Originally posted by: archcommus
I put Sta-bil in before letting it sit unused for 8 months while I was at college, to help preserve the fuel in the tank. That is different stuff from the "dry gas" I'm talking about. I forget the formal name of it, but the guy at the full service station my mother goes to put it in her old Pontiac when it was stallilng, and it eliminated the problem completely.
Thanks very much for the assistance! Very appreciated.
HEET, usually. Common in the Midwest, and areas that it snows in general. My first car practically ran on the stuff, until I found the shoddy duct-tape repair job that the previous owner had performed, and fixed it for good.
Originally posted by: Zenmervolt
My guess is that the anti drain-back valve in the fuel system is leaky and that overnight the pressure in the fuel rail leaks down. Then the first time in the morning when the car is started there is low fuel pressure. Try leaving the key in the "run" position without starting the car for 30-60 seconds in the morning before you start the engine. If it starts fine then, you'll know that the problem is that it's losing pressure in the fuel system and isn't pumping back up fast enough (combination of a bad anti drain-back valve and a clogged fuel filter).
Dry gas will only help to remove water from the gas that is in the tank when you treat it. If the car has been stalling for more than one tank of gasoline, dry gas won't help.
ZV
"Stalling" 3, 4 times a day seems to imply that it happens while the car is running, after having successfully started it. So unless it's having trouble maintaining fuel pressure while running as well (separate issue), it isn't the anti-drainback valve. Clogged fuel filter is possible, though it would be strange that it runs well later on in the day.
As for the second part, not necessarily, it's possible that water is getting into the system through means other than fillup. For example, a leak somewhere, like in my case. My car would stall and run poorly through several tanks, since bits of snow were getting into the intake. The dry gas would partly mask the problem (which gave me no end of headaches, and led me away from a correct diagnosis), but never cure it.
