Page 385 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
adroc_thurston
8,618
11,340
Halo is expected for 25Q1? Q2? Did it change with the recent rumor of Zen5's simultaneous rollout across the lineup?
CES'25.
Either way, I am starting to see what you mean about multiple chips w/ different configs but sharing the same IP.
Yeah they basically rolled DT/luggable parts into mobile instead of server.
Ghostsonplanets
774
1,228
I think he already shared the timeline for Z5 rollout, no? iirc:
May/June - Strix Point (Could be MS AI build event or Computex). Release in July or August
June - GNR (Computex). Release in Q3/Q4
Jan - Kraken Point and Strix Halo (CES 25). Release in Q1 25
Sonoma is ???. But probably isn't that long given it's a socket upgrade over Mendo.
Reactions: Tlh97 and carancho
Markfw
May 16, 2002
27,406
16,255
and which is desktop ? losing track....
H433x0n
1,224
1,606
GNR is desktop.
Afaik, everything gets announced at Computex. Both server and desktop have availability 1-2 months later. Strix Halo announced at CES 25 with availability in Q1 2025.
carancho
55
45
Will Halo feature in workstation class notebooks? Just saw in NotebookCheck than the high end P-line ThinkPads were updated to the newest Intel processors. It seems unlikely that they update then again in Q1. It would be a shame if Halo were only available in gaming laptops.
Joe NYC
4,239
5,857
No.
Useful for laptops tho, can cache display/media hits.
Yeah, that's what I was assuming.
But that could be different in server if there are some 8-16 CCDs potentially hitting the memory attached, such as potential Mi300c or potentially Venice. I wonder if Venice has MALL...
adroc_thurston
8,618
11,340
Reactions: Joe NYC
Joe NYC
4,239
5,857
Sonoma is apparently very low end mobile, 0x Zen 5 + 4x Zen 5c cores, also with smaller iGPU. There are some rumors it might be fabbed by Samsung Foundry.
Oh yeah, GNR is desktop.
Goop_reformed
316
341
So weird all the talks about ipc seemingly vanished overnight, as if the actual results are now in the wild and people have to be quiet about it. Weird.
Reactions: Thibsie
DisEnchantment
1,779
6,798
Very high score at those frequencies.
its literally double of virtualized Zen 2/3/4 cores at ~1.5 G
Or could be GB5 cannot read the frequencies properly inside Xen
Could be spoofed results, I would be wary too, never know. Also its virtualized.
Fjodor2001
4,637
748
two 8 core CCDs!
16 big cores. You don't need anything more!
So you are suggesting 16C Zen6 will have better MT perf than Arrow Lake Refresh 8P+32E?
If not, then persons primarily needing max MT perf at reasonable price on DT should get Arrow Lake Refresh instead of Zen6 DT?
Yeah, mobile includes luggables/mobile WS/halo all that stuff.
SOC tiles share the IP, but not configs.
Mobile and luggables use different SOC tiles.
So Zen6 DT will use same SOC tile as Zen6 Halo?
And iGPU and NPU is not on the SOC tile, but on the IO tile? Also, Zen6 DT vs Zen6 Halo will use different IO tile meaning they’ll have different iGPU and NPU (although DT will not have any NPU on its IO tile from what you said)?
In that case an SFF PC based on Zen6 Halo might perform close to Zen6 DT in CPU bound tasks (if like we saw with Zen4 that the last few extra Watts do not bring much extra perf, e.g. when comparing 105W vs 170W). Plus such an SFF PC have the bonus of much better iGPU and NPU for those that want that.
PS. Why are we now using Intel lingo, and calling the separate dies ’tiles’ instead of ’chiplets’? Will AMD switch over to using Intel terminology for Zen6?
adroc_thurston
8,618
11,340
Fjodor2001
4,637
748
It doesn't have to.
Not for your use cases perhaps, but for others. More specifically those that need max MT perf on DT at a reasonable price. Sounds like Arrow Lake Refresh will be a better option for them, if there will not be any Zen6 DT variant to counter it.
They can get Threadrippers.
Or EPYCs. But they are not reasonably priced (for most persons using them for private use). Arrow Lake Refresh 8P+32E should be much cheaper compared to lower end Zen6 Threadrippers, for those looking for max MT perf in that range.
How did you even come to this conclusion.
Well, you're statements were not 100% clear, so I had to make some guessing.
This was the discussion:
But are you suggesting DT will share dies with mobile?
So Zen6 DT will at least share SOC tile with one of those as I assume it.
But if Zen6 DT will not share SOC tile with Zen6 Halo, then which mobile Zen6 variant will it share SOC tile with? Or are you suggesting Zen6 DT have it's own SOC tile only used on DT after all?
Rekluse
36
46
61
So Zen 5 Desktop is confirmed to be 16-core max on desktop, with no Zen5c variants coming to AM5
Does Zen 6 push past the 16-core Desktop limit on AM5 ?
adroc_thurston
8,618
11,340
People that need nT have money.
For Threadrippers.
Please stop crying.
Reading and bracketing adjacent market segments isn't hard at all.
Reactions: spursindonesia
Mahboi
1,058
1,969
To summarize, Zen 6 things should be pretty clear by now I hope...
- Will use CCDs + IOD for pretty much the entire client stack, from ultrabook chips to mobile workstations to desktop. CCDs remain the same, but IOD will differ depending on product.
Ghostsonplanets mentioned that it's likely that Zen 6+ starts dividing between TSMC eVLT and uVLT (differences in performance and power at low usage). Most likely with Zen 6c using the lower power stuff and ending up on mobile.
Also, there's several signs that this won't be the case already with Zen 5, such as Sonoma Valley using Samsung SSP4( or SSF4, I forget).
- Mobile IODs will have Infinity Cache and varying levels of iGPU and NPU performance depending on the use case. I hope that mobile IODs have a low power core so that the CCDs can be shut down in period of low activity.
I'm not super sure that CCDs can be shut down correctly, can't remember where I mentioned shutting down cores but I was basically told "nah, rebooting/resyncing is making an unacceptable latency". Although that was for GPU and memory so maybe that doesn't apply so much on CPUs but I doubt that you can entirely shut down CCDs. I wonder about a really low power mode though.
Desktop IOD won't have the Infinity Cache or an NPU but likely keeps a small iGPU for basic display purposes.
Isn't Strix Halo precisely the contrary? I think Uzzi mentioned that it's sort of the basis for DT's future.
Doesn't seem like they'll be having only small iGPUs...
- Infinity Fabric over CoWoS-R is what connects the CCDs to IOD. This should be pretty similar to what N31 uses.
Yay N31 redemption arc
- No mixing and matching of CCDs regarding Zen 6 Classic/Dense. CCDs are all Zen 6 Classic.
What about those Z1/Z1 Extreme type SKUs? Those are mixed, I don't see why they would stop? Even Kraken is mixed IIRC.
- My guess is that the Zen 6 CCD will likely still support 3D V-cache. You'll get V-cache in desktop. No idea if you'll get it on mobile.
I doubt that they'll drop 3D V$ anytime soon. On the contrary, it may well become a "forever" staple of all x86 vendors.
Mahboi
1,058
1,969
Why would it?
Why do people still have this weird fantasy that multicore is faster?
Multicore has diminishing returns for almost all applications. You don't need more than 8 for 95% of DT apps, don't need more than 16 for 99% of DT apps. The rare case of needing more is in server.
