Page 172 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Goop_reformed
316
341
Homie, why you using chips out right now to say you don't doubt potential numbers for... future chips? That's wild lmfao
Past behavior is the best predictor of future behavior. With extremely limited budget, amd managed aa awesome comeback with 4 consecutive generations of zen. That's why I was saying several page back if zen 5 isn't at least 25% above zen 4 that'd considered a disappointment in retrospect.
Reactions: Tlh97 and Markfw
Markfw
May 16, 2002
27,411
16,267
Past behavior is the best predictor of future behavior. With very extremely limited budget, amd managed a awesome comeback with 4 consecutive generations of zen. That's why I was saying several page back if zen 5 isn't at least 25% above zen 4 that'd considered a disappointment in retrospect.
This is my logic....
Geddagod
1,684
1,720
Sure, but you look for patterns, not looking at one generation of chips.
That would be like me saying "hey look at how good my 13900k is (I don't actually have one lol), the 14900k is going to be so good.
Wonder how much of that is Intel literally just delaying products to narnia...
IPC? Deff no. Even if it's just overall performance, still no. Zen 3 was a similar uplift in MT IIRC, or even less.
It also depends on what the scope of Zen 5 was supposed to be ig, but they don't need a giant architectural uplift (as in Zen 1 level) to be more than competitive vs Intel.
This is what happens when people hype up a product much too hard before launch. If it meets those sky high leaks, well it's fine, but if it doesn't, then people start thinking it's "bad" when in a vacuum it would be pretty good.
Sure... ;)
Reactions: Tlh97 and Thibsie
Thunder 57
4,301
7,108
How did Intel do with a massive budget? Sometimes being smaller and more agile is a benefit.
adroc_thurston
8,687
11,413
That's not how any of this works.
You usually project comp extremely aggressively which is what AMD did.
Intel had a very unique case of cultural decay (and manpower departure to a lesser extent).
Thunder 57
4,301
7,108
I don't disagree. I won't go into why I think some of that is happening as this is not P&N. I was just responding saying a nice budget doesn't necessarily produce a good product.
Geddagod
1,684
1,720
That's not how any of this works./
Wait, you telling me if AMD projects a 20% IPC bump (like a zen 3 level increase) they are going to be disappointed if they only get 20% and not 40%?
To a certain extent, sure, but I'm guessing Intel wasn't projecting 20% ipc bump for RWC. There's a difference between "aggressive" and "delusional"
adroc_thurston
8,687
11,413
It usually correlates well unless the company in question has major structural issue.
Projections as in competitive projections.
You target relative to what competition has.
Geddagod
1,684
1,720
You also release targets based on your own previous products
Hence that 2x EMR perf projection from that Intel leak for GNR.
But if you're talking about if companies aim to target perf based on what their competitor is also releasing (early in design), well sure, but as I said earlier, AMD doesn't need a massive architectural IPC uplift in order to be competitive with what Intel has coming up. Even a standard zen 3 level IPC increase is fine. And from a gen-on-gen perspective, that won't be disappointing either, unless AMD was aiming for much higher increases and failed to hit them.
Joe NYC
4,253
5,900
I don't believe Strix Halo will be paired with TOP line dGPUs unlike Dragon Range, so why would they pay for extra cache?
I think the reference to Dragon Range was that some OEMs are willing to release a product with a pricey CPU.
While, I think, there will still be a nominal Dragon Range successor (put together at minimum cost to AMD), the main effort, and where more money went is Strix Halo, which will likely have the same CPU power (roughly) plus strong GPU.
19,219
Maybe the early silicon beat all their theoretical estimates and simulations. Is that really hard to believe?
Geddagod
1,684
1,720
I'm not even commenting on what Zen 5 leaks are claiming it will or won't bring.
All I'm saying is that a 25% increase in perf isn't disappointing. The only way it would be disappointing is if AMD aimed for higher, and they failed to meet it. I'm not saying that's what happened, I'm saying that's the only way a 25% jump in perf would be disappointing.
I don't know how much longer I can keep beating this drum lol
Geddagod
1,684
1,720
Ye, I think most people care way more about Strix Halo than DRG... though idk about roughly the same CPU power, bcuz of TDPs...
I think it's a bit interesting Intel and AMD both are creating mobile skus that the other company doesn't seem to interested in competing in. ULP LNL for Intel, "mega APU" Strix from AMD.
Reactions: Tlh97 and Joe NYC
Goop_reformed
316
341
Sure... ;)
That's false equivalence though. 12900k, 13900k, 14900k are essentially the same technologically. What you said about intel is also true, however amd's execution should not be downplayed. And people only hyping up zen 5 only because of the expectations from previous gens results. The rest is just smoke.
Well intel has more than 10x employees at some point, therefore management was substantially more vital. And when intel hit a snag those management positions became useless.
itsmydamnation
3,146
4,029
What's smoke about:
2 more Alus
More load store bandwidth
More L1D
More instruction bandwidth
Likely significantly larger rob and prf
Like we are talking more change then Intel did from skylake to ice lake to golden cove but apparently amd suck and can only get 15% IPC at reduced clocks......
If I was a betting man (I am) I'm willing to bet spec int 1t is closer to 32% then it is to 15% at equal clock.
Thunder 57
4,301
7,108
What's smoke about:
2 more Alus
More L1D
Maybe we should have a predicition thread? :D
If I had to throw out a number I'd say lower 20's, maybe 22-23%. Still waiting for @inf64's prediction since he seems to nearly nail it every time according to his signiture.
Reactions: Tlh97 and inf64
Goop_reformed
316
341
What's smoke about:
2 more Alus
More L1D
Should have mentioned the smoke is about 3 gen of golden cove. Zen 5 is obviously not smoke at all.
Geddagod
1,684
1,720
No it's not lol
So what you're saying is you look at a pattern of multiple generations of products released recently, not just the latest one?
The false equivalence is pretending @Markfw's comment made literally any sense at all. There is literally no relationship between Zen 4 going Vroom and thinking that Zen 5 is going to be a massive jump over Zen 4 lol. You can try to extrapolate the "pattern of multiple generations" claim from that, and that's correct, but that's not at all what he said, and not at all what I responded to him with...
Cap
The majority consensus (on this forum at least) was that this was likely going to be a Zen 3 level jump, not a Zen 1 level one. It wasn't until @adroc_thurston joined that it shifted, and even then there's still healthy skepticism of that higher level IPC claims
But even if that were true, it's from looking at previous generationS not the one current generation
Bad argument. GLC only got a 15% jump in server lmao. And SNC got 18% IIRC. The difference between 18 to 15% is that much lol. Plus, if you believe in the 15% rumor, I doubt you are as likely to believe in the frequency regression rumor as well, at least not a significant frequency regression. And SNC was a frequency regression over SKL, even RKL's 'SNC' version just tied SKL. Plus, the all core frequency regression was seen in both SNC ICL and CYPRC RKL. Also, GLC was technically a Fmax frequency regression over WLC, and that used a better node than WLC to boot (and the node difference there is prob bigger than the one between N4 and N5 for Zen 5 vs Zen 4).
Goop_reformed
316
341
No it's not lol
Cap
Zen 1 was released in 2017, and there has been 5 gen of zen since, and every performance uplift has been increasing since the last. Compared that to intel and you'd see my point. Even if you ignore all that, Mike's comment about zen 5 should at least be something to be addressed. There were also rumors about the excitement behind the scene about zen 5, this has been addressed multiple times already.
Also, 12900k 13900k 14900k are the same damn thing and it's factually wrong to claim otherwise. The false equivalence in this case is about the rate of which intel and amd churning out performance upgrades with each gen is not the same.
Reactions: Tlh97
Markfw
May 16, 2002
27,411
16,267
No one is allowed to tell a member to Exit or censor them if it stays on topic except our Admins / Overlords.
No it's not lol
Cap
So, people are not allowed an opinion unless they can prove it ? Go back to your Intel thread. I could be wrong about Zen 5, but my gut tells me its going to be good.
THATS MY OPINION !
