YACT: 05-06 Mustang GT MPG
fbrdphreak
17,555
Originally posted by: Zenmervolt
I tend to be aggressive with the throttle but conservative with the shift points; 60%-80% throttle but shifting at only 2,000 RPM.
Ah, just what I was looking for. That's probly how I'd drive it most of the time :)
Zenmervolt
Elite member
Oct 22, 2000
24,514
44
Originally posted by: fbrdphreak
While you're on, what RPM are you cruising at on the highway in 5th? Say 70-80MPH
For my Mustang GT with the 18" wheel option, 2,000 RPM is 70 mph in 5th. The cars with 17" wheels are slightly different, but not much (I think 2,000 RPM = about 65 for them, not sure though).
ZV
Zenmervolt
Elite member
Oct 22, 2000
24,514
44
Why's that? Does it use a picky airflow sensor?
Very sensitive computer and MAF meter. Most people who tune see better drivability and improved mileage.
EDIT: You will run lean if you just use an intake without a tune. It might not be lean enough to trigger a CEL, but you will run lean.
ZV
fbrdphreak
17,555
ZV
Tune as in use pre-fab'd maps or get into the nitty gritty of tuning it by hand? I have no problem plugging something in and hitting "DOWNLOAD" ;)
KentState
8,397
393
Originally posted by: datalink7
I guess that is a lot of highway. I am in the military but live about 20 minutes away from post. And on post the route I take is basically 40mph with very few stops untill I get to my building. I'd think you'd still be able to get 20mpg even with a lot of stop and go. And it takes 87 octane fuel, so you save money there.
That's what I'm hoping for with a Mustang; 87 octane and decent mileage. One might be able to get 20MPG city out of a GTO driving conservatively and even more on the highway thanks to the 6-speed, but it drinks premium. We'll see... :)
Originally posted by: I Saw OJ
I have an '03 Cobra, its a little bit different beast but with 85% of my driving being highway I get around 19mpg.
I do have some mods done, but just thought I would put in my 2 cents.
Thanks for the info, but I bet that SC sucks some gas ;)
The tank of gas in the GTO I was able to get 16 mpg in 80% stop and go. On the highway, it can easily get high 20s cruising around 75mph. It also can run on 87, but will have "better" performance with premium.
Zenmervolt
Elite member
Oct 22, 2000
24,514
44
ZV
A hand-held computer that you buy plugs into the OBD-II port and re-flashes the car's ECU. It takes 5 minutes. :)
ZV
fbrdphreak
17,555
ZV
ZV
Sweet, that's what I was figuring.
Zenmervolt
Elite member
Oct 22, 2000
24,514
44
ZV
ZV
Ford was pretty conservative with the ECU calibration. People are getting 30+ hp from intakes with a re-flash to a 93 octane tune. Even a re-tune at 87 octane can give you around 20 hp. The hand-held tuners (a professional shop can sell you one with 3 custom tunes) are great to have because they are also OBD-II readers and they can be used to re-calibrate the guages if you change tire sizes or the rear axle ratio.
ZV
Gunslinger08
13,234
I'm not sure how you'd shift at 2000 while hammering the throttle. You'd be changing gears about every 1/2 second.
fbrdphreak
17,555
If I had to guess, by the time you got to 3rd you'd be at a good place to stay at while cruising in the city? Low enough RPM for fuel conservation but in a low enough gear to pass smoothly?
Gunslinger08
13,234
I literally hit 2000 RPMs at about 5 miles per hour in first gear. Then probably 15 miles per hour in 2nd. You're going to be at/below idle RPMs right after changing. It doesn't seem the most efficient to me. I think 3000 would probably be a better shifting point so that you don't have to open the throttle up as much to raise the RPMs.
fbrdphreak
17,555
I see. Yeah makes sense, but my understanding is that most engines are more efficient with greater throttle @ a lower RPM; I'm sure this of course can vary based on exactly how much throttle one is using. I'd be interested to see a list of gear ratios/speeds (like 1st gear tops out at 40MPH, 2nd gear 70MPH, etc etc).
Either way, I'm sure revving to ~2500RPM should be plenty for city driving; I can do that in my 165HP Subaru which has relatively short gearing for an automatic IMO.
Gunslinger08
13,234
Those are actually pretty accurate. I redline in 1st and 2nd right around those areas. I haven't redlined 3rd yet.. I don't like to do 100+ most of the time.
fbrdphreak
17,555
I asked this before, but what RPM are you cruising at in 5th @ highway speeds? 70-80MPH
Gunslinger08
13,234
Good question. I can't remember off-hand, but I'll check on the way home.
fbrdphreak
17,555
Thanks for all the info :)
essasin
2,777
ZV
ZV
ZV
You will not get a 30+ hp from just changing a cold air filter and getting a tune.... that is completely unheard of. Cold air intakes and a tune are a supporting parts...they won't give 30 hp on a stock GT ever. The stock air intake breaths more than enough for a stock engine, so your bottle neck is the engine itself.
Take the 03 04 Terminators....now they have had the most conservative tune in Ford history because they are supercharged and incorporate a limited exhaust and air intake to pass emissions. In this case the air intake and exhaust (support parts) are restricting the engine. In this supercharged setup a cold air intake and a tune may BARELY gets 30 hp out of it. I believe it saw a 20hp difference. This is a full out supercharged engine here...so there is no way a stock GT engine increase 30+hp.
However see a slight increase from changing the upper and lower intake manifold with a tune. But honestly you are wasting your money if you are tuning a stock car...there is really no point. Its like getting a dell and overclocking it and spending the time to tweak out every last bit of 3dmark pt out of it.
Zenmervolt
Elite member
Oct 22, 2000
24,514
44
Yes, I am shifting very often in town. 1st gear is a slight exception and I typically wait until almost 10mph to shift into 2nd.
RPM is far more important to fuel mileage than throttle opening. It is better for mileage to have 80% throttle and 2,000 RPM than it is to have 40% throttle and 3,000 RPM.
25mph is 3rd gear if I know I'm not going to be cruising at it for a long time, 4th gear if there's a long stretch. At 35mph I'm typically in 5th unless I'm accelerating onto a freeway where I might hold 4th up to 45 mph. (Or if I'm going "balls to the wall" when I'll hold the gears to redline. ;) )
ZV
Zenmervolt
Elite member
Oct 22, 2000
24,514
44
Then someone faked the dyno sheets I saw, and did a damn fine job of it.
ZV
Gunslinger08
13,234
ZV
Wow. I couldn't stand to drive like that. I need that power on demand, all the time. 25 and in 4th gear would kill me. I'm usually having a hard time deciding between 2nd or 3rd at that point. I guess it saves you some gas and wear on the engine/transmission.
Zenmervolt
Elite member
Oct 22, 2000
24,514
44
In a new Mustang GT? There's plenty of power in 3rd at 25mph. 4th is definitely sluggish, but it's easy to downshift quickly. I tend to keep the engine under 2,500 RPM on the street. No real need for me to run it hard unless I'm at a track.
ZV
