- Mar 3, 2017
- 1,777
- 6,791
- 136
I too, will never again recommend HP, for ethical reasons.Got none for HPs thats why I'm never recommending that brand xD but nice though
If AMD has "won", why do they still have less than 15% marketshare in laptops?
That's because it was a usable $999 macbook and not really the SoC part of it.
There's really not a market for tablet parts otherwise.
The current Macbook Pros are peak laptop.The design for the new MacBook also knocked it out of the park and fixed a lot of issues that people had with their previous notebooks.
Same reason I pointed out as to why they can't really grow market share by significant amounts in a single generation. They don't have enough wafers. In this case AMD decides they'd rather win more market share in the highly lucrative server market.
In that case why don’t AMD simply increase the number of wafers they order from TSMC? If you say AMD can use those extra wafers for more laptop chips, and that the market would absorb those chips, that is.The only way for AMD to gain market share is to increase their wafer allotment
I'd actually wait until AMD gives concrete numbersOkay so if we come back to Earth, and consider that MLID may have been correct with the leaked slides - what do you think could be the reason why there is a huge disparity in the performance expectations here (30%+ IPC) compared to MLID(10-15%+ IPC)?
My guess is probably that N4 doesn't quite give AMD the transistor budget to go for a super-fat core.
Or AMD was simply too conservative with their estimates and even they are surprised by the monster core they ended up creating.My guess is probably that N4 doesn't quite give AMD the transistor budget to go for a super-fat core.
Or cement?I'd actually wait until AMD gives concrete numbers
This is entirely dependant on either:In the long run, AMD stands more to lose from the gains they've made in DC, because everybody and their grandmas are realizing that it doesn't make sense to lose margins to AMD and INTC buying their CPUs for the data center, when you can build your own. MSFT, Amazon, Google are all going there.
Ah, you haven't heard of ARM Blackhawk (Cortex X5), the Ultimate ARM core to kill all custom ARM cores!This is entirely dependant on either:
a) Base ARM offerings being competitive with Intel/AMD designs, which really isn't a given. Recently gains haven't been very impressive, they've either come at significant increases to die area spent or power consumption. (Zen and even more so particular Zen xC competes extremely well against Cortex-X/V based designs with regards to power/perf/area)
Just right when the CPU architects left!b) those companies producing their own in-house cores to compete against AMD/Intel. Apple did a great job getting to A14 gen where they're on a level playing field, and have swiftly dropped off with no improvements since.
I doubt Nvidia would go to the trouble of designing custom ARM cores. Custom designs are difficult (Look at the fate of Samsung Mongoose). If Blackhawk is good enough, there is no need for custom cores.Ampere have almost vanished off the face of the earth with their own in house core debuting with AmpereOne. Only real hopes at this approach is really Qualcomm with Nuvia cores and potentially Nvidia, but we don't really know if the latter is still developing their own in-house cores given Orin uses base ARM ones instead - and they're weren't even recent cores for when Orin started shipping either.
I'm more worried about the availability since RDNA 3 laptops were dried up nglWould you expect the power consumption delta between 'Strix Halo' and 'Strix Point' when on IDLE to be very significant ?
I am asking from a 24x7 ON laptop which 80% time is under-demanded and the remaining 20% is over-demanded. I would prefer to wait for Halo ... but what I don't want is having a hot oven when idle ...
Thank you !!!
Also as per arm's comments during their earnings release, armv9 contributed 15% to the revenue compared to 10% last quarter, and they say that v9 is bringing royalty at twice the rate of v8.Ah, you haven't heard of ARM Blackhawk (Cortex X5), the Ultimate ARM core to kill all custom ARM cores!
A word from ARM themselves about Blackhawk![]()
RESEARCH NOTE: Arm’s “Blackhawk” CPU Is An Audacious Plan To Have The Best Smartphone CPU Core This Year
For years now, there has been what I consider a healthy, competitive tension between Arm CPU instruction set licensees and Arm’s pe-packaged and pre-validated IP licensees. (I am sure some licensees would challenge me on “healthy” given Apple’s performance.) I think it made sense that Arm would...moorinsightsstrategy.com
Not even close.It's the best selling laptop in the world.
That's an understatement IMOYeah HP goes for minimalist BIOS.
Well, that heavily depends on the efficiency of the D2D interconnect. I would say yes, there might a significant difference, unless AMD surprises us with something like MTL's LP island.Would you expect the power consumption delta between 'Strix Halo' and 'Strix Point' when on IDLE to be very significant ?
Thank you !!!
All those 50+ power saving enhancements AMD made in Rembrandt. Do they still exist in mobile Zen 4 chips or they didn't have time to integrate them into Zen 4 mobile? My suspicion is the latter.unless AMD surprises us with something like MTL's LP island.
With the four-wide decode for example, a lot of the compilers have optimizations they do because you have a four wide machine. But when we give them something wider, they will be updated to realize how to compile the code to make it even better. So we'll see we only managed to get 10 to 15% IPC on these older codes that when we launched, but as the compilers developed, they'll be able to extract more and more out of our future designs based on what they get out from our current design.
