Page 45 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Anhiel
61
More details, L1 Cache per core is bigger on Zen 5.
A perfect 1.25x increase in line with 4-wide to 5-wide expansion but with same amount each for dispatching.
Anyhow, the given cinebench r23 value is a perfect theoretical match for 64c and +15%IPC. That's suspect. Last time a perfect match was given for ADL and the actual product was 10% off.
But let's assume it's real then with this and given what's said about MTL, and ARL... MTL is no problem but Zen5 won't beat ARL in ST and probably not MT either (with 16c). It's also unlikely Zen5+ can change that either. Zen6 being another refresh will also be in trouble and needs to increase core count to compete in MT. With Intel's follow on products improving further if the leaks are to believed this would be the end for the Zen architecture. AMD might need to rethink about completely new architectures for Zen6 and RDNA5 successors.
Geddagod
1,689
1,724
blinks what?
How much better than RWC do you think LNC is?
Anhiel
61
blinks what?
The leaks say
LNC is 45%IPC over Alder Lake; 20%IPC over Meteor Lake
8-wide
I presume these values are inaccurate or missleading.
theory at best 8-wide/6-wide = 1.33x without anything else accounted for
=> ~24%IPC over RWC => ~29% over RPC
exactly matching leak would be 29% IPC
kind of match leak under my assumption and combined with ~12%CLK ~17%power savings with Intel20A
using stats from https://www.anandtech.com/print/187...ks-review-taking-intel-s-raptor-lake-to-6-ghz
for Cinebench R23
Arrow Lake 8c+16c 5.824GHz/5.488GHz/4.144GHz 105W TDP
for +33%IPC
ST:2958.0
MT:51759.27
for 29% IPC
ST:2869
MT:50202.6
Zen5 16c N4 +15%IPC 8%CLK 6.1GHz/5.8GHz 170W TDP
ST:2543.6
MT:48370.4
Lunar Lake 6c+8c Intel18A 6%IPC 5.8GHz/5.4GHz/4.3GHz 55W base Turbo 157W
ST:3135.5
MT:33958.6
Kepler_L2
1,101
4,781
The leaks say
for Cinebench R23
for +33%IPC
ST:2958.0
MT:51759.27
for 29% IPC
ST:2869
MT:50202.6
ST:2543.6
MT:48370.4
ST:3135.5
MT:33958.6
RWC is not a 20% IPC increase and LNL is the same core as ARL.
Anhiel
61
That's what I wrote with "=> ~24%IPC over RWC => ~29% over RPC" : RWC is only ~4%-5% over RPL
RPC is only ~3% over GC
In case there's a miss communication due to arrows used:
"=>" this is a conclusion arrow or next step arrow
"->" this is a connecting arrow or lineage arrow
H433x0n
1,224
1,606
blinks what?
The guy you’re responding to seems to be jumping the gun a bit since we don’t really know what to expect from Zen 5.
However, going by historical trends I don’t think it’s a stretch to say it's going to be a big task for Zen 5 to keep up with Arrow Lake. Whenever Intel jumps a full node (22nm -> 14nm and 14nm -> 10nm), it's always been a solid >20% IPC jump. With Lion Cove being 2 full iterations ahead of Raptor Cove coupled with a healthy node improvement from the current Intel 7 process I would be absolutely shocked if Lion Cove doesn't end up at 30% IPC ahead of where we are at now.
I wouldn't bet anything that I care to lose that they actually hit their timeline but for this theoretical conversation, if Zen 5 were competing directly against Arrow Lake they would likely have to bring >20% IPC gain to be at parity.
Reactions: yuri69
19,219
Even if Zen 5 fails to overtake its future competition, it would still be power efficient coz that is AMD's philosophy in CPU design now. Intel can keep their "too hot to touch" CPU crown. Zen 5 laptops will still deliver better battery life.
H433x0n
1,224
1,606
The efficiency is in large part due to the node. That’s why my inner geek *really* wanted to see both Zen 5 and ARL-S on TSMC N3. I would love to see that comparison but it seems we’ve been robbed of that opportunity.
Reactions: Henry swagger
soresu
4,259
3,757
Lol it looks like I was right back in 2019 😂
The CCD based on the upcoming "Zen 5" microarchitecture is codenamed "Eldora," and the "Zen 5" CPU core itself is codenamed "Nirvana." There's no codename for the CCD based on "Zen 6," but its CPU cores are codenamed "Morpheus."
I'd say think K8->K10, rather than Excavator->Zen in terms of change - I think if they meant to make such a dramatic change, they would give it a more interesting/less incremental name than Zen3 (hint hint AMD, Nirvana is perfect!).
A///
4,351
3,160
that would depend on whether the Mike Clark interview was out at that time. nirvana in buddhism means to be released from the cycle of birth and death. To start anew would be a stretch to the word. Either way it's the perfect code name for AMD to use. Clark pushed his statements of Zen 5 being a huge game changer.
We now know thanks to the linkedin prolapse of an employee's work those code names and some info about zen 6, specfically for epyc but you take what you can get!still a good guess on your part mr @soreu!!!!
i had more to say but I've forgotten what it was after I got distracted by your reply, it was probably about the same codenames.tpu users seem to think palladiums are still used.
soresu
4,259
3,757
What? Not the alt-rock band. So disappoint. :p
I made a vague guess based on Zen itself, and the Zen based µArch (AMD/Chn JV) called Dhyana, which is also a Zen like elevated mental state related to the practice of Yoga.
But ye, I chose Nirvana from the list of related word cos I lek mah Lithium 🤘🏼
soresu
4,259
3,757
Mike Clark randomly repeating himself that IPC isn't everything. Zen 4 IPC is quite conservative, but out of all the new generations in the Zen family, it brings arguably the most amount of perf uplift in a single generation.
Depends on the workload.
For SIMD heavy taks that is almost certainly Zen2.
Hoping that Zen5 brings another similar boost along with the scalar IPC improvements.
Exist50
2,452
3,106
I think people are giving far too much weight to names. A codename is ultimately chosen because someone sufficiently high up thinks it sounds cool, and possibly with some input from legal. There need not be any deeper reason, fun though it may be to speculate.
Saylick
4,154
9,695
So you're saying if AMD ever had an internal codename called "Intel Killer" or "Da Monster", we should brush it off as some high level engineer's pipedream... Got it.
Joking, of course.
