YACT: I changed my rear drum brakes
djheater
14,637
Total cost: $110.00 - New drums, new shoes, new hardware.
I priced it at a Retail service shop at over $300
I DID manage to clip off a meaningful section of skin from my thumb... it hurts when I move it.
Cheers...
Philippine Mango
5,594
Question, why didn't you just change your brakes to disc? My idea is when I finally work on my toyota land cruiser that I change the front brakes to much bigger roters and put the old disc roater in the back, replacing the old drum brakes.
Insane3D
19,446
Congrats...they can be a major PITA if you don't have the right tools, and are unfamliar with doing them. One thing I used to do when I was new at it was take pictures of how everything was as I took it apart, so I had something to check when putting the new stuff in.
I recently did the ones on my '92 Mustang...new shoes, adjusting hardware, brake hardware (springs, pins, and clips) and two cans of brake clean ran me about $20. :)
Heisenberg
10,621
You have to replace the proportioning valve when going from drum->disc. It can be kind of a PITA.
Colt45
19,720
and then your brake bias becomes horribly offset, and you rear wheels lock up before the front ones do :thumbsup:
Black88GTA
3,430
Cheers...
Nice. Drums are kind of a pain in the ass.
That reminds me, I have to do front rotors, pads, and wheel bearings on my Mustang. Alas, I have no place to work on it anymore - unless I want to start rolling around under my car in 40 degree weather parked on a narrow street w/people speeding by at all hours :(. Probably have to take it in this time.
Pepsi90919
because it's an unnecessary expense?
Black88GTA
3,430
Heh, mine's also a '92
:beer:
Evadman
Administrator Emeritus<br>Elite Member
Feb 18, 2001
30,990
What the hell are you talking about? Do you have any idea? There are like a bazillion things that need to be changed to swap to disks instead of drums. you can't just pull off a drum, slap on a disk and have it magicly work. You have to change all the proprotioning stuff, change brake line size (well, you should anyway) weld up a bunch of custom bracketry, and about a dozen other things.
To the OP, congrats! The only thing I don't like doing is drum brakes. They are a major PITA, and there are some springs with some serious force behind them. I had one richet off my safety glasses in highchool auto shop, and ever since, I hate working on drum brakes.
Insane3D
19,446
Cheers...
I've got to do that soon myself...
I've got a set of Timken wheel bearings and seals, a pair of EBC slotted and dimpled rotors, and a set of EBC "Green Stuff" pads ready to be put on, but the weather has been harsh around here.
I'll probably do them when I switch out my Blizzaks and stock rims for the summer rims/tires in the spring unless my pads wear out before then.
Quick tip. The fox body Mustangs all have 60mm pistons in the calipers. You can do a budget upgrade and put in Lincoln LSC calipers instead, which have 73mm pistons. They are only like $15 each for rebuilts. The Lincoln LSC's from the 90's had the same front brakes as the Mustang, just a larger caliper piston to compensate for the extra weight.
Colt45
19,720
Yeah, I despise drum brakes too. luckily most of my family's cars are disc, except my sisters junker.
$110 for drums/shoes/springs? seems a touch steep - what car is this?
Insane3D
19,446
It's really not when you consider he needed drums....new ones can be fairly expensive...
grrl
6,204
Good job.
Originally posted by: ElFenix
i wish i knew how to do my brakes :(
They are pretty easy. If you are fairly mechanical, you can save a lot of cash working on your car yourself. You have to invest in some tools to do it, but money is never wasted when spent on (good) tools.
NutBucket
27,155
635
Drums are a pain. The best way to not mess up is only disassemble one side at a time. Then you can reference the other side;)
Pepsi90919
how are you gonna do that if only one is disassembled at a time?
NutBucket
27,155
635
Pull of the other drum;)
Baked
36,052
17
Your local shop scams. Hope your DIY job doesn't cause "Aaah crap, I got no breaks."
Insane3D
19,446
:p
A digital camera is perfect for such tasks....take a picture before you take things apart.
ElFenix
102,402
8,574
Originally posted by: grrl
Good job.
my father says he had the tools, i dunno if they're still around.
fscking brake place changed my brakes the other day and now they sound horrible. like they're grinding. cheap ass parts :|
OS
15,581
Good job.
if you're talking discs, it's pretty easy, you should learn. Just get a ghetto hayes manual for $10.
Shops are ripoffs for brake jobs. When my car needed new pads, the stealership wanted f*cken $180 for pads and resurfacing the rotors. I can buy brembo blanks, hawk pads and still have money left over for that much.
Calin
3,112
If you don't have antilock brakes, then your front wheels will lock up before the rear wheels if you have a heavy load, or after them if you have no load
Calin
0roo0roo
64,795
84
yup. the designers balance out the brakes for maximum stoppage without lock. its why sometimes stop distance actually increases for those ricers with giant disc brakes..locked up wheels do u no good.
