X1950pro AGP - FEAR
apoppin
34,890
alienbabeltech.com
Originally posted by: lavaheadache
Originally posted by: apoppin
Originally posted by: aircool
Ive allways wanted a gallitin.
My expectations were not high, i hoped that it would be better than my 6600 card which so far on low its not.
i *hoped* for a 'cheap' 3.4c ... since '04 ... actually buying a decent OC'ing 3.4EE Gallatin for less than $100 [net] has *exceeded my expectations* :)
what i am *thinking* is that you were/are CPU limited with your 6600GT
... and you are still CPU-limited with your x1950p ;)
it is my understanding, the CPU determines the minimum and maximum FPS [basically] ... the x1950p allows you to play at *that* same resolution with much more *detail* and AA/AF then your old CPU
lower the resolution - if i am right, it is the *only* thing that will make any real difference ... 1:1 pixel mapping should make it a playable experience if you want *fluid*
or sell your GPU [$40] and buy a Gallatin for $120 like i did
NOT saying it will *cure* your problem ... there may be *other* issues [like heat] that may also contribute to the instability in FEAR
ALL i am saying - with a similar system - is that i got it 'too' ... not as bad since my resolution was 10x7 ... and "cured" it by getting a much faster CPU
from 8000 in 3DMark05 > 9280 with the EE
that is *substantial* in my book and possibly enough to explain what i am seeing in FEAR's x-pack
let others weigh in
I think you meant CPU ;)
of course, a TYPO and i also edited it above to reflect the *latest* ^
it's pretty clear from the context that 'CPU' is all i am talking about
i read it thru and was correcting and editing it just as you quoted it ... since i am stuck on dial-up it take me a lot longer
the other members have learned to put up with my edits :p
[as long as they aren't hours later :D]
aircool
28
To bad i dont live in the us though, otherwise id be watching closely at a gallitin right now
so i play at 1024x760 it will be smooth? if not smoother than playing in DX8 mode at 1280x960?
apoppin
34,890
alienbabeltech.com
try it and either *confirm* or *debunk* what i am saying
please
i think you are CPU limited above 10x7 ;)
then crank the crap outta the details inc AA/AF till you notice :)
you might also try lowering your OC just a bit [or not] and playing around with the timings in PAT ... might be able to 'up' the overall CPU performance that way
aircool
28
How am i cpu limited above 10x7?
bottlenecks are ussually suppresed when playing at a higher res...
apoppin
34,890
alienbabeltech.com
just *TRY* it ... 10x7 ... try not to vomit :p
we'll discuss later
[i think it also effects the MIN fps ... your 'chugging'. ;]
OK?
fair enough?
what Happens when you run FEAR at 10x7? is it *the same crap* or not?
imo 10x7 IS a "higher resolution" ... with your dog-slow CPU :p
:D
apoppin
34,890
alienbabeltech.com
oh, PLAY the game for a few minutes ... don't depend on the benchmark
what happens at 10x7 compared to 10x12?
:confused:
i will be very glad to admit it if i am wrong
apoppin
34,890
alienbabeltech.com
no aggravation whatSOever
it is one thing to *talk theory* ... endlessly ... about CPU speed effects on resolutions ...
i am just suggesting your TEST my *theory*
--right or wrong, i have no problem accepting results
i am "predicting" that FEAR will be a lot smoother at 10x7 than at 10x12 --nevermind the "details" setting with a x1950p and your CPU. ;)
--much closer to your original *expectations*
aircool
28
not that much better though, come may time ill have some spare cash to grab either a galitin core'd p4 or a pentium M + CT479, Pent M is the better one :)
aka1nas
4,335
Originally posted by: MrK6
What specifically do you mean by "bad FPS"? Is it a low average, surging/sinking, glitchy? Be aware that FEAR is a pretty CPU intensive game, that 2.8GHz P4A (are you sure its not a B with the 533FSB?) might not be cutting it. What's your FSB at (P4 A processors had a 400FSB, overclocked, yours should be at ~484)?
A P4 A would be a Willamette, which only went to 2Ghz and used either RD-RAM or SD-RAM AFAIK. Northwood Bs were 533FSB chips with Northwood C being the 800FSB variants. I would guess that it's actually a Revision E Prescott given the clockspeed of the chip.
aircool
28
See, i doubt this because temps are all fine.
lol even my gpu temps fine, 60 at "load"
Paratus
17,753
16,088
Can you check RAM speed (try CPU Z) to see if your running 1:1 or if your RAM is significantly underclocked?
apoppin
34,890
alienbabeltech.com
damn ... i am not gonna talk to you anymore if you keep ignoring me
--you can *have* and enjoy your crap performance for all i really care :p
:roll:
you and akshayt have a *lot* in common ... ADD
last time, aircool - what was the bottom FPS difference between 10x7 and 10x12 in FEAR? on *your* rig???
if not i am going back to STALKER
... at least i can shoot those not paying attention, in game
:laugh:
--Not "online" play ... that has *nothing* to do with anything discussed here :p
---Single Player
aircool
28
yeah its 1:1, currently at 167mhz or 3.5ghz.
This isnt all about online, im just trying to play a game.
im sorry, im out :(
apoppin
34,890
alienbabeltech.com
me too :(
-for good :)
you still didn't answer my question :p
don't bother
frankly, i just don't give a damn ... anymore
:lips:
good luck ... you'll need it
... and aloha!
1:1 is *not* 167Mhz
:thumbsdown:
:roll:
we got akshayt back!
:heart:
:laugh:
Paratus
17,753
16,088
Your bandwidth limited. P4 's love memory bandwidth. Most P4 C's & E's run with a 200mhz FSB (800mhz Quad pumped.) & DDR 400.
Yours is running at 167 Oc'd! thats only 667 & DDR 333. Either there is something wrong in your BIOS settings or you have a 533 FSB version P4 which are significantly slower than the 800FSB versions.
You also won't have hyperthreading which hurts a little as the CATS are multi-threaded.
apoppin
34,890
alienbabeltech.com
Originally posted by: Paratus
He's got the 533 FSB version. Thats the problem.
i didn't think they made a Prescott with a crippled FSB :p
and that is *part* of the problem ... basically he *expects* way too much
-rigs way faster than his can't run FEAR at 10x12 with 35FPS as the *minimum*
and as i said, his CPU is dog-slow ... look at the 3DMarkO5 scores ... the CPU determines both the minimum and maximum frame rates ... the GPU gets the details and AA/AF, etc.
[it is much more complex than that ^ .. very basically]
a better cpu or lower expectations ... he can attempt to 'tweak' it ... but that's about it
would you say, Paratus ... in this case ... his CPU is holding back his X1950p?
--even in your topic's tests in FEAR at 10x7 with the CPU not maxed, it dropped to *unplayable* for about 10% of the time ;)
here
F.E.A.R___________________________________________________
CPU 10x7 10x7 12x9 12x9
Speed 0XAA-Tri 4XAA-16XHQAF 0XAA-Tri 4XAA-16XHQAF
2.8: 22/66/200 20/53/162 21/57/155 18/45/129
BrkDwn: 5%/33%/62% 11%/34%/55% 7%/32%/61% 12%/42%46%
3.2: 28/77/210 25/59/167 25/64/168 22/49/134
BrkDwn: 0%/20%/80% 0%/38%/62% 0%/31%/69% 5%/42%/53%
3.6: 30/77/203 25/60/173 26/66/180 22/50/135
BrkDwn: 0%/15%/85% 0%/36%/64% 0%/26%/74% 1%/48%/51%
with the weaker CPU it is unplayable at 10x7
