Page 365 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
tamz_msc
3,865
3,730
So RGT claims that the 9950X or whatever it is called is going to score ~170 pts in CineBench 2024 ST. Is it in line with expectations of folk around here?
tamz_msc
3,865
3,730
The people around here are making claims regarding SPECint 2017 so not really comparable like that.
That wasn't the my question - I asked about people's expectations with this "leaked" score of 170 pts, not directly related to claims from people with either a spotty track record at best or none at worst.
Timmah!
1,572
935
The 5930K launched late 2014, that would put it close to Titan X in early 2015. According to TPU perf charts, the 4090 is 5 times faster than the Titan X. Using the same ballpark system, 7950X is almost 3x faster than i5 10400. Factor in the clock advantage and some IPC improvements, and we're probably reaching 4x perf advantage over 5930K.
So, if 4090 is 5x faster for 80% more dollars, then the 7950x can be 4x faster for ~60% more dollars. The CPU should have launched for $960. /s
I presume those TPU perf charts are based off games. Those are not exactly good measuring tool of pure performance, too many other factors affecting those. Compute apps are. In something like Octane Render Titan X scores about 120 points. 4090 scores 1200, while having double VRAM (which is as important for rendering as the performance of the GPU chip itself - though its not reflected in that octane benchmark number).
FlameTail
4,384
2,762
How much memory bandwidth would an NPU, of say... 50 TOPS, need?
Is there a standard figure like for example: "1 TOPS of INT8 = 1 GB/s memory bandwidth" ?
Joe NYC
4,242
5,859
7950X is 5.55x faster than a 5930K in Cinebench R15.
This is just my opinion: For client applications, comparing CPU A (5930K which already has enough cores) to CPU B, the key comparison becomes single core performance. So, Cinebench multicore is the worst benchmark to use.
Geekbench 5 is popular enough to be able to get reliable results for all CPUs and has a separate single core test. Much better bench to use. Geekbench 5 single core results:
CPUGeekbench 5Performance vs. 5930l
5930k984
5800x1728+76%
7700x2202+124%
7800x3d2137+117%
7950x2215+125%
Better than +100% performance increase is a good time to upgrade, too bad it took 9 years. Which, BTW, was when I finally upgraded from 5930k to 7800x3d.
Here are the MSRPs of the CPUs at launch:
5930k: $580
5800x: $449
7700x: $399
7800x3d: $449
We will see where Zen 5 based CPUs (9800x, 9800x3d) land, as far as 1T performance but the rumors are encouraging. And the fact that this is precisely where AMD emphasis was (compared to Intel E-Waste).
Decisive advantage in nT performance brought AMD to the top of datacenter CPU performance, hopefully, decisive 1T performance will do the same to client CPU market (where AMD has pitiful 15% of $ market share).
gdansk
4,802
8,105
Budget-sensitive people won't be running for it but what's your point? If it's 40% faster then expect an absurd price. All that other stuff about more cores and types of work doesn't matter. If it's that far ahead of the competition they can charge whatever they want.
I don't think it will be even 25% faster and so will be cheaper than $800.
Fjodor2001
4,647
748
The point is that this logic does not apply to the Zen5 DT variants with the most cores only (like some have claimed), but for Zen5 in general.
Flame bait removed.
Anyway, outside the US the economy is very weak. The USD is extremely strong. There's inflation, and salaries are not keeping up. Customers are very price sensitive. Zen5 will not sell well if AMD will bump the price. The customers are expecting stable or lower prices when comparing Zen5 models to corresponding Zen4 models. Or they'll go with the competition from Intel, Qualcomm, et al. Like others have mentioned, the competition will be fierce. Everyone want to keep or gain market share.
It'll be brutal competition. And customers will not be prepared pay substantially much more just to get a few extra percent performance compared to the alternatives. Only niche of niche enthusiasts will do that.
Stop with the inflammatory comments already. First rule of fight club/CPU forum is attack the post not the poster. The second rule of fight club/the CPU forum is attack the post not the poster.
-CPU mod DAPUNISHER
Mahboi
1,058
1,969
That's not how that works.
If my choice is a $270 Z4 6 core that's 110% the performance of a $250 Z3 8 core, then I'm getting more bang for my money with the more expensive one.
If Z5 really is 40%+ more INT perf, it can afford to be massively more expensive and still sell. And ST is still king despite all the MOAR COARS crowd' screaming.
The problem with your reasoning is that it applies to, say, any Z5 chip that's performance competitive. Which isn't a lot of them since again ST is king.
Starting 12 core, there isn't going to be a single Z5 chip that has competition even among multicore workloads.
Intel's net income is already at 1%. They can't compete any lower, or only with token discounts.
You're reading the situation very wrong.
Timmah!
1,572
935
I think you are overestimating most people’s willingness to spend money on something as non-essential to life as faster CPU.
You can bet, if 8 core Zen5 is 40 percent faster than Zen4 (and subsequently say 20 percent faster than 7800x3D in gaming), and its priced at 500+, utter majority of people will without hesitation go after 200 bucks cheaper older cpu and put the money they saved into faster GPU or whatever else. Cause they are on budget. Only small group of PCMR kind, who have to have the best of the best alongside their 4090s will pick Zen5.
This AMD can price whatever they want cause they have no competition is nonsense. They will be competing with cheaper and older products, that are not significantly worse. Did 7000 series Ryzen make 5000 series obsolete? Course they did not, those CPUs are still absolutely fine. Even 40 percent speed-up is not some be all and all, like its presented here, that everyone and their mother will run to buy money no object on day one, as if it somehow revolutionized computing. Its not quantum computer for gods sake. Its another incremental performance bump, that Most people wont be able to perceive in 95 percent of situations. And certainly wont feel the urge to randomly pay double for it than what they were used to, because apparently there is no competition.
Mahboi
1,058
1,969
I use a 5600x. I'm not overestimating anything.
There's different tiers of buyers and they have different reasons. Those who want a 16 core are rarely doing it for the fun of it, as Igor said, they either don't care how much they spend or are professionals who will spend highly hoping to work faster. It is you who think that because you consider CPUs based on perf/price, others do. Most others who will splurge on a 14900k or a 7950x do so because they expect huge perf or because they expect returns.
19,218
Those same customers will also have the option of getting Zen 4 (or staying with one if they already have it). Why is it so hard to understand that AMD will price Zen 5 above Zen 4 until Zen 4 stocks run out? Then they will price Zen 5 at Zen 4 prices. Their first priority is to sell old stock. They can't just introduce a new CPU family and let it cause the old one to become worthless as crap. I'm not privy to their wafer supply agreement with TSMC but I bet they are STILL producing Zen 4 CPUs in some of the "older" TSMC fabs. Those CPUs need to sell out otherwise it's a total loss for AMD. So once more, in the beginning, Zen 5 stock will be unable to meet demand. That will keep prices high and some disappointed customers will buy Zen 4 or Intel or whatever coz that's all they can get their hands on or coz it's cheaper. Once the supply situation improves and Zen 4 stocks start dwindling, we will start to see Zen 5 sell at Zen 4 standard prices and Zen 4 will top the best deal of the week or month lists for a while until it is no more. Nothing too hard about that, is there? That's how the market works. Same thing happened with Zen 2 and Zen 3.
19,218
OK, just promise not to be dishonest/hypocritical and not report buying a Zen 5 at launch and silently using it for 6 months before telling us here :p
itsmydamnation
3,140
4,010
The amd of Polaris is dead , it's time for some people to move on.
I'm all on the zen5 being a monster because amd have shown over 4 generations they can deliver high gains at the same sized /resourced core. So I believe they will further extact more performance per resource while making most resources pools significantly bigger.
And thus I expect pricing to allgin to that.
Mahboi
1,058
1,969
Bit funny to read when you know that RDNA 4's biggest SKU will be 240mm² lol.
And thus I expect pricing to align to that.
Reactions: Mopetar
Goop_reformed
316
341
It kinda is. You're just trying to justified your own bias. In what universe is 40% not considered a large jump?
Not quite. AMD was hyping the unreleased product using unrealistic perf/W gains in both Polaris and RDNA3 cases.
And how many amd products have been released besides Polaris and RDNA 3?
linkgoron
2,599
1,238
RDNA1 was good, and RDNA2 was even better. RDNA3 was bad - no doubt about it. The fact that AMD basically lied at the presentation made it worse.
RDNA4 could be decent, although given that we're seeing a mid-sized die at most, I can't say I'm very excited about it. AMD abandoning chiplets for RDNA4 after the Navi 31 and Navi 32 failures basically shows that something is not working as they expected, but they didn't have a backup plan so now we're stuck with Navi 48 and Navi 44.
Reactions: Tlh97
DisEnchantment
1,779
6,798
Some people still don't believe that RDNA 3 was an industrial accident it seems...
Does it matter if people believe or not? People could not care less what may or may not have happened at AMD. Bottomline is that the product was not what it was hyped up to be.
The numbers may or may not be realistic but it is all fine and good knowing we are speculating. It might as well be greater, probably.
But when it gets dished out as facts it starts to get annoying.
You see, it is possible to have access to classified information but still acknowledge there are chances it may not be 100% true or to acknowledge that not everyone accept everything as fact until everything is out, below is a refreshing example.
Again, even assuming the numbers are true
Mahboi
1,058
1,969
I may have phrased it wrong, the problem is not whether people believe in what RDNA 3 should've been. RDNA 3 had a flat promise of 50 + 50 in perf and efficiency.
This follows RDNA 2 which had the same promise and succeeded (exceeded).
Which also follows RDNA that IIRC had also the same ballpark expectations.
The problem is that there is healthy scepticism and unhealthy scepticism.
Healthy skepticism is "I'm promised mad stuff that makes no sense".
Unhealthy skepticism is "there is a general pattern of this amount of growth, and then there's the disappointment".
RDNA 3 held a promise that was in line with what was there before.
Betting based on patterns is sensible. Betting based on the exception to the rule because you've been very disappointed is silly. It's an emotional reaction, not a factual analysis.
Has AMD managed to make large jumps in the past despite sticking to a smaller core? Yes. They've even managed to essentially take a broadly identical Zen 2 core and to bump its perf on the exact same node all the way to Zen 3. Just by bundling stuff better (8 core with unified cache instead of 4) and some tweaks. Then they jumped up a node to 5nm and tweaked minor things over Zen 3 and made Zen 4.
All of this is with "ticks", not "tocks".
Now, we get a promised Tock. A big tock. One with a wider decode, one with a radically reshaped core.
Studying the patterns, is it credible that the corpo that took 20% improvement with a tick on the same node, 20% improvement with a node jump and some tweaks, can come out with a huge 40%+ improvement with a Tock?
Yes. Very much so.
The facts of Z5 I do not know.
The facts of Z2/Z3/Z4, I do.
So unless you think this is all a giant troll/hoax and that Z5 is actually not a tock, not a large reshape, and is still on a 6 wide decode and we're all being Master Trolled by Kepler & Adroc, I'd say the odds are very, very, very high.
You see, it is possible to have access to classified information but still acknowledge there are chances it may not be 100% true or simply acknowledge that not everyone accept everything as fact until everything is out.
This is why I say 40%+.
I have heard other rumours that would stick us closer to 50% than anything else. I'm also lowballing with 40%.
DisEnchantment
1,779
6,798
I do believe quite a few. I find Kepler, Xino etc to credible and I wait and hope for things they say come to pass
But my belief != fact.
I believe that I will successful in my career. This does not mean that I am until things are unfolding before me.
I also have a soft spot for AMD, I bought a lot of AMD shares in 2017 (between 9 and 11 USD each) , little did I know they will grow this big. I have no more AMD shares, already cashed out.
This does not mean I crap on everything else.
I created this account exactly one week before I received my first Zen CPU. I knew there is potential with Zen, I invested in AMD stocks, pre ordered the CPU and got excited about it. Only thing is that if I waited long enough before cashing out, I could be planning my retirement right now. But one thing I dont like is how this forum evolved.
Stilt was active back then and folks like Dresden Boy, retired engineer, etc, putting out rich technical posts.
Now it is an echo chamber for wannabe leakers.
