Hey djheater, did you also replace [or rebuild] the wheel cylinders at the same time? or at least check under the dust seals for any leakage of brake fluid? I dunno if thats what you mean by hardware. It is often a good idea to either replace or rebuild the cylinders while you change out the shoes, would hate to have to R&R the system if it leaks a couple thousand miles later.
Also, if your vehicle has a self adjusting bendix type sytem don't count on it to automatically "adjust" for you, often times you will find yourself using the star adjuster to manually adjust the shoes' contact with the drums.
oh and pat on the back for you and a :beer:
