Page 206 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Joe NYC
4,019
5,572
Client isn't getting higher core count CCDs.
You don't need more cores.
You're not getting more of anything since none of you have the money to pay for it.
I guess it makes sense to wait for the die size of Zen 5 8-core CCD before speculating about Zen 6.
Maybe when 16 core is under 100mm2 die size, which may not happen until a generation after Zen 6.
I wonder how receptive AMD would be to having 2 differenct CCDs, one 8 core and one 16 core. It goes somewhat against AMD philosophy, but if AMD manages to gain more client share in next 1-2 years, it might be a profitable to release such a CCD, that would, by definition be lower volume...
That's wayyy too expensive.
Maybe too expensive under one assumption of costs, and maybe not too expensive under a different assumption of costs.
BTW, at some point, the cost of die savings on the expensive most advance node of the base die vs. cost of stacking + cheaper N6 SRAM will cross over.
Joe NYC
4,019
5,572
Well, if AMD is taking Intel´s route now, no reason to buy them then. Might as well default back to Intel with the next rig in couple of years. Maybe they will put their stuff together in the meantime.
From MLID leak, single Zen 6 IO die processor would be a great HEDT computer, if AMD was inclined to release it.
adroc_thurston
8,071
10,824
More efficient platform is always nice, but if that higher efficiency does not translate into higher performance, it does nothing for me. On desktop, unlike mobile, i am not power constrained.
The lockstep thing with mobile does nothing for me either. That benefits AMD, not me, i dont need them to be the same
It benefits quite literally everyone since you're getting a more efficient more functional platform.
I ain't speculating anything.
Client. Is not. Getting. 16 core. CCD.
You don't need that.
Why waste tapeouts on an extremely niche product no one would care about.
They already own the DIY space and OEM boxes don't need high core counts at all.
There is only one assumption of cost and it's dollars per die area yielded.
Cost is the least limiting factor in anything SoIC-X.
Joe NYC
4,019
5,572
haha, I was talking about me speculating.
You are preaching to the choir. I agree with that.
But what would prompt me to get one, If AMD was offering it couple of generations down the road? Bigger cache sizes would be a good selling point.
I know. That's why I made it conditional on AMD gaining a lot of client market share, which would spread the costs of the extra tapeouts over more units.
It probably does not make sense financially with current market share.
Well, there are different costs between nodes. Say N3E vs. N6. BTW, TSMC is cutting N7/N6 prices...
Is it still true today, and will it still be true 2 years from now?
The answer depends on whether everyone else in the semiconductor industry also jumps on SoIC-X. But it other TSMC customers are slow jumping on-board, TSMC should have way more capacity than AMD is buying.
So, if capacity is no longer a limiting factor, then cost is.
Timmah!
1,572
935
And how does that translate into faster computing, which is exactly what i am looking for? In what way is it more functional and why cant there be a separate desktop part sharing said uncore with mobile for that higher efficiency, while having its own more performant "core" part? And that achieved not just by the virtue of higher TDP?
If there will be 16 core server CCDs, even if they would not want to give more than those 16 cores on desktop, surely having one of those would be more beneficial to me than having 2x 8core chiplets.
EDIT: Or does this new uncore means return from chiplet back to monolithic design, so both cores and uncore on single die again? This is not quite clear to me. If yes, consider above irrelevant.
Joe NYC
4,019
5,572
There is just so little info to go on to make any comparisons. Basically, all that AMD is doing now, and in Zen 5 will be replaced. So gone will be SerDes connected chiplets on server and desktop, and also monolithic mobile.
We have a hint of where server is going (from MLID leak) and where high end client is going (from MLID Strix Halo leak).
I think the Strix Halo is more relevant to the potential new client architecture, but it can't fit in AM5 socket. So, it is possible something else (something new) will emerge...
Reactions: Timmah!
adroc_thurston
8,071
10,824
More watts go towards your raw compute.
It's magic!
No lol, don't even think about that.
To people that make those chips and the wider market at large.
It's not compatible with client designs.
Timmah!
1,572
935
It's magic!
And that would result in what? Higher clocks? Cause you are saying clearly not more cores.
Zen 4 is more efficient than Intels desktop CPUs - at 65W. At more than 200W, they perform similarly.
adroc_thurston
8,071
10,824
Abwx
11,964
4,935
Not in desktop segment. And 300W is needless exaggeration.
14900K is set at 350W out of the box, Computerbase displayed no other number in their tests since they did them at stock settings, contrary to the 14700K wich is 253W limited at stock.
Timmah!
1,572
935
Thats just Intel taking it to absurd levels to take the performance crown over AMD. And even then, its not really that much of an issue, is it? Since Zen4 CPUs cant still beat it in absolute performance, despite being more efficient.
Reactions: Tlh97 and yuri69
Abwx
11,964
4,935
it s the other way around, those 350W are not enough to beat a stock 7950X in MT, despite 3 benches out of 9 favouring Intel, they only manage to hedge out marginaly the 130W limited 7950X3D by a few percents, and even more barely the 7950X@142W.
Markfw
May 16, 2002
27,375
16,217
Pretty sad when they have a 360 watt 64 core server part that can make a 14900k whine even on LN2 and 900 watts (or whatever it was) and can whup any server part on air (using threadripper@980 watts), vs even LN2 Intel @1900 watts..
I mean they have to try and pick some laptop part that is not even a competitor to make themselves look good.Actually, I thought AMDs latest $1000 laptop handily beat Intel best ?? At least the competitor.
Timmah!
1,572
935
Well they are inferior when it comes to efficiency, we already knew that. Yet they are pretty much on par with them in absolute performance, and they are generally better for gaming - you need 3D cache on AMD side to match/beat them.
My point anyway, if its not obvious already, all is nice that 7950x can match it at 142 PPT, the important thing is, there is really no point to allow more than that, as the performance increase beyond that will be negligible. Its not like 7950x at 350W is going to beat living crap from 350W 14900k, because it can already match it at 142W. is it?
What is this "you dont need this, you dont need that" nonsense anyway? Are Zen5/6 some kind of endgame, ultimate CPUs or what? I mean, i still have to wait for things to be done with Zen4 sometimes - are these new gens going to resolve that and make everything instant? Cause if not, i fail to see how one can say you dont need something. Indeed you do. What you dont need, if you look for faster computing, is more efficient CPU, if you cant translate into efficiency into more performance. Which as we can see on Zen4 example, cant really do it, cause even if you pump more power into it, it wont beat RPL by more than negligible margin. I dont expect merging desktop and mobile into one to resolve that, if anything, it will make it even worse.
Timmah!
1,572
935
Well, the mobile segment suits them, as its power limited. Its exactly the place where they shine thanks to their efficiency advantage. But how that helps in the desktop? They just pump more power into it and match the performance. Its not great, but it solves the problem.Thats why people keep buying it, despite everything, it performs on par with AMD, and thats what matters.
Abwx
11,964
4,935
It s obvious that AMD increased the TDP at 230W PPT for competitive reasons, they didnt act like this randomly, they followed intel s path, bigger perfs numbers sell better.
That being said for whom does want efficency within reasonable TDP there s the 7950X3D wich is limited to 130W, that s about the best efficency point for a 16C.
H433x0n
1,224
1,606
The cIOD power is taken into account for package power limit. As an example if a Threadripper processor has a 350W limit the cIOD is probably taking up ~60W leaving the cores ~300W to consume. If a 7800X3D is using 60W while gaming there’s a really solid chance that more than 1/3 of it is the cIOD (especially if you’re running a DDR5-6000 Expo kit).
It will reduce uncore power and increase max theoretical bandwidth. It’ll be an objectively better configuration for desktop DIY enthusiasts.
Reactions: Tlh97 and Thibsie
Joe NYC
4,019
5,572
*to a single CCD but yea.
BTW, that's what I was wondering about in server CPUs as well. Bandwidth to CCD, over IFoP is somewhere between 1-2 memory channel bandwidth. But with the new type of connection between CCD and IOD (which looks like Active Silicon Bridge), the connection could accommodate full 8 or 12 or 16 memory channel worth of bandwidth. With better latency too.
adroc_thurston
8,071
10,824
2 read 1 write and they do some write coalescing/compression on GMI3 anyway.
You're still gonna be limited by whatever the SDP count on the fabric side of things.
Ehhh negligible difference.
Reactions: Tlh97 and Joe NYC
DrMrLordX
23,157
13,250
That's what I thought.
This is a PC enthusiast site. We overclock and buy garishly expensive hardware for our own personal use. It's an decreasingly-relevant hobby. But why would I be happy over AMD sticking us with a mobile part, especially when (since Zen came out) we typically see the server/workstation chiplet designs roll out first?
I personally do not give a fig about luggables and portable workstations. What interests me at a personal level is DiY desktop. Can I overclock it/tune it, will it hit nice high clockspeeds, can I get more out of it with over-the-top cooling, etc. What I'm not all that interested in is a warmed over mobile design. The last time we had that, it was Carrizo/Bristol Ridge.
