Page 299 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
NostaSeronx
3,815
1,294
Eh?
I thought AMD shuttered their Dhyana joint venture after the trade sanctions ramped up?
Xiaolong is the chinese name for EPYC not Hygon-related. Hygon switched to RISC-V after:
"However, in [June] 2019, the U.S. Department of Commerce added Haiguang to the entity list. AMD cannot continue to grant the new generation of Zen architecture to the joint venture, and Haiguang can only design and improve on Zen 1."
leoneazzurro
1,114
1,867
So how long do we usually see from bonding to consumer available?
In a normal situation, after bonding you'll have packaging finishing, testing & binning, delivery. These steps should not take a lot of time. But, when launching a product, normally you want to execute a ramp up of the capacity, and an inventory building. And you'll need to launch the BIOSes for the hardware support on the motherboards' side. So it depends mostly on these factors.
Reactions: lightmanek
yuri69
695
1,246
Official public support of Vermeer on AM4 arrived ~month prior its launch IIRC. There surely are dev platforms with dev BIOSes supporting Zen 5.
So as always with an existing platform - we first need some BIOS activity (MCExtractor & co.) weeks prior launch.
19,204
Why give it a different name? Do Intel Core or Xeon CPUs sell in China with a different name too? I'm guessing Xiaolong may have dedicated instructions to accelerate their domestic encryption standards.
Tigerick
932
847
Must be nice for folks to be able to order their Zen 5 CPUs in April, with an awesome 32% IPC bump. Too bad for the clock regression and the 999USD price point for top end. It s just a few weeks before the reviews hit your favorite YTer.
Haha, so salty.... :p
Tigerick
932
847
Guys, I think I know how the discrepancy between the points of Zen 5 coming from:- Based on leaks from RGT, I know but please bear with me:-
  • ST performance of Zen5 range from 12-20% better than Zen4.
  • MT performance of Zen 5 range from 12-25% better than Zen4, slightly better compared to ST.
  • Surprising, GeekBench 6.2 MT's score is scaling much better than CineBench.
  • We don't know final clock speed of Zen5, but the 3500 GeekBench points should be good indicators of final silicon. Then where the 40% improvement coming from?
Tigerick
932
847
  • It might be coming from Strix Point APU. Per iso-power, Zen5's ST in STX is scoring 3400, that is improvement of 38%. MT's score is almost 80% better thanks to extra Zen 5c cores.
  • There are weird results about ST scores between desktop and mobile; Desktop scores are only slightly higher than mobile version. Not listed in the table above, Cinebench's ST scores are 140/130 for desktop and mobile; like Geekbench scores.
  • If the results are correct, I think Zen5's architecture with ladder L3 cache is designed to be power efficient with scalability in design. AMD is preparing to scale core counts from 8 to 16 (Zen 6) and then 32 cores (Zen 6C). That's why I am more interested on upcoming Zen6C with 32-core. Theoretically, Zen6C's MT should score above 40000 points @ 170W TDP, let's see how things turn out..
inf64
3,884
4,692
Points per watt for ST results is not valid as we cannot take the total TDP when calculating that metric. ST power draw is very different for all those CPUs.
StefanR5R
6,819
10,889
It's not even valid for MT benchmarks.
a) Not all MT benchmarks are power-bound. That is, power use ≠ power limit.
b) TDP is only one power limit among several, and in case of desktop CPUs, about the least relevant one.
Reactions: Tlh97 and gdansk
eek2121
3,467
5,124
TDP != power.
nT performance is almost always limited by some combination of architecture/power/thermals (the TDP thing you mentioned)
If a piece of software isn’t utilizing 100% of CPU, it is waiting on something else or isn’t designed to use 100% (example: system services) and usually makes a poor benchmark.
Schmide
5,755
1,049
TDP != power.
It doesn't equal power per say, but in the same way watt hours != watts (we all say watts). TDP is a power limit over time.
Not all algorithms can use 100% of the cpu. Some are memory bound for example but that doesn't make them a bad benchmark.
You could say they are not a good benchmark of TDP, but they can be a good benchmark of power as long as they are consistent and repeatable over time.
Tuna-Fish
1,688
2,581
Or it could be starved for memory bandwidth, something that's entirely reasonably a problem for a lot of real loads with DT 16-cores. Or it could involve a lot of pointer chasing, and so spends most of execution time waiting on memory latency, which is a reasonable way for a benchmark to act because this describes a lot of important software. (Think all business software written in Java and that take enough memory to not fit the hot set in cache.)
adroc_thurston
8,066
10,801
Or anything javascript which is a branch prediction competition first and foremost.
moinmoin
5,248
8,463
Recording joules per workload would solve so many of these issues, but alas still nobody bothers doing benchmarks like that.
Reactions: Joe NYC
