Page 213 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
JustViewing
272
478
That's cashburn-fueled negative margin product trying to amass critical install base before hiking the pricing aka the usual SaaS stuff.
Somehow, it seems like I am talking to a ChatGPT :innocent:. While usually I am against Saas, nobody is forcing you to use it. You can always host your own services locally. With the current cost, it might be even cheaper to buy own hardware+software.
Reactions: Exist50
Fjodor2001
4,624
746
Price of HW (perf / $) and thus cost of service will go down over time.
Also, PCs will soon have NPU locally to assist.
Reactions: Exist50
RnR_au
2,910
6,502
The algorithms that makes up the AI will get smarter. Less training time needed, higher accuracy. Its what keeping the Pentagon folk awake at night. Despite AI gear bans for China, their AI's will get better and better.
Reactions: Kryohi
linkgoron
2,599
1,238
Github Copilot has been pretty good in my experience. The PR summarizations are pretty good, the code completion is very good, and we've also had good experiences elsewhere with similar tools. I don't get the hate so much.
TESKATLIPOKA
2,696
3,260
If we won't be careful, I wouldn't be surprised If humanity will become batteries for robots or be just outright destroyed.
We will have a real Matrix including Keanu Reeves, if he can live that long.
19,218
With how bad the job situation is in the world, people would actually line-up to be used as batteries while they sleep, as long as they can have a "normal" life.
TESKATLIPOKA
2,696
3,260
With how Strix Point should have 2x 2-3x more powerful NPU, I think AMD will use even more of die size for this unit.
StefanR5R
6,851
11,029
Point taken about Microsoft being partial.
But I can tell you that a lot of companies in general are expecting similar results that Microsoft got w.r.t. productivity increase for office workers, engineers, etc in general resulting from Generative AI. Although perhaps a bit lower percentages.
Productivity increase in engineering?
Have you ever used a calculator? Does a calculator increases your productivity? Not that you can't do calculations with pen and a paper, just that it much easier to use a calculator. Same with AI.
Speaking of engineers, I am one. Much of my current work involves peer review/ verification of other engineers' work. I can't see myself having any generative AI going on on my side of the equation. Neither should there be any at the side of the engineers whose work I am verifying.
Even as far as the so-called mundane tasks in engineering are concerned, such as reading up on meeting notes, managing incoming e-mails, or writing reports, I don't see how a responsible use of current AI would save time with these.
I can see that generative AI comes in handy,
– if it doesn't matter if "IP" of uncontrolled origin sips into your work,
– if you are allowed to simply make up stuff now and then.
Fjodor2001
4,624
746
With how Strix Point should have 2x more powerful NPU, I think AMD will use even more of die size for this unit.
You mean on Zen5 desktop CPUs?
Yes, I guess the question is how powerful the NPU on it will be. For comparison, the NPU on Hawk Point is 16 TOPS and Strix Point is rumored to be 48+ TOPS according to this article:
TESKATLIPOKA
2,696
3,260
I meant Strix Point, because as you linked It should have 3x more TOPs, although it won't come only from NPU.
Fjodor2001
4,624
746
Are you sure it's not from the TPU alone?
This is from the article:
indicating that Hawk Point has 16 NPU TOPS, and 39 total TOPS.
Then there is this from the same article:
again indicating 16 TOPS for Hawk Point, and on the same row for Strix Point 48+ TOPS. So my interpretation is that it's from TPU alone?
TESKATLIPOKA
2,696
3,260
Ok, I am blind. It should be only from the NPU.
StefanR5R
6,851
11,029
Yes, from e.g. Github Copilot as others also have mentioned.
Hmm, okey, I guess besides engineering which relies a lot on analytical thinking, knowledge, experience, and scrutiny, there is also engineering which relies more on googling and trial-and-error. Like when I for example piece together simple helper scripts for my computer hobby at home (although I don't see this pastime as engineering). Yep, there might be potential for productivity gain with an AI assistant in such lines of work.
Edit: Github Copilot has little to do with NPUs though, does it, to somewhat get back to topic.
Fjodor2001
4,624
746
Not sure if you're agreeing or not with that comment. Anyway, currently to my understanding the Github Copilot AI inferencing is done on severs in the cloud. But I assume when PCs get equipped with NPU, the NPU can offload some of the work from the servers. So Github Copilot has a connection to NPUs in that sense.
JustViewing
272
478
More off topic, Visual Studio 2022 already have AI built-in even without Copilot. It analyses current project and does help a lot when programming. It can understand your coding style and able to do code suggestion and completion accordingly. After getting used to it, it is bit annoying to work without it.
I guess these types of workloads can be accelerated by built-in NPU. Also I remember AMD saying that all future CPUs will have some sort of AI. Not sure about Zen5 though.
Reactions: Fjodor2001
Fjodor2001
4,624
746
It doesn't exist.
Are you just speculating? Otherwise provide link to source.
I have a hard time seeing how AMD would intentionally render Zen5 not fully Win12 compliant by not including an NPU. That’s just bad business and a distaster from marketing perspective whether you like it or not.
Reactions: Exist50
Hitman928
6,754
12,500
Zen5 mobile should have an NPU but desktop probably won’t. It’s not in the CCD and there isn’t a new IOD to connect another chiplet. That would leave putting it inside the IOD but they already put a GPU in there and I don’t think there’d be enough room to add something that would be worth anything.
If builders want an AI powered desktop, they can add a dGPU that can give enough performance for whatever baseline they need to hit. Intel is refreshing RPL on the desktop so it’s not like there will be any competitor solution to choose instead.
