jlee
Originally posted by: WhiteKnight77
Trying to fix your car nowadays is similar to trying to do surgery on yourself.
Well, I guess I'm doing major surgery on myself today...
I guess you take your car to Auto Zone when the Check Engine/Service Engine Soon light is on don't ya? Their little code reader does just that. Buy the part you believe will fix the car then come to us when you really want the problem fixed becuase that $100 or more part didn't take care of the problem. Mechanics know this and books, code readers, or your buddy down the street who "works" on cars and has a killer tool box full of tools doesn't.
Your argument on mechanics being failures in high school doesn't hold water. There are many mechanics with college degrees, besides the certifications you mention. They also spend more money going to classes to learn all these new technologies than joe blow BS degree, white collar worker that sits in an office all day does to keep current in his job. A good drivablity mechanic can earn upwards of $100,000 a year. Not bad in my opinion. Most repairs come from knowledge and not a manual. Repair manuals are good, but not all knowing. They are good for specs and basic maintence items, but not for really fixing something.
Originally posted by: CFster
Yeah, we'll see how the CAN standard fairs I guess. Well, actually that's only an interface - nothing specific about what kind of data would be exchanged. I guess that will be called an OBD-III standard or something. Everybody had high hopes for OBD-II, but since it was only for emissions diagnosis the manufacturers decided they would leave the other 98% of their information out. I'm afraid the same type of thing will happen again, and the independants will be up the creek as usual. If the automakers get their way, only dealers will be fixing cars.
It's so damned expensive today to fix cars - nobody realizes. We have 15K worth of scanners, 10K worth of diagnostic (Mitchell 1) and shop management/estimating (ADP ShopLink) software, tools, A/C recyclers, coolant recyclers etc. And most of that stuff needs to be updated every few years. Not to mention the training.
The problem is the rotors sieze to the hub. Any Ford dealer will tell you that there is no puller or special tool they use to get them off. What they use, and we use also, is a BFH. That's right, the biggest fvcking sledgehammer we can find and take full swings - sometimes like 20 hits before it breaks loose. Then of course you throw the rotor away. I was concerned at first about damaging the wheel hub bearing assembly but there's nothing you can do about it and that's what the Ford people say too. As a matter of fact, most of the Ford dealers have "on the car brake lathes" now so they don't have to take the rotors off to machine them. But, eventually they all need to be replaced.
That said, most of the manufacturers now state that unless you have deep grooves or some kind of pulsation, that you DON'T machine the rotors. A little bit of rust or scoring is acceptable - so don't turn or replace them unless absolutely necessary. The theory that rotors should be turned every time the pads are replaced is an absolute fallacy.
I am not sure if the above is directed at me...but although I use AutoZone for their tool rental (speciality tools) I have my own ODBII reader that tells me what each sensor is doing, what pending codes are, and what tripped codes are in real time. It wasn't expensive, but it did cost a couple hundred bucks.
I did not say all mechanics, but I can guarantee you a high percentage could not get into college and took that road. Saying a couple month/couple year program compares to a 4 year college degree is absurd. Most mechanics also don't keep updating their skills either. Some do, many don't...there are good mechanics, but many more bad ones.
The same about the manuals vs real world knowledge affects mechanics the same way, if they have never worked on my car they are going on what they think is the right way.
A big example of this was this guys Eagle Summit...died at a red light...the problems he described to me and quick internet lookup (something which all mechanics should do) showed these have bad computers, the exact same things were happening to his car. He doubted me and took it to a mechanic and was charged about $2k for a new distributor, wires, plugs, and a couple ignition parts. 1 week later the same problem. I got him the ECU and he had me redo his front brakes at the same time....I did it for under $75 + the ECU (about $125 I think he paid for it) with new rotors...the mechanic wanted about $1k.
I have done a lot of work on cars, trucks and houses.
I don't know how you know my OBD-II reader is out of date....I can update it to read whatever ODB-II specs there are...I am able to see real time on even my parents 2000/2001 cars.
Like all this talk of the dealerships with $5k computers and stuff...the average Snap-On wrench is about 2-5x the average Craftsman...do any work differently? no. do they have the same warranty? yes. will sears drive a new tool out to your shop? no, and Snap on only sometimes (big shop = better service)...
Most of the big machines dealers are using can be bought much cheaper for home use...they are usually covered with same day replacement policies and the like a "DIY'er" doesn't need...you pay alot for service contracts, but in a business downtime is even more expensive.
Now many of these same machines can be bought at auctions/equipment sales much cheaper ($500-$2k for alot of $10k+things).
It's all about being educated and just because someone were to drop $10k on a complete auto diagnostic computer, it doesn't mean they are going to be able to get it to work or even know what to do when it reports the problems.
Also all you need is the device for the car you are working on...the professional machines are alot more money since they have to have the complete spectrum of OBD-I, II and whatever propreitary things are out there and all those extras have extra licensing fees and software fees on top of the hardware. My reader does not have the extended codes as my ODB-II in my car doesn't use them...if I had a Corvette I would need them and have to pay the $200+ fee for the software to read them...the cable I have would still work.
It's alot like the PC market: You have windows at $100-$500 per license and LINUX at $0. You have a brand new IBM/Dell/Alienware PC at $2000-3000 or a build it yourself with ebay, AT For Sale, etc for $1k....they both do the same thing in reality but the costs of ownership is alot different. Now let's say your DIY PC starts smoking one day....you have no one to call usually, but if your IBM or Dell does, and you have a warranty, one phone call can sometimes have you a new machine the next day.
Also those complete Diagnostic machines usually just give you the convenience of a one stop shop...reading the codes is more than likely always going to be easy....whether someone has to develop a custom cable or not. Now just seeing what codes are there does not mean you know exactly what to change. My throttle body cracked once, but the codes were idle - out of range, TPS failure, MAP failure, IAC failure, and I think a couple more. Replacing all the sensors would be a waste and perhaps still not fix it. So you would have to break out the multimeter and go through the tests in the Factory manual and see what the screw up is. In my case all sensors were perfect....however I knew it had to be mechanical then so I upbolted the throttle body and then it fell in two parts.
A mechanic would have been able to read all the sensors more quickly of course, but I still was able to get the job done just as accurately. No matter how complicated a vehicle gets a code reader and multimeter will probably allow you to solve almost any problem you are going to have.
