DrMrLordX
- Apr 27, 2000
- 23,217
- 13,300
- 136
If your 880k is anything like my 7870k - and it ought to be since they're basically the same CPU - you should be able to do 4.3 GHz on 1.3v or less. Though 4.2 GHz may be a better point to aim for. Mine will do that with less than 1.3v.
Don't forget the NB! Get that sucker at least to 2000 MHz. There's performance left on the table if you don't bring that clockspeed up some. Mine will do 2100 MHz at default vNB.
