
They've been really, really consistent at not violating that, but alas.
dr1337
548
835
We have results for SPEC for Apple chips and OpenBenchmarking is a joke.
real world performance is always better than synthetic and potentially manipulated benchmarks
open bench is a joke because its real? man, we have user submitted benchmark threads here on the forums, those would easily be as legit... Are you thinking of userbenchmark? the site that is very not legit?
TwistedAndy
159
150
But Apple is increasing clock rates faster than AMD. AMD (and Intel) need to go for IPC because they can't get much frequency. Apple can still get frequency.
Yes, but the power consumption of M4 has more than doubled compared to M1. One P-core in M4 running at 4.5 GHz consumes 7.2 to 9W. If you have 12 of them (in M4 Max), the total power consumption only for the CPU part will be nearly 100W.
Apple has to throttle them down back to M3 levels. As a result, the performance of M4 Max will be nearly the same as that of M3 Max on MT load.
leoneazzurro
1,114
1,867
Nobody really noticed that they used 9950X and 7700X for Gen. Vs. Gen. comparison (GNR-03, probably IPC) ?
What the .... )
Probably a typo in the footnotes, otherwise there would be no sense at all in the scores (no way a 16 core CU can be only +17% in a multi-core test compared to a 8 core CPU, and in the same slide notes all the tests are noted as n-threads). Not the first time slide decks are inconsistent.
Edit: correcting a typo.
Reactions: HurleyBird
Nothingness
3,374
2,475
No I'm not thinking of userbenchmarking :)
I was a bit misleading in my statement, sorry. The problem with OpenBenchmarking is that people misuse it: wrong compiler flags, obsolete versions of SW (for instance some of the benchmarks used to be only optimized for x86 intrinsics/assembly and only got Arm support recently), etc. I basically don't trust the database of results. But I agree the width of applications is great and much more pertinent than other benchmarks such as Geekbench and SPEC.
Reactions: Hitman928
Joe NYC
4,253
5,879
Some of the metrics that are important for client are totally missing (7zip for example), the ones that are included WebXprt & Jetstream it’s 15% and 12% respectively. Also, why would they compare the 9950X v 7700X in the IPC chart? I’m willing to bet it does worse in 3rd party benchmarks than what AMD showed us tonight.
More importantly, who exactly is buying this thing over Zen 4 X3D? It doesn’t meaningfully beat RPL in 1T performance (either worse or at parity in javabloat and cinememe) and probably doesn’t outperform Zen 4 X3D in gaming.. so what is the market for SKUs like 9600X and 9700X?
If price is approx. the same, anyone buying lower priced 7600X, 7700X (rather than 7800x3d) would instead buy 9600x and 9700x.
poke01
4,898
6,238
Good, so about the same as X Elite and Intel/AMD are much worse. Apple will simply kick up the fans in Macbook Pros and this is a non issue on the Studios. Well, this is the result of IPC stagnation..
gdansk
4,804
8,113
If I hear the fans I'm going into low power mode. That's the biggest problem with x64 laptops :mad:
So far I've been able to count on Apple not doing that (unless I was actually doing something).
Reactions: Nothingness
adroc_thurston
8,673
11,375
I'm sorry, but watts (more is better) is the meta and it's not the meta just in server.
X4 toasting like 7W peak in phones was kinda cool, warms my hands in winter for free
Nothingness
3,374
2,475
Oh yeah my P1 laptop is a pain. As soon as it's plugged in, fans turn on :(
OTOH doing heavy SIMD programming, my M1 Pro fans turn on as soon as I launch my program. But it's much less annoying than the P1.
TwistedAndy
159
150
Yep, and that's what Apple will do. I think they can increase clock speeds without major architecture updates for another two generations.
As for the new AMD Zen 5 lineup, it's good enough. It's not something groundbreaking, but a decent update. I'm waiting to see the new Strix Halo with 16C and the integrated LP cores. I hope it will address the idle power issue.
As for Intel, I'm really excited to see the new E-cores (Skymont). If the leaked slides are correct and we will see a 38-60% IPC increase, the HX SKU (8 + 16) looks really nice. As for P-cores, I think we will see a moderate 15-20% IPC boost.
leoneazzurro
1,114
1,867
No, it's mid.
What it is interesting is that no test used for the IPC increase over Zen4 is 1t. They are all multiple threads, of course there are lower threaded tests (like FC6 - which has a strange behaviour with AMD) and higher threaded tests.
What is "strange" in all that is, multi-threaded performance increase is exactly where I'd put it (and I wrote it earlier in this thread that I expected around 10-15% in that) because nowadays it is mostly limited by thermals and power, which are also consequences of the production process. n-thread is exactly where the N4 to N5 process jump allows it to be. Single thread, I think we have to see the specific benchmarking. But all in all, the performance increase is not stellar, so in the desktop arena competition will continue as today. Server is another matter.
poke01
4,898
6,238
balls in Intel's court now.
Gideon
2,044
5,103
The problem isn't performance uplift, its timing:
  • M2 launched June 6, 2022 (~11% uplift mostly clocks)
  • Zen 4 launched September 27, 2022 (13% IPC + 16% clocks)
  • Cortex-X3 launched late 2022
  • M3 launched October 30, 2023 (~15% mostly clocks)
  • Cortex-X4 launched late 2023
  • M4 launched May 15, 2024 (7% IPC + 10% clocks)
  • Zen 5 launches in July, 2024 (16% IPC uplift 0% clocks)
And now lets extrapolate:
  • Cortex X925 will launch late 2024
  • Cortex "X6" will launch late 2025
  • Zen 6 will launch mid 2026
  • Cortex "X7" will launch end of 2026
  • Cortex "X8" will launch end of 2027
  • Zen 7 will launch some time 2028
The issue isn't the uplift itself. It's that we already know that If Zen 6 comes with a "Nehalem" style upgrade (a lot of uncore changes but only ~10% more IPC as promised).
If
AMD continues to execute at that (22 month) pace, Zen 6 will only arrive mid-2026 and Zen 7 comes in 2028. That in turn means that you'll still see about the same ST and MT performance from AMD chips early 2028 that you'll get in July.
I know it's a big if (as is the execution of competitors) but given AMD now has 4 competitors instead of 1 in 2027, they will fall behind, unless they pick up the pace.
leoneazzurro
1,114
1,867
ST and MT performance will be affected also by uncore and process improvements. 2026 means we will see N3-N2 for the cores and in Zen5 a some performance is also related to the IF links/connection to the I/O die. So thinking they will stay static is in my opinion wrong.
Reactions: Thibsie
Joe NYC
4,253
5,879
as a total platform, Strix Point is looking great.
It will be a great APU to get for a laptop.
AMD should really rush to put these into AM5 sockets as APU and sell them as business desktops. It seems AMD is already getting some traction in this category with Phoenix.
