You have a plane and a conveyor belt.
InlineFour
Banned
Nov 1, 2005
3,194
Originally posted by: Number1
Plane stopped = wheel speed 0 = treadmill speed 0
Plane MOVING at 5 MPH = treadmill 5 MPH backward = wheel speed 10MPH.
Notice the emphasis on the word MOVING. The plane IS moving forward; therefore it is generating air flow around the wing. Once it is moving fast enough it will take off.
the plane isn't physically moving if the it is moving at 5mph and the coneyor belt is moving in the exact opposite direction in 5mph. if it isn't moving, there would be no airflow around the wings.
Kenazo
10,429
Originally posted by: PowerMacG5
Originally posted by: FeuerFrei
You freaks who somehow convinced yourself it would take off need to go back and read the OP. The conveyor is moving backwards while the plane rolls forward, COMPLETELY NEGATING any forward progress the plane would make. The conveyor would speed up to match the increasing thrust of the plane and thus the motion of the plane would be imperceptible and airspeed would = 0. Basically, the plane is static in airspace and the ground is moving beneath it... that is all.
This thread is not for arguing whether a plane could take off on a conveyor belt, PERIOD. Naturally a plane would eventually accellerate enought to achieve airspeed (if the conveyor stayed at a constant pace) it would just take longer to launch.
Ok, you are an idiot. The plane does not use it's wheels for motion.
Assuming the plane has get engines:
It uses the jet engines. The jets do not give a fvck what the ground is doing. With a plane, you have to realize there are basically two roads. The ground and the air. Your car is moving using the ground, the plane the air. The jets push on the air, not the ground. If you still feel you are correct, think of it this way. A car cannot drive well on the ice, but a plane can take off perfectly fine, traveling in a perfectly straight line.
If you don't believe me, then you are a fvcking moron who will get no where in life because he doesn't understand a basic thing. I am sick of all these morons here not understanding basic physics.
You might want to be careful with what you say. I'm sure you'd feel ridiculous if you realized you were wrong after all that.
The belt does not care what the source of propulsion is, a car would behave the same way on that belt. The belt just senses rotation of the wheels and compensates for this, regardless of what force is rotating them. If the wheel cannot rotate faster than the belt is moving backwards, the wheel would effectively be stationary to the world around it. Because the plane is attached to it's wheels, the plane would likewise remain in the same spot.
A loss of traction would be required for the plane to take off.
The reason I won't feel ridiculous is because I am 100% correct.
Imagine this. Bush pilots airplanes right on sleds, not wheels. Sleds do not rotate, and are in effect "stationary." Guess what, these planes still take off.
The only thing wheels do for an airplane is provide an interface to the ground so the plane is not rubbing its belly (simplified for takeoff only, and I know thats not the only purpose when it comes to landing, but we are talking takeoff).
As long as the wheels are not literally clamped to the ground, it doesnt matter how fast the ground is moving, the wheels will just turn at incredible speeds while the plane moves through the air.
Your sled statement is wrong, since the friction between them and the conveyer would probably be too great for the plane to overcome.
EDIT: I thought you meant the plane was on skids, on the conveyer. My mistake.
NanoStuff
Banned
Mar 23, 2006
2,981
Look at the situation again, the 'treadmill' is not moving backwards at 5MPH while the wheels are rotating at 10MPH, the treadmill is also moving backwards at 10MPH. It doesn't allow the wheels to rotate faster than itself.
Originally posted by: Kenazo
Assume the wheels offer 0 friction... The wheels will just spin at some insane speed (airspeed of plane plus speed of conveyor), but the plane will move forward.
If the wheels spin at an insane speed, the belt will move backwards at an insane speed effectively imposing insane forces on that plane. The two really do cancel eachother out.
Kenazo
10,429
THINK!!!!
hahaha. i love when you have ppl calling other ppl in the thread "fvcking morons," when they in fact have totally misinterpreted the situation. this is the definition of "PWNED"
Wait.. are you making fun of me, or the ppl I'm quoting. i just said that someone should think about it.
PowerMacG5
7,701
You know what, fvck it. I am through with this thread and all the 10 year old morons who think that the plane won't take off because they don't realize the wheels and the ground mean absolutely nothing. The only thing that matters is the air.
Kenazo
10,429
No they don't cancel each other out. Assuming there's zero friction and assuming the tires don't fly apart, the tire speed would just keep increasing to infinity and the plane would keep going forward. The forces in action between the conveyer and the wheels are irrelevant.
PurdueRy
13,837
4
I guess people don't see that you can't slow down a plane by trying to rotate its wheels more....:roll:
Mo0o
24,227
The only fundamental understanding error here is that the wheels themselves do not propel the plane forward. The friction involved in the ball bearings offer such a negligible resistance that you might as well consider them to have no friction. In a car, the wheels has power applied to them through teh engine, allowing it to go forward, in an airplane the wheels simply allow the plane to go foward on the ground while propelled by the turbines. So the conveyer belt would not do anything once the engines wind up.
alien42
12,868
3,298
you just proved yourself wrong. you are correct that the wheels and the ground mean absolutely nothing. yes the only thing that matters is the air and since the plane is not actually moving there is zero airflow on the wings, hence no lift.
shimsham
10,765
Originally posted by: shimsham
yes, but the wheels provide motion relative to the ground, moving the plane and wings through the air. the conveyor belt negates that motion, and the plane doesnt move forward, so where does the airflow required for the wings to lift come from?
The airplane does not rely on motion relative to ground. It relies on motion relative to the air. The jets push on the air, not the ground. Therefore, I could do whatever I want to the ground, and if the jet sticks to its guns directing itself with the jet thrust in one direction, it will take off.
but its the motion relative to the ground that provides the forward movement to move the air over the wings to provide lift for the wings and takeoff. not flight, but takeoff.
NanoStuff
Banned
Mar 23, 2006
2,981
Sleds do not hold traction to the surface they're travelling on. The rotation of the wheels is directly proportional to the movement of the belt. If the wheels are not spinning faster than the belt, they are not moving forward.
PurdueRy
13,837
4
Try to keep a plane stationary by rotating its wheels...tell me how that goes
Kenazo
10,429
But don't you see that if there's zero friction betwen the wheels and the conveyer the wheels would just speed up indefinately to keep pace with the conveyer and the plane will keep moving forward?
That said, since the entire point of the thread was obviously just an exercise in critical thinking, given the limitations of the original scenario... I suppose then no, the plane wouldn't take off...
The plane increases it's thrust and the wheels begin to rotate. The belt compensates for the rotation of the wheels in reverse, as in the belt moves in reverse exactly as fast as the wheels move forward.
alien42
12,868
3,298
that is the entire point of the conveyor belt.
PowerMacG5
7,701
I know I said I was done, but I need to answer this. If the jets are producing thrust, then the plane is moving forward, hence air is moving over the wings, producing lift.
thirdlegstump
Banned
Feb 12, 2001
8,713
5mph one way negated by 5mph the other way means the plane is not moving
Where did the speed go? The only way to have the treadmill moving is to have the plane move forward.
If you mean by the plane's wheels are rotating at 5MPH and the treadmill moving at 5MPH, then the actual location of the plane does not change, and unless there is wind blowing into the front of the aircraft, the plane is actually performing at 0 airspeed.
Airspeed is what determines the plane's flight performance and not the perception of the viewer from the ground. If the conveyor belt keeps going and the pilot cuts the engines, the plane will start moving backwards gradually and keep speeding up (backwards that is) until it matches the belt speed. Crank the engines again and it will reduce the backwards motion until it reaches par (meaning it looks still from afar.) When it reaches par and even more power is applied to the engine, the plane will visually move foward. Only then will there be any level of headwind. To take off, it's just a matter of the aircraft reaching the required takeoff headwind/airspeed, not how fast the wheels are spinning.
Headwind = what's shown on the airspeed indicator. Airspeed = direct relation to the performance of the aircraft.
PurdueRy
13,837
4
And you can't slow down an object that is not tied to its wheels directly. You spin the treadmill, the wheels just spin more, if I am moving at 5 MPH and you spin the treadmill at 10000000000 RPM, I will still be moving at 5 MPH(assuming the wheels don't break).
Kenazo
10,429
I recant my position... Given the original post's stipulations, it won't take off unless the thrust of the engine is greater than the mass of the airplane. otherwise it's going to stay there.
The OP:
The constraints set out by the scenario tell me it's not going to happen, unless the engine has more thrust than weight. Of course in real life there's no way this is going to happen.
Feb 19, 2001
20,155
23
Originally posted by: InlineFour
purduery, you're saying that the plane will take off?
yes
So this is why I think my Purdue Engineering friend is incompetent. This is why we Cal students get the job.
Your assumption of 5MPH assumes that the wheels are spinning FASTER than the treadmill..... This is like walking at the same speed the treadmill is going. The treadmill is not at a fixed speed. It goes in reverse as fast as the wheel does.
Thus dv/dt = 0. Without any net motion there is no airflow, thus no takeoff.
InlineFour
Banned
Nov 1, 2005
3,194
edit
oznerol
2,476
www.lorenzoisawesome.com
So what is the upward force on the plane? What is counteracting gravity?
Would it not be lift? And wouldn't air over the wings be required for lift?
The engines would only propel the plane forward, not up. And doesn't the original question say that the conveyor belt counteracts all forward motion of the plane? So the plane would essentially require a vertical takeoff, no? Something would have to create that lift.
If I'm running on a treadmill and matching the speed of it exactly, and I spread my arms out, there's no drag on my arms, as they are stationary with respect to the air. Even if someone pushed me from behind, who wasn't on the treadmill, at the same rate that the treadmill accelerated, we'd have the same situation.
So what is holding the airplane up? And what gets it up in the first place? Unless the plane/engines are on a tilt, I don't see how it would be possible.
