YACT: help changing tires
Fenixgoon
33,338
12,924
Originally posted by: KLin
Here's another candidate for Kelvrick's dumbass list :laugh:
gotta learn somehow, rather than be an inept fool begging for assistance for the rest of my life
xbassman
1,243
Originally posted by: Fenixgoon
turns out i couldnt have put on the wheels anyway.. all the tires were directional and i had 3 right side tires and 1 left side.. the ventus tire had "rotation -->" hidden on the damn thing.. so reallly, if i had seen that i didnt have the required tires, none of this would have happened :|
ummmm... no such thing as left side and right side tires.
You have to have them mounted correctly on the wheel.
Nebor
29,582
12
Yes, there are such things as left and right side tires. They're called asymetrical, as in they aren't identical. High performance tires are usually like this.
jlee
48,518
223
Originally posted by: murphy55d
This is why I let trained professionals do any sort of car-work.
I hope you don't think they all work at Pep Boys.. :p
Fenixgoon
33,338
12,924
car seems to be in relatively good condition.. it will be taken to some repair shop or another to make sure everything is fine. i hope this doesn't cost me $$$
iamwiz82
30,772
13
Mounting the tire backwards = opposite
murphy55d
11,542
As in, ASE Certified.
Now that I have a new vehicle that's under warranty for 10 years, I'm hoping any kind of work will get done at a dealership.
Vic
50,422
14,337
It doesn't take ASE certification to change a tire.
It seems to me that the OP's problem is that (IIRC) VW/Audi uses hubcentric wheels. In order to make the wheels sit flush to the hub, you steadily tighten down all 5 lugs in the proper star pattern. As you tighten each lug in turn, the wheel will eventually flush to the hub. On the final tightening turn, it is crucial to torque the lugs to the proper specification, and then to re-torque them 2-3 days (and roughly 100 miles) later as a precaution.
Tires that are designed to roll forward in one particular direction only (usually for more efficient rainwater shedding) and fit only on one side of the vehicle are known as "directionals". The proper side and rolling direction will be marked on the outside sidewall of the tire.
Scissor jacks suck :p
Uhhhh, no.
Fenixgoon
33,338
12,924
Uhhhh, no.
yes there are.. they're called directional tires.. you cant mount a forward rotating tire that would normally be on the right side of the car on to the left.. it would be rotating in the direction opposite of what it's supposed to
StageLeft
70,150
I thought we already covered the tires being directional. Some are. I can take a picture of my directional tires when I get home if it would make anybody happy. You can tell by the arrow on them, and the fact that they say LEFT and RIGHT on them.
Uhhhh, no.
You take that tire, remount it to another rim the other way and put it on the opposite side.
Is that hard to understand?
CraigRT
31,440
I've never had a set of non-directional tires on my car :p
the Max has Proxes FZ4 which are directional too...what are you running on yours man?
StageLeft
70,150
[/quote]They're still directional :) As an aside, I think that the specs of a tire are written on only the outside...not sure though.
Cheapest H rated I can find! Actually my new tires are not directional, but I still have a pair of directional Vs, that came with the cars when I bought them (each car has two Vs and two cheapy Hs).
Baked
36,052
17
Ok class, lets go over what's wrong w/ this picture -
1) Drives VW
2) Have trouble putting wheel on
3) ...
4) teh ghey?
No offense to gay guys who can put a wheel on of course.
Ok seriously now, call road side service. Or better yet, PM ribbon13, it seems to know everything.
Fenixgoon
33,338
12,924
1) Drives VW
3) ...
4) teh ghey?
my VW can burn a lot of cars. the 1.8T can be pretty damn quick, esp when you're pushing 15 PSI w/ the turbo. it doesn't have the stock antenna, so it doesn't look goofy. lowered suspension looks very good.
They're still directional As an aside, I think that the specs of a tire are written on only the outside...not sure though.
All of my tires are identical on both inside and outside. I have had directional tires (nokian hakkapilita) taken off the rims, mounted the other way, and rotated to the other side.
Directional tires can be on either side of the car. The only exception I see is if you have partial directional tread. Like a small piece of the tread on the left half of the tire is directional, and the rest is not (green diamond tires). Even then, if you remount all of them on the rims and rotate them, they will all match up properly.
So the fact that the tread is directional doesn't matter, it will still rotate in the proper direction no matter which side you put it on.
