Originally posted by: Mark R
The check engine light just means that something is wrong with the emissions system. It could be anything. More importantly, most cars, especially those before about 2000 don't have sensors to check the catalyst is operating correctly.
This means that the engine light can only be triggered by something 'before' the catalyst. This doesn't mean that the catalyst is fine, a lot of faults can destroy a catalyst in short order, but it doesn't mean it is bad either.
You need to find a garage that can read the error code from the ECU, and fix the problem. Then they need to test the catalyst once the problem is repaired, to make sure that it hasn't been damaged.
The check engine light comes on for thousands of reasons - not just emissions. It can be anything from "your gas cap is loose" to "oh crap your engine is ablaze."
At 270k miles, the cat is your car is almost certainly gone. They rarely make it past 200k miles. I've pulled cats out of cars with only 100k miles and they were already completely blown out. You probably just don't know it because you never have to go through smog/emissions check. Note that the OP's problem is that he needs to pass smog. If he lived up north where I do, where a failed smog test is free, I'd say run it through to make sure. But as he lives in CA where he has to pay to find if there is a problem, the way to know if a cat is dead is (1) does the car's exhaust stink in the morning, and (2) has the exhaust tone changed for the noticeably louder and raspier in the last 50k miles?Originally posted by: TwoBills
My '87 Mitsubishi, w/270K, still has the orig. cat. Food for thought. Any shop will try to sell you a new cat. That's where the profit is.
Part #15547 for $109.09 -- shouldn't take more than half an hour to do the swap yourself provided you have the tools.Originally posted by: NascarFool
$109 direct fit replacement.
Did you meet Ben Dover at the dealership?Originally posted by: Blieb
Dealership wanted like 700 ... I got it done at some small exhaust shop for 175 ...
Originally posted by: Gillbot
I have tuned every one of my cars and they have all passed without a cat converter. It's all in how well they run and how efficient the combustion cycle is.
You're right. My bad. My memory is going. *smacks himself*Originally posted by: QuitBanningMe
NopeOriginally posted by: Evadman
Here is a little hint: Emission controls have a 10 year federal mandated warranty. If your car was built after '95, then it is still under warranty with very very few exceptions.
8years/ 80000 miles
Originally posted by: andylawcc
UPDATED
went to autozone today, used their tester thing and found out the problem was just one of the Oxygen sensor! yeah... anyway, so here's the following question, where to buy one?
Autozone said theirs are 180 bucks. Bosch.
Wouldn't hurt to see what the dealer wants for one. Also check out NAPA.
A bad front O2 sensor (or CEL code indicating it is bad) would usually mean that the car is running rough (or rich) or that the exhaust pre-cat is too cool (usually meaning damaged heatshielding, the exhuast must be hot for the cat to function properly.
In your case, I would just buy the cheapest sensor and hope it makes the code go away.
I just called another friend about those Universal sensors, he said stay away from them because they carry the wrong voltage and will be just a waste of money. He recommended OEM all the way.
these are the prices I found
Toyota dealer OEM: 140
Napa: 90
Bosch: 97 from Evadman's link
NTK or Denso (universal): 55
my friend also recommended buying used from junkyard.
