Page 245 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
poke01
4,881
6,223
What I find interesting is that there are NO negative views or leaks that I have seen on Zen 5. Unlike Intels latests that are marginally decent, but not even the best !
Arrow Lake is meh. Lunar is great but that is low power not desktop. AMD will own desktop for a few years more imo.
Saylick
4,129
9,649
Well, it’s got the same IOD as Zen 4, which is arguably a bad/sad thing. Probably means Zen 5 can come faster to market but could have had some improvements to the memory controller if they wanted to invest resources.
StefanR5R
6,851
11,029
Regarding Strix Halo (intended for laptop), rumors say it'll be 16C Zen5 + 40 RDNA 3.5-spec compute units. So essentially close to DT variants of Zen5 in CPU perf (but likely with somewhat slower clocks), and extremely much higher iGPU perf than DT. This is assuming Zen5 on DT will only be max 16C and have same IOD (and iGPU) as Zen4.
So this means for Zen5, DT will not have much higher MT CPU perf than laptop [...]?
In workloads which are actually able to utilize all thirty-two hardware threads, the Zen 5 based successor to 7950X will certainly make better use of the (default) socket power budget compared to 7950X. In other words, the zone of diminishing returns from an increased power limit should sit somewhere higher on Zen 5 than on Zen 4. Consequently, there should be a computing throughput gap between the 7950X successor and Strix Halo in such well parallelized workloads, if Strix Halo is only going to be available in form factors which are more constrained than desktop PCs WRT power supply and cooling performance.
branch_suggestion
905
1,967
But still better than the stupid Zen 5.
Conroe was pretty stupid as well, the memory controller was still on the chipset, very primitive compared to the sophisticated uncore of K8.
Still beat the everloving snot out of it, which is what matters.
It will take more than magical process leaps to make LNC competitive, the actual core design needs a massive overhaul vs their current cores.
IDC might be the stupid ones after all.
adroc_thurston
8,615
11,330
I think that's why @Panino Manino put that in quotes. There are some people who listen to the hype and then are disappointed in AMD because reality isn't as awesome as the rumors (rather than being disappointed in the rumormongers themselves).
There's a general expectation mismatch between what people expect (another Zen3 at maximum) and what it actually is.
Reactions: Tlh97 and Elfear
gdansk
4,793
8,085
Hold me to it: I'll buy an X3D part if there's even a 15% 1T improvement. But I expect 25% 1T improvement like Zens of yore.
Reactions: lightmanek
