X2 4400+ aggressive OCing
The heat is going to be a bit much over 1.55V. If 2.8GHz isn't stable, settle for 2.75GHz or 2.7GHz with less voltage and heat.
Currently 2.7Ghz is my top bench speed. I am hopeful that this burn-in cycle is not a mythe but will help it to oc further after some getting used to at a higher speed.
24/7 use is @ 2.4GHz with 1.4v, only because I forget what stock voltage is.
very nice oc :thumbsup: i wouldn't push it much further either. is that 58 temp still holding?
Originally posted by: Avalon
Stock should be 1.4v, and nice job with the overclock.
:thumbsup:
Stock is actually closer to 1.26V from most reports on various forums. That is what my DFI defaults to.
:thumbsup:
That doesn't mean that is what it is.....AMDs own specs say 1.35v-1.4v....1.29 for me on my board would make perfect sense if the board was undervolting like it always has....
I agree Duvie. My CPU sits at 1.3 stock.
There is no such thing as a stock "1.4 Vcore X2". At least, not yet. 😛
Well in any case, at least the CPUs are performing stable at VCore <1.3V at stock speeds. Gives them a little more headroom when overclocking.
Yeah, but I can even run 2600 MHz with 24/7 stability (100% load on both cores) at 1.3 Vcore. It's possible, but a 200 MHz OC while being undervolted? 😕
I would expect that CPU to break the 30 sec barrier. My not too good 3000 Winnie running at 2475MHz core speed with 5:6 mem divider will yield 34 sec 1M SuperPi.
