Page 312 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Joe NYC
3,656
5,199
So what happens to Zen 4? Zen 3 is still being manufactured I suppose? Do they stop making Zen 4 chips immediately or are they supposed to slot in below the Zen 5 SKUs for more pricing options for consumers?
New_Zen4_Price = Old_Zen4_Price - $50
New_Zen5_Price = Old_Zen4_Price + $50
It will probably make sense to phase out Zen 4 SKUs once full slate of Zen 5 SKUs is shipping in volume, except some special SKUs notably:
- 7800X3D
- 7500F
StefanR5R
6,676
10,580
The cache amounts are wrong for some of these, Zen 5C cores have a fraction the L3 available to them.
EDIT: Actually, there's probably a lot more wrong than that. Wouldn't make sense for there to be only one 500W SKU.
I don't read twitter, but it seems there was an update posted:
https://www.computerbase.de/2024-03...rver-cpus-mit-mehr-l3-cache-und-fragezeichen/ (scroll down to "Update 25.03.2024 07:34 Uhr")
This still claims that there is only one part with 500 W default TDP.¹ I also wonder about the cache amounts of the parts with multiple-of-3 core counts, of the F parts (frequency-optimized), and of some of the low core count parts (low core count combined with "low" cache overlaps with SP6/ Siena and possible successors).
¹) Edit: The table header says only "TDP". "default TDP" is just my own interpretation. Core count increase aside, given the widing of the cores, a bump of at least cTDP_up per core compared to Genoa, if not of default TDP, would make sense to me.
Reactions: Elfear
Gideon
2,030
5,035
INT is what most people care about. Both single thread and multi-thread.
If it is really > 40% single thread, it would be truly mind blowing performance gain.
Yeah, 40% was Zen 1 initial target (which they beat by actually achieving 52%).
As full "breaking, ground-up redesigns" of CPU's usually take at least ~5-7 years, I was hoping (ever since that famous Mike Clark interview) that Zen 5 would be it - with targets as aggressive as Zen 1. Containing all the results of the higher-risk / more conceptual research AMD has been doing ever-since 2017.
As beating Zen 4 by that amount (particularly on a similar node) is an insanely harder achievement than "clubbing baby dozer-cores", i'm still very sceptical ...
... but boy do I want to believe :D
Joe NYC
3,656
5,199
Exactly, after Zen 4 performance gains that were really quite decent, where Zen 4 already used up some of the N7 -> N5/N4 process technology gains.
Computex is in about 2.5 months from now, so not too long before we find out. Maybe some leaks between now and then.
Another thing to keep in mind is that unlike previous Zen generations, when AMD was struggling financially, Zen 5 team was not under the same financial pressure, and could pursue all of the avenues that looked promising, even more risky ones.
adroc_thurston
7,191
9,962
Core for core Zen5 is >40% faster than Zen4 in SPEC.
You weren't supposed to say that, little one.
Well no, that's more of a willpower thing.
R&D money translated directly into more designs rather than more ambitious ones.
AMDK11
473
407
IPC increase for Zen 5 > 40% What does this refer to? Is this the average of the IPC growth curve? Up to 40-50%?
It's easy to throw around such numbers, but if there is no reference point and what type of load these numbers refer to, they don't tell us anything. It is equally easy to write that Zen 5 has an IPC >6%. And what does this tell us? Nothing.
Zen 3 with one specific workload (SPEC?) saw +106% compared to Zen 2. However, in the case of AMD's presentation, the IPC growth curve ends at +39% with an average of +19%.
Zen 4, also according to AMD's presentation, the IPC growth curve ends at +39%, but the average is already +13%.
inf64
3,884
4,692
Zen 3 with one specific workload (SPEC?) saw +106% compared to Zen 2. However, in the case of AMD slide, the IPC growth curve ends at +39% with an average of +19%.
It was explained that the figure is from the aggregate SPEC score (which is calculated from the subscores).
AMDK11
473
407
IPC? 19 and 13% respectively.
+19% and +13% are the average of the IPC growth curve from programs and games. I asked about the SPEC result.
+40% for Zen 5 is certainly not average and will this translate into average in many applications? I am not a carefree optimist, but to err is not a sin.
on average +40%, how much would the Zen 5 core have to be expanded? IPC does not come out of thin air, but requires reconstruction and strong expansion of the logic controlling the core and resources. On average IPC +40%, i.e. a curve from approximately +10-15 to 70-90%? Oh, it's going to be a disappointment.
adroc_thurston
7,191
9,962
The SPEC results are the exact same lmao.
AMD SPEC results translate into averages in just a truly wonderful fashion.
You're shadowboxing stuff.
The numbers are SIR2017 rate 1/n.
Reactions: Tlh97 and inf64
leoneazzurro
1,114
1,867
According to this Anandtech review:
The average SPECINT 2017 ST increase from Zen3 to Zen4 is 23% considering the average of all substests, considering the platform differences there is probably some lower margin due to the cores only because of memory BW advantage of Zen4, which should not exist with Zen5.
