Page 288 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Abwx
12,033
4,995
im still waiting for the low ballers to explain how from zen 1 to 4, core width didn't grow and OOOE window increased a small amount ( especially relative to others ) while doing ~ 50% more ipc and yet going to 6 wide plus a whole new fronted we know nothing about except its big shinny and new and we are getting -5 to 15% with clock regression.....
its not like there arent cores that size with that much more IPC on the market.
RGT is at it again these days, with the usual +30% IPC speculation of course but also no frequency regression this time, he even risk 6GHz as being possible...
Reactions: lightmanek
Fjodor2001
4,633
748
Although he seemed to get the details about the Zen 5 delay right
How do we know if there has been any delay, when no official release date has ever been communicated?
Could be that whatever the release date finally is communicated as was what AMD was targetting from the start anyway.
Kepler_L2
1,089
4,703
I’ve had more than 1 person tell me that CB R23 1T is >=2800 which is a >=40% increase. If I had to take a geomean of Zen 5 leakers it’d probably be a 40% 1T perf increase overall.
I don’t personally believe that but it’s at least consistent. The only person saying it’s not hype™ is MLID who’s track record is spotty. Although he seemed to get the details about the Zen 5 delay and 800 series chipset right .. so ymmv.
That was on A0 silicon which had a clock regression :p
19,218
So things looking great for Zen 5 but AMD decided to take some extra time to iron out all the kinks, have a stable BIOS at launch with decent RAM speeds and may even launch X3D simultaneously coz by then they would have built enough stock already.
FlameTail
4,384
2,762
Can we do a microarchitecture comparison of Zen 4, Raptor Cove(or RWC), M3 P-core and Cortex X4?
Decoder Width
Dispatch width
ROB size
Etc...
19,218
Zen 4 4-wide
RPC 5-wide
RWC 6-wide (re-compiled software could theoretically run faster than Raptor Lake Refresh)
Source for above 3 is ChatGPT (please correct if it spitted out misinformation)
M3 width probably no one knows. M1 is supposed to be 8-wide according to this: https://news.ycombinator.com/item?id=25394447
X4 10-wide (yowza!)
Zen 5 possibly 8-wide
Wow. Looks like ARM is shooting for the moon.
CouncilorIrissa
788
2,855
Zen 4 4-wide
RPC 5-wide
X4 10-wide (yowza!)
Intel's P-cores have been 6-wide since GLC.
edit: there's also a uarch block diagram repo: https://drive.google.com/drive/u/0/folders/1W4CIRKtNML74BKjSbXerRsIzAUk3ppSG
majord
509
711
I think you need to look back at Excavator's front end , including op cache , before being too surprised at Zen's current IPC despite only 4 decoders. Pushing any more IPC out of it , i.e Zen 5, without going wider? , yeah that will start to get interesting.
AMDK11
496
441
Zen 4 4-wide
RPC 5-wide
X4 10-wide (yowza!)
Zen1-Zen4 4-way x86 decoder
Conroe(Core 2) - SunnyCove/CypressCove 4-way x86 dekoder(1+3)
GoldenCove - RedwoodCove 6-way x86 dekoder(6(1+5(?)))
FlameTail
4,384
2,762
What does 1+3 / 1+5 mean?
Also why specify it's an x86 decoder? We know it's an x86 core.
19,218
Ooh. Is Intel the only one doing this?
RISC has far fewer instructions than CISC, and each basic instruction is executed in a single clock cycle. CISC's instructions can be complex and perform multiple tasks in a single instruction. CISC's complex instruction set makes x86 chips harder to design because the chip has to be able to account for the complex instructions, making x86 chips typically more expensive.
Because RISC uses simple instructions and tends to use less power per instruction, this makes ARM chips ideal for devices that need longer battery life.
So all x86 CPUs should have at least one complex decoder. ARM doesn't need one.
Reactions: Tlh97 and FlameTail
JustViewing
272
478
In AMD terms,
Dispatch = Macro Ops,
For Zen4, in theory for 6 Dispatches there can be up to 12 micro ops.
Zen4 can have peek execution of 14 micro ops. It won't be sustainable of course, bottle necked by front and back end. In addition to this, few instructions can be resolved within scheduler like mov reg,reg, load imm etc.
Tuna-Fish
1,695
2,606
Zen has been 4 wide/6 dispatch all the way from Zen 1 to Zen 4?
That is crazy.
Zen is wider than 4 if you run from the uop cache. The cache can deliver up to 9 uops per clock, but alignment restrictions reduce average throughput. The pipeline after that (crucially, rename) is 6 wide.
I think AMD decoders are more flexible, but this is really not something that actually matters much. As a rule, complex ops are slow and if you have plenty of them you are not going to be limited by decode anyway.
