Originally posted by: TankGuys
The bottom line here is that it depends on the wording of the question, and how people interpret it. There are some "wordings" where the plane won't take off, and some that the plane will take off.
If people make the strict assuption that the treadmill moves backwards at the same speed as the wheels rotate forward, you run into issues of infinite acceleration and other fun stuff, and the plane won't take off.
If people assume the belt moves backward at a velocity equal to and opposite the plane's speed, then the plane takes off just fine, wheels spinning 2x the normal speed.
Consider this thought experiment:
You know those toy cars that you roll backwards, and when you let go, they move forward? Let's say you put it on a STILL treadmill. The car moves forward fine right? Now, put said car on treadmill that's moving backwards, and we all know the car moves at it's speed minus the speed of the treadmill, right? This is because the propulsion system of the car depends on the spinning of its wheels, which are affected by the treadmill. This all makes sense so far, yes?
Now, consider a standard matchbox car. Put that car on a non-moving treadmill. What happens? It stays still. Now, turn the treadmill on, and what happens? Car rolls backwards, right? Now, reach out your hand and hold the car still, while the readmill is moving. What happens now? The car stays put right? Do you think it takes much force to actually hold it still? (try it!) NOW... try pushing the car forward, while the treadmill is moving. You can do it, right? Is it hard? Is it noticably harder than pushing the car forward when the treadmill is not moving? (again, try it!)
This is exactly what happens with a plane. The force of the engines is pushing on the plane - NOT the treadmill. Aside from the bit of friction at the axle that the engine thrust has to overcome, the engines, air, and plane don't really care what happens to the treadmill.
Seriously, anyone who has a treadmill and a matchbox car at home can easily prove this to themselves
