You have a plane and a conveyor belt.
Page 21 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
TankGuys
1,080
Originally posted by: clarkmo
Let's say the plane's take off speed is 60 knots. When it's on the treadmill it's not moving but the wheels are spinning. If the plane were to take off it would be going 60 knots in the blink of an eye, exploding and possibly initiating time travel. But it wouldn't fly. If you think it would then you should design the next aircraft carrier. Your country needs you!
Hm? I'm not following this logic at all... can you expand a bit?
clarkmo
2,615
So, so wrong. It does move.
Where does it go?
JujuFish
11,454
1,057
Where does it go?
Wherever the pilot wants to take it?
Rubycon
Madame President
Aug 10, 2005
17,768
485
You could build a plane that used the wheels to move it forward and then your conveyor would keep it from taking off.
Of course a plane like this could take off but not stay airbourne long - as soon as the wheels left the ground the driving force is gone and gravity pulls her back down. It would still be funny to see. :)
giantpinkbunnyhead
3,251
Where does it go?
It takes off like it normally would, of course.
BUrassler
811
Originally posted by: TankGuys
Originally posted by: BUrassler
That is my understanding and stance on this question. I read that the OP said the wheels will always match the belts speed, leaving the plane at a stand still.
Glad I am not going crazy!! :) (I think!?)
Yea, that's the problem though... if the wheels always match the belt speed, there are some paradoxes that will arise, so it's not possible.
But, assuming the belt moves back at the same speed as the plane moves forward, it takes off, no problem.
But that assumption would be ignoring the OP's stipulation, right? I just want to clarify.
According to the OP's exact wording, the plane would not take off. However, in reality, it would take off?
clarkmo
2,615
Assume the plane typically requires an airspeed of 60 knots to create the lift for take off and it is generating sufficient force from it's propellors to acquire that air speed if it wasn't on a conveyor. In your theoretical take off, the plane would have enough force to go 60 knots. From 0-60 at lift off. This was a little tongue in cheek and probably won't fly with you mathematical wizards but then again, neither will the plane.
Banzai042
489
Ok, here you go (for the 3rd time or so), an analogy that explains exactly why it WILL take off
Ok, here's an analogy, if you put a rolling suitcase on a moving walkway at an airport that is moving at 5mph, and you walk beside the walkway (*NOT* on it) pulling the suitcase in the opposite direciton at 5mph, does the suitcase move, even though the treadmill surface (moving walkway) moving backwards at the exact same speed you are pulling the suitcase forward at? If you said yes, you're right .
Now lets put an airplane on a treadmill that moves backwards at the same speed the plane moves forward, but the thrust from the engines is pushing on the wings, *NOT THE WHEELS*, thus when force is applied to the wings the wings apply force to the rest of the plane and push it forward, causing it to accelerate to takeoff speed.
TankGuys
1,080
Okay, let's take this bit by bit, and see if I can try and explain this. Let's use my analogy.
Now, picture yourself with a matchbox car and a treadmill. turn the treadmill on. Can you hold the car in place, with your hand, to keep it from moving relative to you? If so, how hard do you think it would be?
TankGuys
1,080
Ok, here's an analogy, if you put a rolling suitcase on a moving walkway at an airport that is moving at 5mph, and you walk beside the walkway (*NOT* on it) pulling the suitcase in the opposite direciton at 5mph, does the suitcase move, even though it's moving backwards at the exact same speed you are pulling the suitcase forward at? If you said yes, you're right .
Also an excellent example, this is exactly the same thing.
waggy
68,143
10
sigh.
Q How does a jet engine work?
A If you've ever blown up a balloon, let it go, and watched it fly around, you know the basic principle of jet propulsion. A jet engine uses a gas turbine to drive a fan which sucks in air, mixes it with burning fuel, then blasts the expanded air-gas mixture out the back. Because every action has an equal and opposite reaction, as the air streams backward, the engine is forced forward. Modern, fuel-efficient engines called turbofans blow air around the main part of the engine as well as through it. This decreases noise and increases the amount of airflow, which in turn increases power.
bolded the important part. with how jet engines work the wheel speed DOES NOT MATTER. it is going to move foreward NO MATTER THE WHEEL SPEED.
BUrassler
811
That leaves the wheels turning at 10mph and the belt at only 5mph, breaking the OP's rule.
TankGuys
1,080
This is why we're saying the wording is important. If you say the wheels and belt must move at the same speed, and the engines are on, and nothing is physically holding the plane in place, it's impossible. Flat out, completely, 100% impossible.
So, we're talking about the situation where the belt moves backwards at the same speed as the plane moves forward, this is the only system we can even discuss, since it's the only one that's even physically possible :)
JujuFish
11,454
1,057
Wrong.
Let's look at the OP:
Originally posted by: NanoStuff
The plane increases it's thrust and the wheels begin to rotate. The belt compensates for the rotation of the wheels in reverse, as in the belt moves in reverse exactly as fast as the wheels move forward.
Notice the bold part. It does not say it needs to be the same as the wheels' angular velocity, but rather its linear velocity.
BUrassler
811
Thank you very much for saying that. That is all I wanted to know.
BUrassler
811
Wrong.
I cant argue that b/c I dont know what that means exactly. If 5mph and 10mph are not different speeds though, I live in a crazy world.
giantpinkbunnyhead
3,251
Wrong.
angular velocity is rotational speed, not speed along a path. Picture a car skidding with all its tires locked. The tires have no angular velocity because they are not rotating, but they do have linear velocity because the car itself (and therefore the tires) is moving.
clarkmo
2,615
Originally posted by: waggy
sigh.
Then it's gonna have to move off the treadmill and then take off because as long as it's staionary on the treadmill there is no wind speed, no lift and no take off.
So the propulsion pulls or pushes it off the treadmill putting it on the ground and taking off, is that right?
Banzai042
489
sigh.
Are you deliberately avoiding my explinations? Here is one that is being posted for the 4th time in the past hour or so that you seem to keep missing.
clarkmo
2,615
sigh.
That's a stupid analogy because the only ones who get it already understand what tyou're treying to say. It teaches nothing. I edited my post and added...So the propulsion pulls or pushes it off the treadmill putting it on the ground and taking off, is that right?
giantpinkbunnyhead
3,251
sigh.
Yes. the plane moves by propulsion from the engines, which push against the air. The plane doesn't care what's beneath it as long as the wheels are free to rotate. If the treadmill was long enough, the plane would take off on the treadmill as if it were a runway. If the treadmill were moving, the plane would be unaffected, however the wheels would be spinning faster. That's it.
clarkmo
2,615
sigh.
You get the apple :beer:
But you gotta share it with Wag
