Page 128 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Joe NYC
4,042
5,591
Probably meant to ask if Wafer-on-Wafer n3 (cores only) + n4 (level 2 and 3 cache) would be a viable option for zen5c.
Definitely cheaper than n2p
Zen 5 is already done, and it appears to be unchanged from macro architectural POV. Only the core is new.
We will see if Zen 6 brings any changes in how caches are organized. Since Zen 6 will be N3 or even N2, there will be more incentive to move L3 entirely off the main die.
soresu
4,228
3,713
N2 seems unlikely given AMD usually wait quite a while for a process to mature before they send a chip to be fabbed on it (or its AMD custom variant).
A///
4,351
3,160
Soresu is correct once again. You used to be conservative with your theories, Joe. Have you been bitten by the brain eating mlid bug?
soresu
4,228
3,713
they're one of the first N3e customers
N3e is still TSMC's 2nd N3 node though.
If they are pursuing a new node like N2 though so close to release they must be less concerned about tuning for absolute performance, which suggests possibly Zen6c.
I guess if they know that many are just skipping N2 for the BSPD feature in N2P then TSMC might give them a good price on it.
adroc_thurston
8,095
10,858
It's the first actual one since N3b came out stillborn.
Wat.
PDK's one and the same for all.
No it's egregiously expensive but cloud guys can pay.
And they will.
Joe NYC
4,042
5,591
I only bring it up because @adroc_thurston mentioned it as a possibility. And AMD likely has contingency plans as well.
It would make sense to use it for product most benefiting from density, same as Zen5c is likely to be the first AMD CPU to use N3, while the mainstream lineup is going to use N4.
adroc_thurston
8,095
10,858
Lol that sounds ominous
You'll see why next year.
N2 has no density bump over N3p (it's like 1.1x moar); perf/power is what cloud guys ready to pay for and they will.
Reactions: Tlh97 and Joe NYC
adroc_thurston
8,095
10,858
when AMD will be going big.LITTLE on desktop CPUs
Not any time soon.
Desktop can pay for real cores.
Will it be introduced on Zen5/6/7/...?
Doesn't look like you're getting dense spam in DT any time soon and there's not really a reason to.
Better keep that 1t CAGR going as well as massive bump in system efficiency from Zen6.
Markfw
May 16, 2002
27,375
16,217
@adroc_thurston:
What are your thoughts with regards to when AMD will be going big.LITTLE on desktop CPUs? Will it be introduced on Zen5/6/7/...?
And Zen4C and the like I would not call little, its just less cache, same core. So I doubt they will go big.little, but dying to hear what adroc_thurston has to say,
Edit: and I agree. Intel had to do that to save power and still do something close to competitive. But I don't think it is. Zen4 is better than a P-core and I have 16-96 of them depending on the box.
CakeMonster
1,655
836
I get that most DT users can afford to pay for the cores, but at some point consumers will want more cores too. As has been alluded to earlier, 6c/12t works surprisingly well in Z4 because of IPC, but a lot of people just don't want it anymore. Will AMD move to more than 8c CCX with Z6 or Z7 to be able to sell lower end parts with more cores than 6? Like 10c or 12c CCX? Or might they just ship everything with two of them and disable more cores? At some point the 6c will move to the price point that the rarer 4c models are now and you'd think AMD was looking at preserving the price points above it.
Joe NYC
4,042
5,591
BTW, there was some discussion about using Zen5c in AM5 socket.
AMD has bee outright negligent about not pursuing the low budget server market, given an overwhelming advantage Zen 4 already has (while Intel is probably outselling AM5 servers 100:1)
With Zen 5c, add another 2x to that advantage.
Ajay
16,094
8,114
Why do you keep bringing this up?
What do you think server CPUs based on Z4c are for?
Joe NYC
4,042
5,591
They are for (they sell for) multiple thousands of dollars in 128 core Bergamo. That's quite high end of the server market.
But AMD leaves all of the low end server market to Intel. AM5 mini / budget servers would fill this role perfectly.
Joe NYC
4,042
5,591
Siena is for that.
Don't worry, AMD's 1st party bar charts will be nice and juicy too.
I think Siena is positioned a lot higher than that. Low end servers are way below $2,000 price even below $1,000 for the whole server.
Siena will probably be above that just for the CPU.
