X1950pro AGP - FEAR
Paratus
17,692
15,941
I'd say he's CPU bound but unplayable is in the eye of the beholder. I played FEAR online with an 9600XT! (at 800x600) ;)
apoppin
34,890
alienbabeltech.com
i am using the OP's definition ...
he *wants* 35FPS as a minimum for 12x10
:Q
Core2Duo and 8800GTS?
:confused:
heck Core2Duo and 9600p ... the FPS are mostly determined by the CPU
... there just won't be any 'detail' ... but it will be smooth as butter
:D
aircool
28
Sorry for lookin an ass, but you could of at least stated a lower fsb mean lesser fps.
Sorry.
Anyway, i think i expect WAYYY to much (as yuove said) so i got stalker and this is so that i know what 30 fps looks like.
Thanks
apoppin
34,890
alienbabeltech.com
no prob :)
i did try to correlate CPU speed including lack of bandwith with Frame-rate :p
STALKER !!!
:Q
it's a real resource hog if you have *everything* maxed :p
make *sure* you put (1) grass way down ... (2) grass shadows off and (3) AA to min ... runs good for me with *everything else* maxed
Paratus
17,692
15,941
Sorry.
Thanks
No problem!
I missed yours was a 2.8'A' in your OP. That would have saved us all some time.
You still have a good rig but your going to have to trade some eye candy for FPS.
apoppin
34,890
alienbabeltech.com
Sorry.
Thanks
No problem!
*this* is why i was confused ... from your P4 thread:
http://forums.anandtech.com/messageview...&STARTPAGE=6&FTVAR_FORUMVIEWTMP=Linear
Hello, can you help me.
My computer:
-Pentium 4, prescott core, running (OC'ed to) 3615mhz, from 2800 stock.
-1.5gb ram
-ASUS P4C800-E DELUXE
-200gb HDD, in total.
-500w dual railed psu, 18a each.
-Sapphire X1950pro AGP
I cannot play fear smoothly, even at low settings.
1280x960 at low settings, even minimal, plays bad.
i score 7.5k ~ in 3dmark05.
i don't believe ANY Prescotts were P4-A :p
they were *after* Northwood ...
:roll:
no wonder there was confusion ;)
Paratus, he has no trade-off of eye candy for FPS
... His CPU renders FEAR unplayable (for him at even 10x7 ... he is gonna have to DROP his resolution to 800x600 [or even 4x6] to get 35FPS as the *minimum* Frame Rate
--of course he can probably get *maximum* eye-candy and detail plus 8xAA/16xAF at 8x6
apoppin
34,890
alienbabeltech.com
there really is a P4 'A' at 2.8ghz pressie core'd.
it must not have been popular .. i can certainly see why :p
:D
actually ...
Prescott was always called "E" but you are *right* there was a further "A" [533 FSB] designation in the line
http://techreport.com/reviews/2004q1/p4-prescott/index.x?pg=1
Prescott clock speeds will initially range from 2.8GHz to 3.4GHz. To keep Prescott-based P4s distinct from older "Northwood" cores, Intel is tacking an "E" on to the product names, so they'll be called the Pentium 4 2.8E or 3.2E. The product mix gets most confusing at 2.8GHz, where one could buy four different Pentium 4s: the 2.8GHz (a Northwood core with a 533MHz front-side bus), the 2.8C (Northwood again, but with an 800MHz bus), the 2.8A (Prescott with a 533MHz bus), or the 2.8E (Prescott with 800MHz bus). Clear as mud?
it makes little sense to have a fairly high-clock CPU completely *crippled* by its FSB ...
:confused:
that's when AMD pulled ahead with A64
but yeah, faster CPU for better frame-rates in FEAR
or turn the resolution way down ... now
glad that's clear now :)
