Originally posted by: TwoBills
OK, let's see if I can bottom line this thread. Hm, hydroplaning, inflation pressure, alignment, rotations, front/rear w/the new tires, dry rot, oversteer/understeer w/a blowout. I think that'll cover it.
Hydroplaning: This doesn't really have much to do w/your tires. If your hydroplaning at all, except when you're pushin' it, you need a set of shocks. Good shocks/struts. Not the cheap crap.
Inflation pressure: Inflate 'em until they wear even. Forget max sidewall pressure and the door sticker. Go by the tire wear. Nothing else.
Alignment/rotation: A good alignment guy is hard to find. It's mostly bs. If your ft./rr. is out of alignment, slightly, then step up the rotation times. 2500 - 5000 miles will usually hit the sweet spot. Most alignments will do nothing or make it worse.
Front/rear w/the new tires: I always put my new tires on the drive wheels. Worked for me. Nowadays I buy my tires in sets of 4 or 5 anyway, so that doesn't matter.
Dry rot: if the sidewall is cracking, get new tires. If they're dryrotted the tires, not to mention the driver, shouldn't be on the road. It's the UV that kills em. The heat generated by driving preserves them. Put some ruglyde on em now and again.
Oversteer/understeer w/a blowout: This is mainly driver error. What do you do when you get a blowout @ 70mph? Ease off the gas? Slow down? Steer off the road? Nah! Man, if you get a high speed blowout, stomp on the gas - floor it to maintain speed and control, then ease it off the road.
Speaking of oversteer/understeer: Correct that w/inflation pressure. After you find the pressures that make the tires wear even, then make small pressure adjustments, ft/rr, to balance the car in the corners. Me, w/rwd, I want that ass to kick a little when I lift. Gotta be hard into it, in third gear, for that to even work, unless you're runnin' your rr tires too low.
Oh, yeah, if you're runnin' a 944, never mind. Different beast.
