Page 475 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Det0x
1,490
5,121
Question:
In your example of - "Optimal speed" as you put it for 2000FCLK would be 6000MT/s in 1:1 mode or 8000MT/s in 2:1 mode
Would it be correct in saying that the 2000 FCLK and 6000 MT/s in 1:1 would provide lower latency but less throughput than the 2000 FCLK and 8000 MT/s in 2:1?
Or is that not the correct conclusion to draw?
Not sure will like my answer because it will involve a new factor we haven't talked about yet -> nitro mode
For highspeed 8000MT/s 2:1 you would need to run nitro 1-3-1 or more likely stock 2-3-1 (lower delay is better)
You will also need a good 1DPC motherboard if you want fulll boot to boot stability @ 8000MT/s (forget it on a 2DPC MB)
For plain old 6000MT/s 1:1 which every motherboard can run, you can lower nitro values to like 1-2-0 (stock / nitro disable) which will make up some part of the memory speeed difference..
But depending on memory timings, fully optimized 2000/8000 would net you both lower latency and higher bandwidth then optimized 2000/6000, at a much higher price
As a sweet spot for price/performance i would recommend running 2133/6400
blackangus
264
489
Thanks again!
Yeah while I want to get as fast and low latency as possible memory, I also need capacity, so 2 DPC is a must. (Or I wait for much denser memory)
2133/6400 a possibility with 4 dimms?
Det0x
1,490
5,121
Thanks again!
Yeah my 2DPC hero is good upto around 7400MT/s with full stability (can bench at 8000MT/s with countless hours finetuning settings)
Think that will be the norm for good 2DPC motherboards, cap out at the 7200-7600MT/s range with the current generation X670
If you want to compare settings/latency/bandwidth you can take a gander at this ranking
I'm domdtxdissar on that list
eek2121
3,491
5,190
Thunder 57
4,301
7,108
Almost same clock but surprisingly lower TDP
And I was told I was wrong about 170W eight cores not being a thing. Of course I could be eating crow in a few days.
Why? Every TDP is lower or same than ZEN4. 12 Core 7900X has 170W, 8 and 6 Core 105W.
The funny thing is that Adrocs Rumors already begin to seem off, he claimed ZEN5 uses quite a bit more Power than ZEN4.
Good thing they came out in April and we are able to measure these sorts of things. Oh wait...
Thunder 57
4,301
7,108
I get it, you're upset, but no need to vent here.
2 days left.
Fair enough. For the record I hope you are right about the performance numbers. I also like hearing your opinions. I'd edit that out but it's a bit late now I guess. Looking forward to (local to me) Sunday night 🍻.
Saylick
4,133
9,652
No worries, OEMs will be all over Turin soon™.
As long as Dell is in that group, there's a chance.
1717202147996-png.100158
