MrSquished
Ignoring the ignorant, incorrect and clueless trolling poster and moving on.
I received the XIM Apex, and it does indeed work great. It took about 10 minutes to set up to get working, and about 10 more to make sure all the keys are programmed correctly. The app is very easy to use, and you simply hit a button, say X within the app and then it will say "listening". Hitting a button on the keyboard maps the button from the controller, to the keyboard. I did not find any button that would not work. One nice feature is that you can set a different sensitivity to the general mouse movement, and a different one for when you are zoomed in. Normally lowering the sensitivity is better when at 3x zoom rather than having it faster. I am using an older Razer keyboard, and a budget MSI mouse I got with a motherboard I ordered. Buttons on the mouse worked fine too, I did not encounter any problems with it. Its not too crazy of a mouse, two side thumb buttons, one under the wheel, and the two standard buttons up top. Zero issues. Fine tuning what you want the mouse sensitivity probably took me the longest. Much like a steering wheel for racing, or an arcade stick for a fighting game, this feels far more natural to me. Its not different than another 3rd party controller. I detest playing a FPS with a gamepad, now I don't have to. I have only tried BF1, and Battlefront II so far. Overwatch is next, other people claim it works well too. I have all three of those games on PC and console, it would be very nice if I could either link the accounts, or log into each with the same user/pw. Yet they won't let us. I have contacted EA regarding it after reading online that people have gotten it to work, support claimed it was not possible. I'll try again and see what the next guy says. There is no way to log out of BF1 on the PS4 and try another login, which is annoying. I uninstalled, reinstalled, I was already logged in. When I bought it I tried my PC login details, didn't work. But now I can rejoin the guys from work and play on the PS4 and not feel like I am soaked in molasses trying to control the game. I also have all auto aims off.
I just ordered this and will be here Saturday;
Reviews were great, beating out the Corsair and Razer model by most accounts. I have been wanting a newer Razer mouse for my PC, so Ill just transfer my Razer Mamba TE to the PS4. Thanks to PixelSquish for the heads up on this. I had been waiting for the release, and it slipped my mind.
Dude the new Beta Firmware, EX1, has some new settings which change what the BOOST setting does per config. So there are now 4 settings for BOOST - BOOST 0, BOOST 1, BOOST 2 & BOOST 3.
I tried the BOOST '0' setting in BF1 and it is definitely better, and I thought stock was pretty damn good already. BOOST 3 would be the same as the stock config.
Check it out if you feel like messing around. Make a new config for the game though, as your sensitivity levels will be different with each BOOST level. You can rename each config you make so it would be easy to switch back and forth while testing them out if you so choose.
